Author Topic: Oil question  (Read 3452 times)
Offline Rustybear
  • -Given: 243
Oil question
« on: July 07, 2012, 08:44:52 pm »
Having had a BMW previously I am used to the oil light coming on every 1000 miles or so and having put a litre or so in. Had the golf gti for circa 6 months and no oil light has come on. Is it meant to and do they burn allot of oil? Checked the level and looks ok so just wanted to check. Car had full service before I bought it.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Oil question
« Reply #1 on: July 07, 2012, 10:15:05 pm »
Some burn oil, some don't.
I've read on here it is due to how they were run in  :surprised:
Anyway, the dipstick has a min and a max on it to enable you to check it, don't rely on the oil light to tell you. There was a thread on here the other day about the oil light only coming on for someone when the sump was practically bone dry  :scared:
My advice (and I'm sure 90% of the forum agree) is check it monthly at least by the dipstick  :happy2:
Gray
Offline edd666999
  • -Receive: 89
Re: Oil question
« Reply #2 on: July 07, 2012, 10:16:10 pm »
You should never wait for a oil light to top up oil....should really be checked regularly  :drinking:
Offline Beddie
  • -Receive: 76
Re: Oil question
« Reply #3 on: July 07, 2012, 10:19:26 pm »
The OP of that thread overreacted somewhat imo, he had the yellow 'low oil level' warning come on then had a 'mechanic' check and top up the oil on a hot engine with 2.5l when the required amount on activation of the yellow warning is only 1litre to refill to capacity...
Checking monthly as you say and not relying on the warning is the way to go  :happy2:
Carbon Grey Edition 35 - Here
  • -Receive: 427
Re: Oil question
« Reply #4 on: July 07, 2012, 10:31:03 pm »
Had my ED30 6 months now and try to remember to check every month. It is something I am conscious about with a turbo'd engine. IMO don't just top it up, change it at least every 6 months, got a good deal on at National Tyres using (5 litres) Castrol Edge 5W30 For £40 ish about 2 weeks ago. For peace of mind it's worth it alone.
Offline gigolo456
Re: Oil question
« Reply #5 on: July 08, 2012, 12:03:08 am »
After reading this thread I went out and checked mine, and if anything the level was above the max level! My GTI was serviced bout ten wks ago, so not sure if owt 2 worry bout, bearing in mind ive had a TBE, Twintake and remap since then!? I'll b honest, ive never topped up, r needed to, in the 7 years ive had my car!! That oil refill has been in that rubber holder in my boot and has never been opened once, never mind used, lol!!
Offline reflex11
Re: Oil question
« Reply #6 on: July 08, 2012, 12:34:54 pm »
i always check oil plus just changed other day.. can't help when eurocarparts have 30% off oil, 5w30 castrol edge 4lite + 1litre + oil filter =£43 pound... :rolleye:
Offline Frenzy
  • -Receive: 29
Re: Oil question
« Reply #7 on: July 08, 2012, 09:17:59 pm »
don't mean to take the pee but you did check it whilst the car was level and the engine cold?
Offline Syrag64
Re: Oil question
« Reply #8 on: July 08, 2012, 09:24:02 pm »
I was told to run the engine  then turn off leave 10mins then check oil, i'm wondering if i've been doing it wrong all this time?  :ashamed:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
  • -Receive: 427
Re: Oil question
« Reply #9 on: July 08, 2012, 09:38:46 pm »
I check it when cold as that's what I've been taught but saying that many peeps do run the car, turn off engine, wait 15 mins then check the oil level (thinking its a more accurate reading when it's been hot and then settled)
Offline gigolo456
Re: Oil question
« Reply #10 on: July 09, 2012, 11:19:48 am »
I checked when the car was completely cold, and the surface is as level as my head, lol!! Maybe i should check when cold for only about 15 min!?
