Author Topic: Bought an RCD510 Now what!  (Read 2514 times)
Offline jamiek1065
« on: July 12, 2012, 10:39:15 am »
Hi everyone,
bought myself an RCD510, I have a MK5 GTi I've read on here I will need a new CANBUS gateway? Where can I get one of these from and can I fit it myself or will it need to be coded?
Jamie
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: Bought an RCD510 Now what!
« Reply #1 on: July 12, 2012, 11:52:25 am »
Depends on what year the car is. If it's a 2007MY or later you could be OK.
Offline jamiek1065
« Reply #2 on: July 12, 2012, 11:58:30 am »
I'm 2005 mate.
Offline simonp
  • -Receive: 38
« Reply #3 on: July 12, 2012, 12:01:19 pm »
Probably will require an upgrade then. As for coding, the gateway needs doing, but the radio is a straight swap. Good luck with the swap, I've heard it's a right pig to do! :confused:
Offline jamiek1065
« Reply #4 on: July 12, 2012, 12:17:04 pm »
The swap actually looks fairly easy once you know how! I'm just worried about fitting it and coming out to a dead battery lol.
Offline Kalpsn2000
  • -Receive: 56
« Reply #5 on: July 12, 2012, 02:09:46 pm »
Yes the HU swap is pretty straight forward. The CANBUS swap is a bit more tricky. Changed mine when I got my RNS510 but I was just watching.
It needs to be swaped over and coded with VCDS. Maybe check if there a forum member near you who is will to help you swap/code.
P.S. I got my CANBUS gateway from ebay.de (half the price comapred to the stealers) but cant find the link right now.
« Last Edit: July 12, 2012, 02:11:23 pm by Kalpsn2000 »
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #6 on: July 12, 2012, 06:55:37 pm »
Hi
As mentioned by Kalpsn2000 the new Canbus need to be coded to the specific car. I have one of them so PM me if interested.
Alex
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline wacky
  • -Given: 56
« Reply #7 on: August 02, 2012, 08:56:52 am »
whats the MY bit stand for ? is that the reg number or VIN ?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #8 on: August 02, 2012, 09:27:10 am »
MY - Model Year
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: August 02, 2012, 10:01:32 am »
will depend on MY
late 2007 cars are ok
if you need one I have new one
http://www.mk5golfgti.co.uk/forum/index.php/topic,40034.0.html
Cluster and Key coding
Location Great Yarmouth
Offline david25
  • -Given: 19
« Reply #10 on: August 02, 2012, 06:10:31 pm »
This page has pics, see about 2/3 the way down;
http://www.golfgtiforum.co.uk/index.php?topic=40928.0
