Author Topic: Pirelli GTI Update  (Read 48575 times)
Offline gixerben
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92657.msg930393.html#msg930393
Re: Pirelli GTI Update
« Reply #60 on: June 13, 2014, 08:38:59 pm »
I need those mats dude, where did you purchase?
Pirelli GTI
Offline Pirelli Paul
  • -Given: 64
« Reply #61 on: June 14, 2014, 09:30:34 pm »
Hi Ben
To be honest mate I can't remember the company I used, I remember a member of here had them, and I mailed him for the details of where he got them 2 or 3 years ago and sent the company a picture of his mats and asked them if they could do the same but without the heel pad he had on his (Actually I later brought his set off him as spares when he sold his car). I have just tried to find the site but am not sure which company I used as there are a few on the internet, try somebody like ulitimatcarmats.co.uk and send the picture of my mats to them and see if they can confirm they can do them.
Sorry I can't be of any more help on this issue Ben.
Cheers Paul
« Last Edit: June 14, 2014, 09:53:25 pm by Pirelli Paul »
Offline vwrascal
« Reply #62 on: June 14, 2014, 09:41:09 pm »
Car looks great, especially the mk6 steering wheel, is that custom yellow stitched?  :congrats:
  • -Given: 64
« Reply #63 on: June 14, 2014, 09:47:56 pm »
Hi Ben
To be honest mate I can remember the company I used, I remember a member of here had them, and I mailed him for the details of where he got them 2 or 3 years ago and sent the company a picture of his mats and asked them if they could do the same but without the heel pad he had on his (Actually I later brought his set off him as spares when he sold his car). I have just tried to find the site but am not sure which company I used as there are a few on the internet, try somebody like ulitimatcarmats.co.uk and send the picture of my mats to them and see if they can confirm they can do them.
Cheers Paul
Hi Ben
This was the company who made them:
http://www.autostyle.co.uk/catalog/index.php
Cheers Paul
  • -Given: 64
« Reply #64 on: June 14, 2014, 09:52:48 pm »
Thanks Mate
Yes my MK5 wheel didn't have the audio controls etc. and after I had the new audio installed in the car I had a MK6 wheel with audio controls etc. installed and first had it covered in perforated leather and alcantara and a guy who specialises in covering steering wheels did an awesome job on it with yellow stitching etc.
Cheers Paul
« Last Edit: June 14, 2014, 09:54:37 pm by Pirelli Paul »
Offline gixerben
« Reply #65 on: June 15, 2014, 10:39:52 am »
Hi Ben
Cheers Paul
Hi Ben
Cheers Paul
Thanks Paul, email has been sent to them :happy2:
Pirelli GTI
Offline phatmuther
« Reply #66 on: June 17, 2014, 01:19:07 pm »
Loving this.  :congrats:
Offline Pikey Motorsports
« Reply #67 on: June 17, 2014, 02:26:49 pm »
is that the ultra racing front upper strut brace
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
  • -Given: 64
« Reply #68 on: June 21, 2014, 11:56:54 am »
Yes mate, was an easy fit and bolted straight on after removing a few bits.
Cheers Paul
  • -Given: 64
« Reply #69 on: October 05, 2014, 04:23:36 am »
Got a few things planned for the Pirelli as follows :driver::
New R32 Rear Calipers Painted Red
New R32 Carriers Painted Red
New Rattle Plates
New Fixing Bolts
Front subframe bushes and bolts
Rear subframe bushes and bolts
ECS clutch bleeder block (New model, hope its a better fit that the last one I tried)
034motorsport Billet Dogbone
034motorsport Front Sway Bar End Link
034motorsport Rear Sway Bar End Link
034motorsport Rear Trailing Arm Spherical Bearing Upgrade Kit
034motorsport Rear Upper Adjustable Control Arm
Tarox Race Pads
ECS 310mm x 25mm 2 Piece Discs
Ground Control Adjustable Top Mounts
Beissbarth Geometry Set Up With Front &Rear Camber Of Around 3 Degrees
ECS aluminum underbody protection
TTRS brake & clutch master cylinder
Black Hazard Light Switch
Cheers Paul
Offline TimmyH92
« Reply #70 on: October 05, 2014, 10:15:33 am »
Very impressive and inspirational build
  • -Given: 64
« Reply #71 on: October 05, 2014, 03:48:26 pm »
Thanks Timmy  :happy2:
  • -Given: 64
« Reply #72 on: October 12, 2014, 01:54:11 am »
Updated list of car parts (All are completed apart from 19 of the items that are ready or arranged for when I am next back in the UK)
Current milage around 20,600 miles
1   VW Pirelli 2.0T FSI 230PS GTI MK5
2   Air-conditioning service
3   ECS Magnetic Drain Plug With 10 Copper Washers
4   ECS Tuning Billet Aluminium Oil Filter Housing Kit 2.0T
5   ECS Volkswagen & Audi Jack Pad Adapter
6   Forge 25 - 35mm Stainless Steel hose clips
7   Forge Alloy Intercooler for MK5 Golf
8   Forge Alloy Radiator for MK5 Golf
9   Forge Blow Off Valve kit
10   Forge Charcoal Canister Cover
11   Forge DV to Intake return Hose
12   Forge Hose Clamp set for FMKC010
13   Forge oil catch tank system for 2.0 litre FSi vehicles with a charcoal filter installed
14   Forge Silicone Coolant Hose Kit for VAG 2.0 VW MK5 Golf Edition 30 FMKC010 (Hoses in black)
15   ITG Maxogen Induction Kit for VAG 2.0 VW MK5 Golf Edition 30
16   Milltek Large Bore Downpipe and Hi-Flow Sports Cat
17   Milltek None Resonated Cat-Back Exhaust System
18   Open Air Honeycomb Grille Kit - Pair - Golf Mk5
19   Osir mono vent pod
20   Pivot XV Boost/Water/Oil Gauge
21   Porsche Oil + Water Caps
22   Revo Integrated Throttle Pipe for VW Golf Mk5 2.0T FSI
23   Revo serial port switch
24   Sachs up rated clutch flywheel kit inc single mass flywheel (400 BHP +)
25   Timing belt and water pump change
26   VCDS/VAG-COM Pro-Kit
27   Okada red coil packs
28   Forge Motorsport Heater Matrix Hoses - Golf Mk5 2.0T
29   Forge Motorsport Silicone Carbon Canister Hose Kit
30   Forge valve spring kit
31   Fuel Filter 6.6 Bar
32   G12 Coolant/Antifreeze
33   Gear Box Oil Change - Best Oil Available
34   Heat Shield
35   High Flow Fuel Return Valve
36   Loba TFSI HPFP
37   NGK IRIDIUM IX spark plugs - BKR8EIX
38   OEM cam follower for the high pressure fuel pump
39   Oil Filter
40   Engine Oil Change - Castrol Edge Sport 10w-60 (Plus 20K service & service book stamp)
41   Pollen filter
42   Rad Fan Kit OE
43   Revo stage 2+
44   TTRS fuel pump blank for fwd conversion
45   TTRS in tank fuel pump and seal
46   1 Pirelli P zero Tire Size 225 40 18 92Y (For spare wheel)
47   4 Pirelli P Zero Tire Size 225 40 18 92Y
48   42 Draft VW Shifter Bushing Kit - Mk5 6S MY08-09
49   ATE Super Blue Brake Fluid Service
50   Bilstien PSS10 kit
51   Brembo Gran Turismo Brake Kit - 4 Piston Kit with 328mm x 28mm 2-Piece Drilled Discs
52   Neuspeed 2.0T K04 Hi-Flow Turbo Discharge Kit Part Number: 48.02.70
53   Neuspeed Stainless Steel Brake Lines - 4 Line Kit
54   Neuspeed triangulated upper rear strut brace
55   OSIR - Orbit Illuminated Gear Knob  (Stainless)
56   Osram Nightbreaker PLUS  - H7 499 High Beam
57   Osram Nightbreaker PLUS  - H7 499 Low Beam
58   Powerflex 2 x (PFR85-508) Rear Tie Bar to Chassis Front Bush
59   Powerflex 2 x (PFR85-509) Rear Lower Spring Mount Outer
60   Powerflex 2 x (PFR85-510) Rear Lower Spring Mount Inner
61   Powerflex 2 x (PFR85-511) Rear Lower Link Outer Bush
62   Powerflex 2 x (PFR85-512) Rear Lower Link Inner Bush
63   Powerflex 2 x (PFR85-513) Rear Upper Link Outer Bush
64   Powerflex 2 x (PFR85-514) Rear Upper Link Inner Bush
65   Standard track rod ends
66   Vibra-Technics VAG500M - LH Gearbox mount
67   Vibra-Technics VAG510M - RH Engine Mount
68   Vibra-Technics VAG520M - Torque Link Chassis Bush
69   Volkswagen 02Q Differential Bearing Kit
70   Volkswagen Clutch release bearing 0A5141671F
71   Wavetrac 10.309.175WK LSD differential
72   Wavetrac LSD bolt fitting kit ARP 10.498.02M 02M/02Q
73   SuperPro anti lift kit
74   Whiteline Heavy Duty Steering Rack Bushing
75   UNIbrace UB
76   UNIbrace RB
77   Front upper strut brace
78   Whiteline Rear Sway bar side stop
79   Beissbarth 4 wheel alignment
80   Shifter Bracket Bushings
81   SuperPro Performance Control Arms
82   Whiteline Front Sway bar side stop
83   Neuspeed rear 25mm Sway Bar Clamp/Bushing Kit w/Grease Fitting
84   New R32 Rear Calipers Painted Red   Ready
85   New R32 Carriers Painted Red   Ready
86   New Rattle Plates   Ready
87   New Fixing Bolts    Ready
89   Front subframe bushes and bolts   Ready
90   Rear subframe bushes and bolts   Ready
91   ECS brake bleeder block    Ready
92   034motorsport Billet Dogbone   Ready
93   034motorsport Front Sway Bar End Link   Ready
94   034motorsport Rear Sway Bar End Link   Ready
95   034motorsport Rear Trailing Arm Spherical Bearing Upgrade Kit   Ready
96   034motorsport Rear Upper Adjustable Control Arm   Ready
97   Ground Control Adjustable Top Mounts   Ready
88   TTRS Master Cylinder   Arranged
98   Tarox Race Pads   Arranged
99   ECS 310mm x 25mm 2 Piece Discs    Arranged
100   Beissbarth Geometry Set Up With Front &Rear Camber Of Around 3 Degrees   Arranged
101   2 x 250mm x 250mm Pads Wave Diffuser
102   2 x 250mm x 250mm Pads Wave Diffuser
103   A Pillars construction
104   Alcantara covered MK6 GTI MFSW
105   Alpine INE-W928R Navigation with 8" Screen &
106   Alpine KCU-461iV to connect your iPod or iPhone to  INE-W928R
107   Audison Voce 5.1 = 5 Channel Power Amplifier
108   Audison Voce Quattro = 4 Channel Power Amplifier
109   BEST BFD 21 FUSED DISTRIBUTION BLOCK TWO WAY
110   Best PF 2BK POWERFLOW POWER CABLE (Black Earth)
111   Best PF 2R POWERFLOW POWER CABLE (Red Power)
112   Best PF 4BK POWERFLOW POWER CABLE (Black Earth)
113   Best PF 4R POWERFLOW POWER CABLE (Red Power)
114   CD changer replacement part
115   Cloth Webbed Adhesive Tape
116   Hertz Mille MLK 2TW Car 2 way speaker system
117   Hertz Mille MLK 3PA Car 3 way speaker system
118   Skinz Door Sound Deadening Kit - Bulk (27 sheets)
119   SONUS MP 1/0BL MAIN POWER POWER CABLE (Blue Power)
120   SONUS MP 1/0S MAIN POWER POWER CABLE (Silver Earth)
121   SONUS S 210 SONUS SPEAKER CABLE
122   SONUS SBC 41N NEGATIVE BATTERY CLAMP
123   SONUS SBC 41P POSITIVE BATTERY CLAMP
124   SONUS SFD 41C FUSE, GROUND & DISTRIBUTION BLOCK FOUR WAY
125   SONUS SFH 11WP FUSE HOLDER WATER PROOF
126   SONUS SGT 11 GROUND TERMINAL 1/0AWG (2pcs)
127   SONUS SMC 01B16 MAIN CRIMP D 10,5mm BULK (16pcs)
128   SONUS SMC 02B20 MAIN CRIMP D 8,5mm BULK (20pcs)
129   SONUS SMC 10B50 MAIN CRIMP D 3,5mm BULK (50pcs)
130   SONUS SRT 1/0 RING TER. (2pcs)
131   SONUS SRT 4 RING TER. (2pcs)
132   SONUS SSF 2.5 DGT CAPACITOR 2.5 FARAD W/V-DGT
133   SONUS ST2 550 STEREO RCA CABLE 550cm 3 Sets
134   SONUS SYB 210B Y-BOOT (72pcs)
135   Speaker Adaptors Auto Leads SAK3108 VW
136   Trim Replacement Parts
137   VW Door Panel Clip With Backing Pieces
138   Alpine fitting kit
139   Stereo mounting cage
140   T10 General 194 Wedge 5W5 Bulbs
141   Tire Valve Caps – GTI
142   Volkswagen Motorsport Emblem
143   VW Badge Emblem - Piano Black for Golf V GTI Front Grille
144   VW MK6 GTI LED Number Plate
145   Wheel Bolt
146   Wheel Bolt Covers
147   Wheel Hanger Installation Guide Tool - 14x1.5 Thread
148   1K0054690A Cruise Control - With Multi Function Display
149   1K052431BE Daytime Running Lights - Vehicles With Front Fog Lights
150   2 x Scirocco (Sprung) Pump stops       1K8 827 761 D
151   2 x Seat Leon Ball pins                          1J6 827 439
152   2 x Skoda Fabia Gas Struts                   6Y0 827 550 C
153   2 x VW Emblem Key fob Coloured
154   3M Di-noc Carbon Fibre for rear VW emblem
155   Adapter LED number plate light
156   Airbag trims
157   Aluminium Look Glove Box Handle
158   Belkin Micro Auto Charger USB 1A
159   Blue Snap On seat covers
160   Car cover
161   Change wheel colour with powder coating after striping and blasting including tire fitting balancing and short valve (For spare wheel)
162   Chrome Window Switches
163   Chrome Automatic Headlight Switch
164   Chrome Heated Electric Mirror Switch Without Power Fold Function
165   Door Warning Lights = Pair  for 2 Doors with W5W Bulbs
166   ECS Billet Alu Climatronic Rings Mk5
167   Fuel door chrome switch
168   Full detail & machine polish
169   GTI Keychain 2011
170   Have wheels stripped, blasted and powder coated in another colour
171   Ignition Key Bezel VW = Silver
172   LED Lighting Interior Kit = Colour Hyper White (6000K)
173   LED mirror lights = Pair
174   LED Parking City Lights = Pair (No Error) x 2 Colour 6000k
175   LED Rear/Braking Lights
176   LED Reverse light bulb = NEW Osram Series
177   LED Spares for above Door Warning Lights = Pair  for 2 Doors with New Type LED’s
178   MK5 GTI Jacking Point Bungs
179   MK5 Pirelli GTI Mats
180   Neuspeed 2.0T Carbon Fibre Half Engine Cover
181   OSIR - Boot GT - Black Stitching
182   OSIR - Orbit Knob V3 - LED Kit - Blue
183   OSIR - O-Rest GT
184   OSIR - SPM GT - Manual - Gloss Carbon
185   Pirelli 1 of 222 Plaque
186   Pirelli OEM Wheel 18” x 7.5” ET51 with 5 x 112 cm (For spare wheel)
187   Pirelli Wheel Centre Caps
188   Pirelli Wheel Centre Caps = 4  (As spares)
189   Safety Kit
190   Smoked Mirror Indicator Lenses Pair - Golf Mk5
191   LED Yellow Foot Well Lights = Error Free
192   ECS aluminum underbody protection     Ready
193   Black Hazard Light Switch   Ready
Cheers Paul
« Last Edit: October 12, 2014, 02:02:58 am by Pirelli Paul »
Offline Tal001
« Reply #73 on: October 12, 2014, 06:14:15 am »
Nice ride!
Offline Wayne D
  • -Given: 17
  • MKV GTI Pirelli
« Reply #74 on: October 12, 2014, 09:05:38 pm »
Such an impressive car! Love it! :happy2:
