Author Topic: DSG launch control question  (Read 1259 times)
Offline Robo
« on: July 13, 2012, 04:12:02 pm »
Since having Revo stage 2 engine software and Revo stage 1 DSG software I have not used launch control however Wednesday night I decided to have a play with it and some mates were there and the girlfriend videoed it. After the first run I noticed it left 2 tyre marks obviously spinning both wheels I thought this would not happen with a standard diff? Bit confused really I did 2 runs and both showed both wheels spinning
Any ideas? A friend said it could be flicking from wheel to wheel but there were no breaks in the tyre marks :/
Offline edd666999
  • -Receive: 89
Re: DSG launch control question
« Reply #1 on: July 13, 2012, 04:53:07 pm »
On the quiet REVO fitted a LSD?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=l26ku5vuv2mluk1f27lcraa3pc&/topic,19740.0.html
« Reply #2 on: July 13, 2012, 05:08:38 pm »
ESP off.... Both wheels will spin at the same time unless wheels are on different surfaces.
Offline Robo
« Reply #3 on: July 13, 2012, 05:12:06 pm »
I wish Revo had fitted the diff lol
So at Santa pod or similar u wouldn't need an LSD to set off nicely then only advantage been on track?
Offline Ellis
« Reply #4 on: July 13, 2012, 07:56:06 pm »
I thought the DSG had an electronic LSD element within the DSG gearbox, or is that the MK6?
Ellis.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: July 13, 2012, 09:04:02 pm »
only Mk6s have an electronic diff (but DSG and manuals both have it)
PLANS: Stage 2+
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #6 on: July 13, 2012, 09:44:08 pm »
XDS (Elec diff) still doesn't stop the wheels spinning.
I've tried it once in my Octy which has the XDS Diff and the wheels still spun. Unless you get some super soft slicks, a proper mechanical diff and a grippy track surface you will get a better launch short shifting into 2nd
Offline RENNTAG
  • Premium Performance Parts
« Reply #7 on: July 15, 2012, 03:39:58 pm »
As long as both wheels have the same level o grip they will behave the same. Its when one wheel looses traction a LSD helps.
