Author Topic: Spark plugs and fuel filter  (Read 1708 times)
Offline swedishfireball
« on: July 14, 2012, 07:40:40 pm »
Just thinking about changing mine over and seem to recall there was a set of spark plugs everyone posted about while back that were cheap and good quality? Cannot for the life of me find the thread though. I know this is vague so apologies but hope someone can help!
Also, as a side note.. I'm going to swap the fuel filter but would I be best off buying it directly from VW or could I use someone like GSF for a copy part?
Offline Apollo
  • Middlesbrough
Re: Spark plugs and fuel filter
« Reply #2 on: July 14, 2012, 07:50:42 pm »
Could this be the thread?
http://www.mk5golfgti.co.uk/forum/index.php/topic,38720.0.html
  • -Receive: 427
« Reply #3 on: July 14, 2012, 08:05:50 pm »
Fuel filter is only £20 ish from VW, so no biggie!!
« Reply #4 on: July 14, 2012, 08:09:55 pm »
This was the one, Thanks :happy2: And thanks to everyone else for the quick replies, jeez you lot are fast :laugh:
The only reason I'd get the filter from GSF is because I can get trade price. Not a massive saving but a saving. Just wondered if anyone knew about any quality issues?
  • -Receive: 427
« Reply #5 on: July 14, 2012, 08:15:28 pm »
Ooh, if you need it, part number for fuel filter is:-
1K0201051K.
« Last Edit: July 14, 2012, 08:57:02 pm by MC71 »
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #6 on: July 14, 2012, 08:39:54 pm »
1K0201051C
Latest one from VAG is 1K0201051K
I think this is fairly 'hot off the presses'. Has a 6.6 bar pressure regulator, the older has 6.4 bar.
'07 Red manual
  • -Receive: 427
« Reply #7 on: July 14, 2012, 08:56:07 pm »
^^^^ oh, your having a laugh, have only just had mine changed recentley with the 6.4 bar C revision, back to VW then for the K one.
Thanks for correcting me though, will change my previous post, as not to confuse anyone!
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #8 on: July 14, 2012, 09:11:10 pm »
I don't think you should waste your time! 0.2 bar isn't much - the C has worked fine - never heard of any failures/recalls.
'07 Red manual
  • -Receive: 427
« Reply #9 on: July 14, 2012, 10:29:28 pm »
^^^^ cheers bud, your right, not much point when you think about it.  :signLOL:
