Author Topic: Rs4 brake setup  (Read 2611 times)
Offline plush-automotive
Rs4 brake setup
« on: May 27, 2009, 11:17:35 pm »
Can anyone shed any light on fitting these, do i need any special adapters if i wasnt to buy the direct kit from amd is it, and buy the parts from audi as in the discs and calipers, what else would i need to make these fir or is a bolt on part.
Any help fitting pictures etc would be great.
Re: Rs4 brake setup
« Reply #1 on: May 28, 2009, 05:10:43 pm »
First off you need to make sure they will fit behind your new rims as the RS4 kit is about the size of a  smart car.
You may need some wheel spacers.  :smiley:
You will need something like this to stop your car with the sound system and the bags.  :laugh:
Re: Rs4 brake setup
« Reply #2 on: May 28, 2009, 06:12:25 pm »
Ha ha cheers mate yeh i'm cool with putting the spacers on and sorting the stance out after i've read they will clear 18s i just wondered if it was as simple as buying the calipers and discs and bolting them straight on the car or wheather i need custom brackets etc.
need some big stoppers in my life though :laugh: :laugh:
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: Rs4 brake setup
« Reply #3 on: June 06, 2009, 09:19:56 am »
Maybe consider using the RS6 Discs instead of the RS4 two piece discs, they are about 12mm taller, they are not two piece in the strictest sense but share the semi floating design from the R8. They are lighter than the B7 disc and mean you dont need as big a spacer. You cant buy replacement rotors for the RS4 ones so not much point in going for those in aneconomic sense.
You need roughly a 2mm shim to centralise the caliper on the disc
Offline mYGeL
    • my Build Thread check it out
Re: Rs4 brake setup
« Reply #4 on: November 21, 2010, 04:23:46 pm »
borrowing the thread I hope it is ok?
Does anyone know where to buy a set of brackets to hold the RS6/brembo 8piston caliper to the car?
Or if someone has a drawing so can get them fabricated?
how many mm shims behind the RS6 disc will be needed exactly?
Appreciate if someone can help me with these questions? :)
Best regards// Michel D. Sweden.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Rs4 brake setup
« Reply #5 on: November 21, 2010, 04:28:15 pm »
talk to DaveB1970 he has sold a couple of these braklesetup. And loved your car at Streetfire  :happy2:
Over the top mod list ;o)
Offline mYGeL
Re: Rs4 brake setup
« Reply #6 on: November 21, 2010, 06:25:40 pm »
Thanks for the Tip mailed him.
I hope he can help me  :smiley:
Thanks :D you car wan really nice also!  :happy2:
Offline mYGeL
Re: Rs4 brake setup
« Reply #7 on: January 09, 2011, 03:04:34 pm »
I mailed 2 times but haven't got any answers :(
Do somebody know any body else that can help me?
I also want to pwdercoat them and the rears white.
Any tip of anybody that can do this?
The var that i will mont them on
http://www.seatcupra.net/forums/showthread.php?t=283972
