Author Topic: got my golf gti today but have trouble already  (Read 1876 times)
Offline gaz7331
« on: July 09, 2012, 10:50:01 pm »
today i bought an 06 golf gti with 68k on. It had an airbag fault which i was aware of but after driving to the shops this evening the eml light came on and has stayed on solid now. I have noticed a little bit of black smoke if you rev it hard. I cant comment if the engine sounds like its misfiring because i dont know whats normal with these but i did notice that on a receipt for the cambelt that was changed in feb it said engine light reset for free which makes me wonder.
Anyone got any advice??
Re: got my golf gti today but have trouble already
« Reply #1 on: July 09, 2012, 10:59:11 pm »
Ask a friendly forum member near to you to scan your car.
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Offline gaz7331
« Reply #2 on: July 09, 2012, 11:01:12 pm »
i work at a car sales place so was going to twist one of the mechanics arms to code read it but im not back until wednesday so was trying to get an idea before i go back
Offline lm_gauci
« Reply #3 on: July 10, 2012, 12:30:20 pm »
Scanning it should provide you with all the answers you need. Pretty hard to know otherwise, might be worthwhile popping in to a local VAG specialist and seeing how much they charge to scan it. They'll more than likely know of any common faults and help you out.
Offline Apollo
  • Middlesbrough
« Reply #4 on: July 10, 2012, 12:32:29 pm »
If your anywhere near Gosport I can fault code read it for you and reset if it lets me - Only a standard code reader but i can do it for you.
Offline gaz7331
« Reply #5 on: July 10, 2012, 05:32:17 pm »
thanks for the help guys, got it code read today and it came up with 2 main ones
01089 evap emmision control system incorrect flow so ive had a search and narrowed it down to the things that can cause that.
p1602 power supply terminal 30 so i reckon the last guy disconnected the battery so thats gone now.
had a play turning the passenger airbag switch on and off as that was what was causing the airbag light and that seems ok now.
only thing unaware of is the auto lights and wipers had a fault which i didnt write down but i have noticed if i put the auto lights on they just stay on all the time which matches the fact it chucked a code up but i dont know what could cause that
Offline lm_gauci
« Reply #6 on: July 10, 2012, 08:17:26 pm »
I think the auto lights are meant to stay on all the time when switched into auto.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #7 on: July 11, 2012, 04:39:14 pm »
That's wrong. The lights work from a photocell (I think) which measures the environmental light level. They switch on as required and should not be on constantly.
'07 Red manual
Offline gaz7331
« Reply #8 on: July 11, 2012, 09:06:50 pm »
is the photocell in the same place as the rain sensor or is it two different things?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: July 11, 2012, 10:54:48 pm »
Same place. It's called RLS - Rain Light Sensor.
Stu...
Offline gaz7331
« Reply #10 on: July 12, 2012, 10:40:26 pm »
cheers I'l have a look into changing that
