Author Topic: RS4 coil packs  (Read 8791 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
RS4 coil packs
« on: July 10, 2012, 09:02:27 am »
i've seen a BT build on another forum where the owner is using RS4 coil packs
doing a little googling i've come up with the only difference being the colour (they are red topped) and don't provide any performance benefit according to some RR tests done by APR on another forum
but then another source states that they might increase longevity - and yet ANOTHER source that says the only difference is the colour, and with them being "E" revision coil packs they'll be worse than the coil packs that were issued in the recall ("F" revision)
what are peoples' opinions/experiences?
PLANS: Stage 2+
Offline vRSAlex
  • -Receive: 253
Re: RS4 coil packs
« Reply #1 on: July 10, 2012, 09:32:54 am »
I keep both the 'Red' and the 'Black' coilpacks in stock.  Tried them both in the Skoda and found no difference at all.
They do have a different end number, but the full part number is different.  So the latest TFSi coilpack ends in 'F', but the latest RS4/R8 coilpack ends in 'E'.
Follow AKS tuning on Facebook
Re: RS4 coil packs
« Reply #2 on: July 10, 2012, 12:32:39 pm »
However Red is the fastest colour  :evilgrin:
Offline jimk04
Re: RS4 coil packs
« Reply #3 on: July 10, 2012, 06:25:37 pm »
Red ones worth several horse power when you lift the 'hood' if running no engine cover.
If you never open your bonnet tho they are a waste of monies :P
Only my 10p -  'I know nussing!'
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: RS4 coil packs
« Reply #4 on: July 12, 2012, 02:33:29 pm »
so apart from Okada coils what other options do we have?
PLANS: Stage 2+
Offline bigmig95
  • -Receive: 50
Re: RS4 coil packs
« Reply #5 on: July 12, 2012, 03:16:45 pm »
I was told by a reasonable source that there were higher power output versions (red ones by the way) of these coil over plugs available a few years back that were used in the RS Audi engines.  I subsequently fitted them into a Cosworth YB engine.  Sold it all now so can't quote part numbers.  Anyone heard anything similar ?
Re: RS4 coil packs
« Reply #6 on: July 12, 2012, 06:09:44 pm »
Okada coils going in mine in a week or two. Then to the dyno!
h4rdy
Re: RS4 coil packs
« Reply #7 on: July 14, 2012, 07:37:11 am »
The RS4 coilpacks part number is taken from the 'Special' platinum plated 'RS' computer in the Audi Dealership and are £400 each :signLOL:
Re: RS4 coil packs
« Reply #8 on: July 14, 2012, 10:42:51 am »
Wow, makes the Okada ones look cheap...   :scared:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: RS4 coil packs
« Reply #9 on: July 14, 2012, 01:59:36 pm »
That's just daft. PSI Tuning sell a set of 4 for £77
PLANS: Stage 2+
Offline vRSAlex
  • -Receive: 253
Re: RS4 coil packs
« Reply #10 on: July 14, 2012, 07:26:10 pm »
Rs4 coilpacks are the same number as the tfsi packs.  Red ones are generally fitted to the r8 and the 2.0fsi a4 with the alloy block.
h4rdy
Re: RS4 coil packs
« Reply #11 on: July 16, 2012, 04:12:55 pm »
Sorry I was joking. I thought the  :signLOL: was enough :ashamed:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: RS4 coil packs
« Reply #12 on: July 16, 2012, 04:42:33 pm »
cut us some slack. i'm not very bright and Alex spent the weekend on fire.
PLANS: Stage 2+
h4rdy
Re: RS4 coil packs
« Reply #13 on: July 16, 2012, 05:08:06 pm »
Sorry!
I might buy some red ones though!
Look a bit different!
Offline vRSAlex
  • -Receive: 253
Re: RS4 coil packs
« Reply #14 on: July 16, 2012, 09:22:28 pm »
Sorry!
:signLOL:
Got some in stock for ya  :happy2:
