Author Topic: need help :(  (Read 1624 times)
Offline CK
  • http://i1053.photobucket.com/albums/s475/carokenn/
need help :(
« on: July 07, 2012, 06:37:05 pm »
hope someone can help, might be a stupid question but im a girl so i have an excuse :) the heated seats in my car wont work will i need new fuses or elements ?and where would i get these would i have to go to vw.
thanks:)x
Offline Syrag64
Re: need help :(
« Reply #1 on: July 07, 2012, 07:06:30 pm »
I would first check the fuse in the fuse box, if thats ok then get someone with a multimeter to check that power is actually getting to the elements before condeming them.
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline CK
Re: need help :(
« Reply #2 on: July 07, 2012, 07:16:44 pm »
Ok thank you ill get it looked at :)
Offline DarkSideJohn
Re: need help :(
« Reply #3 on: July 07, 2012, 08:29:02 pm »
If you do go to VW just flatter your eyelashes a bit and im sure the price will be reasonable ;)  :evilgrin:
Sorry that was totally off topic but just had to be said
'04 GT TDI 140 | Remapped | Cold Air Intake | WALK | TBE
Offline CK
Re: need help :(
« Reply #4 on: July 09, 2012, 12:04:45 pm »
that was the plan anyway hahah :P
Re: need help :(
« Reply #5 on: July 09, 2012, 12:17:55 pm »
Or you could look in the Passenger compartment fuse box at position 37 (should be a 30A fuse) to see if blown.
Offline CK
Re: need help :(
« Reply #6 on: July 09, 2012, 12:45:54 pm »
i have no idea where that is lol ill need to get someone to have a look for me .thanks tho at least i can pretend i know what im talkin about :) lol
Offline gazon69
Re: need help :(
« Reply #7 on: July 09, 2012, 05:01:28 pm »
Hi, have they never worked or have they all of a sudden just packed in.
Offline CK
Re: need help :(
« Reply #8 on: July 09, 2012, 05:02:37 pm »
Hi , im not sure i just bought the car a month ago they will have at one point but iv tried them and no heat at all so both of them are broken :(
Offline gazon69
Re: need help :(
« Reply #9 on: July 09, 2012, 06:29:41 pm »
Hi there, i dont mean this sarcastic so please dont take this the wrong way, have you tried turning them on whilst sitting in the seat or have you switched them on and touched them with your hand and noticed them not working. The reason i am asking is because if you dont sit in the seats they dont heat up. You have to be sat in them for the sensors to work. If you have then as said, could well be a fuse.  :happy2:
Re: need help :(
« Reply #10 on: July 09, 2012, 06:44:10 pm »
You could also check the connection under the seat hasn't come out. Clips into the floor connector and if you shove things under the seat they can get disconnected. :smiley:
Offline CK
Re: need help :(
« Reply #11 on: July 09, 2012, 06:47:40 pm »
haha no its fine , yeh i realised that iv tried them a few times they just dont heat up at all :P
Offline CK
Re: need help :(
« Reply #12 on: July 09, 2012, 06:49:20 pm »
well i did notice the black plastic cover has came off my seat so i put it back on maybe somthing has came out . when i bought the car he did say they all worked fine. hope its just me being stupid and i dont have to go get them fixed lol
Offline TrickGTI
Re: need help :(
« Reply #13 on: July 09, 2012, 08:02:38 pm »
For them both to not work then it's more likely to be a fuse problem as its very unlucky and unfortunate for both seats to pack in at the same time. So as said a garage will check this for you. A independant garage is more likely to check the fuses and not charge you whereas VW who prob will charge. We don't charge for little things like this at our garage as it takes seconds to check. Again checking the feed to the seat is also a failry quick job so don't let anyone tell you it takes ages and charge you a fortune  :happy2:
2006 Tornado red GTI
Offline CK
Re: need help :(
« Reply #14 on: July 10, 2012, 12:37:38 pm »
Aww thank you x
