Author Topic: Cruise Control Coding Clarification  (Read 4591 times)
Offline tkboyle
« on: July 11, 2012, 06:42:54 pm »
Hi,
Just had cruise control fitted and coded to a MY07 ED30.
It appears to have been coded and is registering commands as seen in vcds although it's not activating on the road.
The car has MFSW and Highline and is a manual.
Would like if possible for someone to post the coding if they have the same spec.
The stalk is the newer Mk6 one (1K0 953 513 G)
cheers
Offline Matto
  • -Receive: 116
Re: Cruise Control Coding Clarification
« Reply #1 on: July 11, 2012, 06:48:12 pm »
Did you code both the steering controller and the engine?
Offline tkboyle
« Reply #2 on: July 11, 2012, 07:31:02 pm »
Yep it's been coded.
Steering Wheel Module
Code: [Select]
                Address 16: Steering wheel       Labels: 1K0-953-549-MY8.lbl
Control Module Part Number: 1K0 953 549 BD    HW: 1K0 953 549 BD
  Component and/or Version: J0527           638 0070
           Software Coding: 0002022
            Work Shop Code: WSC 12345 123 12345
           Additional Info: XXXXXXXXXXX E0221           002 0010
           Additional Info: Geraet 12345
                      VCID: 75E5E5E76701
No fault code found.
Engine Module
Code: [Select]
040300031807 01 60
I'm not sure if the values represented in the steering module are correct.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #3 on: July 11, 2012, 08:17:14 pm »
Does your steering controller support cruise??
Offline jedi-knight83
  • -Receive: 41
« Reply #4 on: July 11, 2012, 08:37:00 pm »
did you check that the plug on the back of the control module had the diagnostic wire?
pin 13?
Offline tkboyle
« Reply #5 on: July 11, 2012, 08:45:20 pm »
Yes it does its the highline variant.
Code: [Select]
Control Module Part Number Slip Ring Software Level Variant Steering Angle Sensor LIN Version Notes
1K0-953-549-BD         Type 2      SW 0070              Highline                 Yes                         1.3                  #2
#2: Manual Transmission only, does NOT support Ignition Key Lock.
Offline tkboyle
« Reply #6 on: July 11, 2012, 08:45:52 pm »
pin 13?
Is this the black and white wire? if so its there already.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: July 11, 2012, 10:51:32 pm »
Do you have any fault codes?
Was the stalk new?
Stu...
Offline tkboyle
« Reply #8 on: July 12, 2012, 12:16:34 am »
Was the stalk new?
No faults. The stalk is brand new from VW.
Offline tkboyle
« Reply #9 on: July 12, 2012, 08:22:30 am »
Think I might have found my answer.
Just a Note for others
ANY controller with 638 0070  HW and SW will not allow cruise to be fitted
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: July 12, 2012, 05:03:01 pm »
Hi
as I posted earlier any controller with 638 0070 will not work
all other version are ok
You will need to change it any of the following
BK BP BD AK AQ CH
Cluster and Key coding
Location Great Yarmouth
Offline tkboyle
« Reply #11 on: July 12, 2012, 05:29:49 pm »
Oh. I have a BD
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: July 12, 2012, 05:34:06 pm »
Oh. I have a BD
yes you have a BD with the wrong HW / SW
there are other BD controllers with different HW / SW just make sure whatever you buy doesn't have 638 0070 on the label
Offline tkboyle
« Reply #13 on: July 12, 2012, 05:36:28 pm »
Can you supply these Eddie?
If so can you PM me.
Offline ashley
« Reply #14 on: July 12, 2012, 06:03:45 pm »
Presuming you have sat at a steady speed over 30mph to activate. Controls do nothing stationary, Sounds stupid but a friend was expecting the light to come on once fiited/coded.
