Author Topic: Missfire/spluttering at low rpm or idle  (Read 3487 times)
Offline greygti
« on: July 13, 2012, 10:40:51 pm »
It's a 08 GTI with a 3'' jetex TBE ,K+N intake and a rtech remap ,replaced plugs 4000 miles ago(oem plugs) and diverter and PCV  were replaced 1000 miles ago,getting a spluttering/miss at idle and up to 1500 rpm but ONLY when the engine is hot it started to happen today ,no ecu/fault lights . any ideas guy's ??
« Last Edit: July 13, 2012, 10:49:55 pm by greygti »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Missfire/spluttering at low rpm or idle
« Reply #1 on: July 13, 2012, 11:08:08 pm »
If it's doing it at idle I'd suggest coilpacks!
« Reply #2 on: July 14, 2012, 10:35:55 am »
This but I'd do a vcds log scan for misfires before fiddling with changing coilpacks...
Offline greygti
« Reply #3 on: July 15, 2012, 10:30:26 am »
Done that yesterday and nothing showed up,cleaned and checked the plug gaps,i'm hoping it's just a faulty coilpack
« Reply #4 on: July 15, 2012, 08:20:05 pm »
Did you log misfire count with the engine running or just did a standard fault scan?
AFLConsult
« Reply #5 on: July 16, 2012, 02:37:37 pm »
Sorry a bit off topic, do you still have the UB spacers for sale?
I have an R32 and was running a blueflame cat back and all was
OK but I have fitted a Milltek cat back at the weekend and now the exhaust is fouling on the UB.
Can be contacted on following email
j.killeen@yahoo.co.uk
Thanks,
Offline greygti
« Reply #6 on: July 16, 2012, 09:34:17 pm »
No i just did a standard fault scan with a snap on diagnostic tool ,how do you log a misfire ??
« Reply #7 on: July 17, 2012, 12:00:01 am »
If you use vcds then a live run logging blocks 015 and 016 will show up which cylinder is misfiring. You only get a fault stored if the misfire count exceed a certain value.
Offline greygti
« Reply #8 on: July 17, 2012, 10:23:34 pm »
Cheers mate i'll do that
Offline greygti
« Reply #9 on: July 19, 2012, 10:21:23 pm »
Turned out to be the primary 02 sensor (pre-cat) ,£60.23p later for a bosch 02 sensor from andrew page and the job is a good un   :laugh:
« Reply #10 on: July 19, 2012, 10:47:21 pm »
Glad to hear that it's sorted.   :smiley:
Offline greygti
« Reply #11 on: July 20, 2012, 07:21:07 pm »
Cheers mate  :happy2:
