Author Topic: 2008 Golf GTI Ed30 - Sluggish in low revs, very (very!) low MPG  (Read 16498 times)
Offline Statller-Stevo
Re: 2008 Golf GTI Ed30 - Sluggish in low revs, very (very!) low MPG
« Reply #15 on: July 19, 2012, 10:53:07 pm »
Did you have the cam belt changed... if so It sounds like they have got the cam timing wrong !!! it seems to happen quite a lot...
Would a cambelt timing being out cause any damage other than just poor performance?
As long as the fool who's done the job gets it no more than a few teeth out it won't hurt,  just causes the exact symptoms described
A 2.0 Tfsi belt is a doddle to fit, I really can't believe how many are fitted wrong :confused:
Offline JpowerGTi
« Reply #16 on: July 20, 2012, 01:04:03 pm »
All the advice is brilliant lads I really appreciate it!
Offline SyntaxTerror
« Reply #17 on: July 21, 2012, 06:22:05 pm »
UPDATE :smiley:
You lot are awesome. Thanks again for the great info.
So, this week the car went into TuningWerkes, and Reuben and his team worked through the problems i described above. The service these guys provide is top notch, the level of knowledge Reuben and his team have is seriously impressive!
Results: She is now back to her normal self! MPG is back on par and we even dropped in the APR re-flash (although drove it on standard mapping for a good while to test it out)
What changed:
1. Plugs had seen better days, swapped out with NGK Iridium
2. PCV replaced
3. And as you all thought, Cam belt was 1 knotch out!!
Before:
After:
So, i'm going to have a bit of a moan at the original dealer to see if they can re-fund some of the initial cost... i'll let you know how that goes!
Thanks guys, and huge credit to TuningWerkes who i'll definitely be going back to in future.
« Last Edit: July 21, 2012, 06:23:50 pm by SyntaxTerror »
2008 Ed30 - VWR Cold-Air Intake - APR Stage 2 - Helix 'fast road' Clutch & SMF - H&R Coilovers - Pipewerx Downpipe - Whiteline Anti-Lift Kit - R888's - Dogbone insert - GFB DV+
  • -Receive: 453
« Reply #18 on: July 21, 2012, 06:57:28 pm »
Great result...   :happy2:
Offline mad_pete
« Reply #19 on: July 21, 2012, 10:31:14 pm »
Nice.  So scary that this can get messed up.  Surely check and re-check on little white marks lining up is easy enough.
Offline werkes
    • Tuningwerkes
« Reply #20 on: July 24, 2012, 10:21:16 am »
UPDATE :smiley:
What changed:
2. PCV replaced
Before:
After:
Hi mate,
Thanks for the review of our work and positive comments!
It's good to know your car is back to where it should be and you have the bonus option of the APR software now too!
Look forward to seeing you again sometime!
Regards
Reuben
Edition 30 APR Stage 1::H&R Coilovers::BBS CH
LCR 1.8T APR Stage 2+
KW Weitec H&R & Milltek Offers & Free Shipping available
www.tuningwerkes.com
Authorised APR Distributors and VW Racing Dealers --->secure online shopping at www.aprtuned.co.uk
Saintsteve
« Reply #21 on: July 24, 2012, 10:27:16 am »
 :congrats: :congrats: to the guys for diagnosing this  :happy2:
DSG-GTI
« Reply #22 on: July 29, 2012, 09:21:54 am »
Good to hear you got it sorted bud... What is it with cam belts that people cant get right   :scared:
Offline alackofspeed
  • -Receive: 24
« Reply #23 on: July 30, 2012, 11:14:17 pm »
Gotta wonder about the mechanics "fitting" these cambelts, as anyone who has ever fitted one will know that fitting the belt is really very easy :stupid:. The annoying part is gaining access.
Offline Scrubadub
  • Soon to be "bagged"
« Reply #24 on: August 05, 2012, 06:17:20 pm »
If its only 1 tooth out it shouldnt cause any major damage, but im also betting this is whats wrong
Fun bags
Offline GS WAX
« Reply #25 on: September 02, 2012, 08:10:00 am »
 Glad you have it sorted, This topic inspired me as I had the same symptoms with my ED30.Changed PCV,DV and plugs,slight improvement but not quite "how it was" ,then changed DV to the G revision from the MK6 D rev and what a difference,all is purdy again.
