Author Topic: Auto electrician in Yorkshire area???  (Read 2713 times)
« on: May 28, 2009, 07:51:16 pm »
Removed the power supply to the light in my boost gauge (was trying to eliminate the cause of a burning smell   :confused:)
It was piggy backed on my ciggetette lighter power supply from the fuse box and i accidentally snipped the wire to cig lighter (which i need to power my sat nav on sunday on drive through europe)
Cig lighter needs reconnecting to fuse box....
Helllllllllllllllp  :sad:
Re: Auto electrician in Yorkshire area???
« Reply #1 on: May 28, 2009, 10:54:50 pm »
It should just be a matter of stripping back the wire and simply put in a 4 point connector Mike. Have you snipped it at a really awkward spot or is there plenty of wire either side of the cut?
« Reply #2 on: May 29, 2009, 09:24:28 am »
It reaches the back of the fuse box with 10mm of wire bared.  it goes into a single square on the back of the fuse box, not sure if it gets soldered in as bare wire or uses a bullet connector or something.
