Author Topic: cruise control fitted now warning lights on dash on.  (Read 4025 times)
Offline pd9264
« on: July 07, 2012, 08:15:02 pm »
hi just fitted cruise control and had it coded. but i now have a fault code which i think is steering colum module. i have three lights on the dash board
esp light
orange steering wheel
and the tyre pressure monitor symbol
iv driven the car for around 30miles now and they havent gone out.
iv removed everything and refitted to make sure i hadnt missed anything out. but still the same. iv tried setting the steering sensor by turning the steering wheel all the way to the left then all the way to the right. but no success. any ideas of whats happend.
Offline donovan2123
Re: cruise control fitted now warning lights on dash on.
« Reply #1 on: July 07, 2012, 09:24:34 pm »
Did you check the pins? Did you see if there is any markers on slip ring to show if it needs to be lined up is connector at steering module connected properly? I check all fuses related to steering module.
Also post up the fault code
Offline donovan2123
« Reply #2 on: July 07, 2012, 09:28:38 pm »
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 366722EB3D63
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 -  -
The above is the fault code and name from your car mate
Offline Matto
  • -Receive: 116
« Reply #3 on: July 07, 2012, 10:01:50 pm »
Did you complete all the basic settings afterwards?
Offline donovan2123
« Reply #4 on: July 07, 2012, 10:04:53 pm »
what basic settings are these?
Offline Matto
  • -Receive: 116
« Reply #5 on: July 07, 2012, 10:14:28 pm »
The sensor needs to have the basics settings restored. This will extinguish the orange steering wheel light. Park up on flat level ground with steering wheel straight, go full lock left and hold for 10 secs, then back to the centre for 10secs. Repeat going full lock right for 10 secs then back to the middle. Afters this drive forward in a straight line no more than 10mph and the light should go out. The esp one should do as well after a little distance.
As for the TPMS, that might just need setting as you normally would once the basic settings have been done. Not sure though as I don't have it.
Offline pd9264
« Reply #6 on: July 08, 2012, 10:53:46 am »
i tried resetting the basic settings but it doesnt turn the lights off. i tried it 3 times. iv checked everything is is pushed in correctly. the slip ring can only go in one place as its got pins that feed oin to the seering wheel. so that is defo in the right place.
Offline pd9264
« Reply #7 on: July 19, 2012, 08:49:47 pm »
i removed everhing the other night and did find a bent pin. anyway sorted that out, and now the steering wheel light has gone out but the esp and tpms are still on. any sugestions
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: cruise control fitted now warning lights on dash on.
« Reply #8 on: July 19, 2012, 08:57:54 pm »
Following the basic settings in the correct order will sort that out.
It took me a few times when I first did mine... I'll find the link...
VCDS (Preston, Lancashire)
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: July 19, 2012, 08:58:18 pm »
Post up a full Auto Scan of what you have.
Stu...
Offline donovan2123
« Reply #10 on: July 19, 2012, 09:33:36 pm »
Think when my replacement lead comes we will be able to do the basic settings this time now you have found bent pin  :signLOL:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #11 on: July 19, 2012, 11:36:08 pm »
Heres the link:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
Do Steering Angle Sensor Basic Setting
After successful basic setting, the Steering Limit Stop needs to be adapted too.
Jas
Offline pd9264
« Reply #12 on: July 20, 2012, 08:06:17 pm »
cheers matey. that was wierd why it burnt out. what did ross tech say. i need to gt one really but cant afford at the moment.
Offline donovan2123
« Reply #13 on: July 20, 2012, 08:09:05 pm »
To be honest I think it was my fault. I guess I should of disconnected it when switching on converter. From what I can see it was the negative pin which managed to short. Never mind Ross tech have been ace.
Offline donovan2123
« Reply #14 on: July 20, 2012, 08:09:59 pm »
Replacement should come next week  :happy2:
