Author Topic: Some opinions please - technical  (Read 1595 times)
Offline johnhol78
« on: July 09, 2012, 05:14:18 pm »
This is the log I did of a power run after replacing the Fuel Pump O ring and new cam follower.
Is the Requested and Actual pressure ok on the fuel pump - is the small difference ok?
Any opinions would be great.
« Last Edit: July 09, 2012, 05:16:11 pm by johnhol78 »
Offline johnhol78
Re: Some opinions please - technical
« Reply #1 on: July 09, 2012, 05:17:10 pm »
Map maybe in adaptation after removing battery for 2 days. If that makes ANY difference  :ashamed:
« Reply #2 on: July 09, 2012, 08:45:40 pm »
You are meeting and exceeding your requested rail pressure so IMO you should be good.
Offline johnhol78
« Reply #3 on: July 09, 2012, 09:20:50 pm »
Thanks.....found my air filter hose is not attached to the intake on the front.....great - something else to fix.
Might help answer why my max intake air mass is only 177 (especially as 177 = 221 bhp  - according to thread on here)
« Reply #4 on: July 09, 2012, 09:23:10 pm »
Just remind me whose map and what stage you're using...
Offline johnhol78
« Reply #5 on: July 09, 2012, 09:34:29 pm »
Viezu - Map custom to my mods - Blueflame TBE 200 Cel - Autotech internals. Standard intake
« Reply #6 on: July 09, 2012, 09:39:20 pm »
Could well be the map itself that's limiting your power as you should be able to have stage 2/2+ mapping with your hardware. From your logs, the map isn't fully utilising the capabilities of your uprated hpfp.
Any boost and timing pull logs to hand?
« Last Edit: July 09, 2012, 09:41:54 pm by bacillus »
Offline johnhol78
« Reply #7 on: July 09, 2012, 09:41:31 pm »
Nope.....will do them over the next day or two. Will post up as soon as i can - thanks for the help
Offline Statller-Stevo
« Reply #8 on: July 09, 2012, 10:59:08 pm »
Id say This isn't tuned correctly for the hardware fitted?
Assuming the cars healthy You really should be hitting higher numbers here
I don't think Viezu do the HORP files for the TFSi's  (do they??)
Just trying to help out :happy2:
Offline PDT
  • -Receive: 142
« Reply #9 on: July 10, 2012, 12:24:58 am »
Block 115 and 114 would be good to see.
Offline johnhol78
« Reply #10 on: July 10, 2012, 08:30:28 am »
HORP Files???
PDT - Will do these at the weekend.  :happy2:
« Reply #11 on: July 11, 2012, 07:34:50 am »
HORP files ??
(High output rail pump)
What I meant is the car isn't tuned for a high pressure fuel pump,
If you look the fuel demand is stock but you have an Autotech fitted, that's what you slightly exceed demand just a tad
The software you have isn't tuned for your hardware at this stage.
It won't hurt anything like this, but you've wasted money on a H.P pump if your not utilising it
Maybe your tuner can do this for you now ??  :happy2:
« Last Edit: July 11, 2012, 07:36:42 am by Statller-Stevo »
