Author Topic: ITG maxogen whistle  (Read 23931 times)
Offline GarethB
Re: ITG maxogen whistle
« Reply #30 on: July 11, 2012, 05:30:28 pm »
Just spoken to Andy@itg again and either i'm going to his or he is coming to meet me at R-Tech on the 24th (I need to clear this with Nick first) to listen to the noise on the dyno.
He says they have had a handfull of noises like this out of the hundreds of kO3 kits they have sold and never any on the KO4 kits.
Glad to hear that ITG are prepared to look into the matter and not shy away. I'm really tempted to come join you at R-Tech as further evidence of the noise.
Offline jedi-knight83
  • -Receive: 41
« Reply #31 on: July 11, 2012, 05:41:30 pm »
perhaps its worth emailing andy at ITG so he is aware of the problem. At present he said he is only aware of a handful of whistles but I think its a bigger problem than he knows about.
Offline bigmig95
  • -Receive: 50
« Reply #32 on: July 11, 2012, 05:54:47 pm »
Mine does it too.  Kind of glossed over it really and never thought to much of it.  Noise  increases with more aggressive maps on the SPS select switch all from around 3500 rpm.  Had Revo tweek my map today and no problems with engine meeting boost levels as you might expect from a damaged DV.
  • -Receive: 41
« Reply #33 on: July 11, 2012, 06:20:10 pm »
another one... not such a rare issue then.
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #34 on: July 11, 2012, 08:07:17 pm »
I had my head in a TFSI k03 today trying to see what it could be,  It could be related to the breather pipe from the cam cover to the turbo, or linked to the bleed off side of the n75 both of which are on the inlet side of the turbo.    Only way to find out is plnk them off and do some test runs.
01455 617233
  • -Receive: 41
« Reply #35 on: July 11, 2012, 08:17:21 pm »
cool well im still going to try the twintake on my car as well to see if that makes the noise.
Unrelated... sort of.. but my mpg is still terrible since fitting this (and no not because i've been driving like a mad man everywhere  :P) Just went for a very gentle drive and was under 23mpg again
Offline badbwoy27
« Reply #36 on: July 12, 2012, 05:40:52 am »
Got an open cone itg and don't get this noise at all. Have never heard it once for that matter since fitting it. :smiley:
  • -Receive: 41
« Reply #37 on: July 12, 2012, 09:57:12 am »
are you KO3 or KO4?
Offline badbwoy27
« Reply #38 on: July 12, 2012, 10:55:33 am »
Ko3 stage 1
Offline jamiek1065
« Reply #39 on: July 12, 2012, 11:04:20 am »
I also have an ITG Maxogen Stage 1 K03 and it makes the exact same noise!
Offline badbwoy27
« Reply #40 on: July 12, 2012, 11:16:23 am »
I must be just 1 of the lucky few then. :laugh:
  • -Receive: 41
« Reply #41 on: July 12, 2012, 06:31:45 pm »
So thats the following that have the whistle:
jedi-knight - MK5 stage 1 KO3 - ITG
mkviken - MK6 stage 1 - ITG
gigolo456 - MK5 KO3 - Twintake?
GarethB - MK5 KO3 - ITG
JMP - MK5 KO3 - ITG
bigmig95 - MK5 stage 1 KO3 - ITG new cannister arrangement.
jamiek1065 - stage 1 KO3 - ITG
« Last Edit: July 13, 2012, 10:32:24 am by jedi-knight83 »
Offline mkviken
« Reply #42 on: July 12, 2012, 06:58:33 pm »
mine is a mk6 gti stage 1
on standard map the whistle was barely noticeable. on stage 1 its very loud like the videos
  • -Receive: 41
« Reply #43 on: July 12, 2012, 07:03:36 pm »
this is interesting / slightly annoying.
I take it your mk6 intake is the enclosed canister that attaches to the oem pipework that then runs along the back of the engine to the turbo.
So this disproves my theory that its the metal piping vibrating as yours doesnt have the same set up?
Offline 56OctyVRS
  • -Receive: 72
« Reply #44 on: July 12, 2012, 07:21:09 pm »
My K&N Typhoon intake did this as well.  I think it is to do wth the design of the turbo and the position of the DV and how the diverted air is fed back into the intake.  The K04 DV feeds the air back into the intake from a different position than on the K03 and I think the noise is the air being pulled over where the diverted air is reintroduced into the intake side again and whistling. Well thats my theory anyway :rolleye:
