Author Topic: can you fit MFSW and highline steering controller to a car with lowline dash?  (Read 6106 times)
Offline jedi-knight83
  • -Receive: 41
Asking on behalf of a guy who wants to buy my control module. He has a MFSW he has bought and wants my Highline controller but he only has lowline clocks.
Will this work or does he NEED to upgrade the clocks too?
Thanks in advance.
I'm going to send him the link to this thread as well so be nice to a potentially new member.
  • -Receive: 41
anyone?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
why shouldn't you? it's the canbus gateway that needs to be ready for it  :happy2:
Over the top mod list ;o)
  • -Receive: 41
ah so that might need changing? I didnt think that would have an impact
Offline skard
  • -Receive: 245
If he's replacing the SWCM (your controller), then he'll need the MFSW airbag loom too, but I guess he knows this.
I'm pretty sure a member on another forum had a lowline with MFSW - problem being he couldn't change track with the MFSW, but that was with an RCD300, and I'm sure it worked otherwise.
He will definitely benefit from a cluster upgrade, even to midline, as he will now have trip functions available with a highline SWCM.
Where is he and what's the age/details of his car? I have my diesel midline clocks going and I could fit them if he was in the NE. Others on the forum could do the same I'm sure if more local to him.
Certainly to get the most out of the whole setup, it's best having at least midline clocks.
Offline mvb12
  • -Receive: 64
I have Midline clocks up for grabs from my 07 plate GTI PM if interested  :popcornsoda:
Offline vitalijus
Hi, i have jetta '06 tdi dsg, lowline no extras..
Is it worth to do MFSW + full disp cluster retrofit on lowline or its just to much hassle?
Offline vitalijus
I'm in barking - northampton
vw55raz
Full or at least midline is Definetely worth it with a mfa+ wiper stalk.
If you're going to get a satnav then highline cluster is definitely worth it.
Offline vitalijus
After MFSW retrofit is done would i be able to change tracks or adjust volume on rns mfd sat nav?
Offline vitalijus
What difference is between full and midline display?
Didnt understand what 'mfa+' means
Offline skard
  • -Receive: 245
This is my midline cluster
Looks like lowline but has trip computer etc. Are you sure this isn't what you already have?
This is an old pic of my highline cluster - note the full size screen.
MFA+ stalk is a wiper stalk with a rocker switch to let you switch through trip functions.
  • -Receive: 41
ah ha.. you signed up :)
Offline vitalijus
Thats the one i have then..
Looks like my vw its not such a lowline:)
Offline skard
  • -Receive: 245
Well that is good news.
Check this for some info http://uk-mkivs.net/forums/p/280194/2444758.aspx - seems like you will need highline to get full use of the audio buttons.
I put my cluster in days before my MFSW so can't help you with that one sorry.
Ps. this is lowline courtesy of a search on the same site
http://i197.photobucket.com/albums/aa227/bpat832002/IMG_0126.jpg?t=1265829685
