Author Topic: Cruise Control Coding Clarification  (Read 4588 times)
Offline tkboyle
Re: Cruise Control Coding Clarification
« Reply #15 on: July 12, 2012, 06:17:53 pm »
I did manage to get to 88mph. Only then did it switched on. Once activated I then found myself driving in 1955.
Offline jedi-knight83
  • -Receive: 41
« Reply #16 on: July 12, 2012, 07:19:41 pm »
Oh. I have a BD
yes you have a BD with the wrong HW / SW
there are other BD controllers with different HW / SW just make sure whatever you buy doesn't have 638 0070 on the label
where on the label will this code be? is it part of the part number? pic would be awesome.
will just be helpful for the future when asking friends to check there controller to see if its cruise compatible.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #17 on: July 12, 2012, 08:33:37 pm »
Would one of these go straight on an 08 car with just the coding needing doing?.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #18 on: July 12, 2012, 08:37:58 pm »
Depends what Steering Wheel Controller and slip ring You have Mate.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #19 on: July 12, 2012, 08:40:59 pm »
..........i guess?.Just wondered if being a later car it would have the correct slip ring?.
  • -Receive: 41
« Reply #20 on: July 12, 2012, 08:54:54 pm »
slip ring depends on the control module.
