Author Topic: Pirelli GTI Update  (Read 58368 times)
Offline Pirelli Paul
  • -Given: 64
Pirelli GTI Update
« on: July 15, 2012, 05:19:04 am »
Was back in the UK recently and had some work carried out on the Pirelli, eventually got around to the performance parts and was very happy with the results :driver:. Unfortunatly the Brembo BBK arrived after I returned to Hong Kong so they will get fitted on the next trip back.
I list below the modifications to date and some pictures of the car and works (Note: some of the items were fitted after the pictures were taken).
VW Pirelli GTI MK5 (2009 model with just over 17,000 miles)
Cosmetic
Forge Alloy Covers for VAG 2.0 Oil + Water Caps
OSIR - Boot GT - Black Stitching
OSIR - SPM GT - Manual - Gloss Carbon
OSIR - O-Rest GT
OSIR - Orbit Knob - LED Kit - Blue
OSIR - Orbit Illuminated Gear Knob (Stainless)
OSIR - Zero Square V2-Set A-Silver/Dark Chrome Key Covers
MK5 GTI Jacking Point Bungs
VW MK6 GTI LED Number Plate bulbs
2 x VW Emblem Key fobs
Neuspeed 2.0T Carbon Fiber Half Engine Cover
MK5 Pirelli GTI Mats
ECS Billet Aluminum Climatronic Rings
Osir mono vent pod
Forge Charcoal Canister Cover
Performance/Engine
Revo serial port switch
Forge Silicone Hose For The Carbon Filter
Forge DV to Intake return Hose
Forge Silicone Throttle body hose
Forge oil catch tank system
ITG Maxogen Induction Kit
ECS Tuning Billet Aluminum Oil Filter Housing Kit
ECS Magnetic Drain Plug
Milltek None Resonated Cat-Back Exhaust System
Milltek Large Bore Downpipe and Hi-Flow Sports Cat
Forge Blow Off Valve kit
Revo stage 2
NGK IRIDIUM IX spark plugs - BKR8EIX
OEM cam follower for the high pressure fuel pump
Pivot XV Boost/Water/Oil Gauge
Oil filter change
Pollen filter change
Engine oil service
Gear box oil service
Air-conditioning service
Handling
Bilstien PSS10 kit
Neuspeed front anti roll bar 25mm
Neuspeed rear anti roll bar 25mm
Neuspeed rear sway bar links
Whiteline anti lift kit
Front wishbone front power flex bush
Whiteline bump - steer adjust kit
Beissbarth 4 wheel alignment
Neuspeed triangulated upper rear strut brace
4 Pirelli P Zero Tire Size 225 40 18 92Y
ECS Subframe Spacer Plates
Neuspeed Torque Arm Insert
Neuspeed Short Shift Kit
42 Draft VW Shifter Bushing Kit
ECS 6-Speed Clutch Bleeder Block (Arrived but pending fitting)
Braking
Tarrox Sport Japan Drilled & Slotted Front & Rear Brake Discs (Pair)
EBC Yellow Stuff Front & Rear Brake Pads (Pair)
Neuspeed Stainless Steel Brake Lines - 4 Line Kit
ATE Super Blue Brake Fluid Service
Brembo Gran Turismo Brake Kit - 4 Piston Kit with 328mm x 28mm, 2 Piece Drilled Discs (Arrived but pending fitting)
Others
Safety Kit
Autoglym Lifeshine
Semi Rigid Loadliner
Osram Nightbreaker PLUS for both main and high beam
Cruise Control
Daytime Running Lights
Next items planed are an upgraded clutch, an LSD and then stage 2+ with an APR fuel pump and twintercooler etc.
Thanks for a great site, I spend many hours in Hong Kong veiwing all your recomendations and comments and planning my next works on the car when back in the UK. All the works are done at Vagtech in Milton Keynes and I highly recomend them.
Cheers Paul
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Pirelli GTI Update
« Reply #1 on: July 15, 2012, 08:46:51 am »
That is frigging awesome!
PLANS: Stage 2+
« Reply #2 on: July 15, 2012, 09:28:47 am »
Just a few mods then :signLOL:
Awesome car
Offline DFish
« Reply #3 on: July 15, 2012, 09:56:45 am »
Nice set of mods on that. :)
Do you think the Neuspeed rear boot brace works?
Fish
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: July 15, 2012, 11:05:00 am »
Fish
now that there's a UK supplier for the UniBrace i'd go for that instead personally. more practical more of the time, neater, designed by an architect and the same price/slightly cheaper.
PLANS: Stage 2+
  • -Given: 64
« Reply #5 on: July 15, 2012, 01:20:14 pm »
Hi DFish
The Neuspeed brace seems to work well, certainly seems to tighten things up at the back when pushed hard and easy to remove with an allen key and comes with a spacer bush if you want to keep the diagonal brace out (A two minute job to remove completely).
Cheers Paul
« Reply #6 on: July 15, 2012, 01:25:17 pm »
Fantastic Spec  :happy2:
« Reply #7 on: July 15, 2012, 02:22:26 pm »
Immense, should go well once the clutch is done!  :wink: :congrats:
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
« Reply #8 on: July 15, 2012, 02:44:05 pm »
Fantastic  :notworthy:
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #9 on: July 15, 2012, 06:05:55 pm »
great car! very rare also!
Paul
Offline CarrG
« Reply #10 on: July 15, 2012, 06:46:46 pm »
Wow.
Thats some parts list  :drool:
Should notice the difference  :party:
K1 Revo 2+
Ibis RS3
Offline DFish
« Reply #11 on: July 15, 2012, 07:25:18 pm »
What settings are you running the PSS10's on the road? I'm asking as I've just had some installed. :)
Fish
Offline Louis.
« Reply #12 on: July 15, 2012, 08:53:46 pm »
 :scared: those seats and the interior are incredible!!! First time I've seen a pirelli edition, love it!!
  • -Given: 64
« Reply #13 on: July 16, 2012, 03:43:00 am »
Fish
Hi Fish
The PSS10's are on setting 7 at the moment which is pretty stiff but it grips very well
Offline TheBIGJAYY
« Reply #14 on: July 16, 2012, 01:46:46 pm »
 :notworthy: :notworthy: :notworthy:
absolutely gorgeous mate! awesome list of mods too! VERY Jealous! haha
Rainford Accounting Services
Tel. 07875505637
Email. jrainfordmaat@gmail.com
