Author Topic: Oil cap cover came off  (Read 1443 times)
Offline Black9
  • -Given: 35
« on: July 16, 2012, 02:38:09 pm »
Just gave someone a jump start, noticed something odd. The cover for my oil cap has came off. The actual cap is still on and no oil is coming out its just the actual cover :surprised:
Any idea how this may of happened and has anyone else experienced this. The only reason I can see it coming off is my engine cover is a bit loose which may have gradually loosened it over time :fighting:
Thinking of getting an R8 cap now depending how much VW charge for one, some VAG parts seem to be pretty bad build quality :sad1:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Oil cap cover came off
« Reply #1 on: July 16, 2012, 02:46:07 pm »
Could be the upper engine mount and transmission mount are worn, causing excess engine twist,in turn pushing oil cap off?
« Reply #2 on: July 16, 2012, 02:47:17 pm »
You should be able to snap the two halves together providing there's no breakage of clips.
« Reply #3 on: July 16, 2012, 02:54:59 pm »
This happened to me but only with the R8 oil cap. From what I gather, it has to separated and reattached so it is correctly orientated when fitted.
Offline Black9
  • -Given: 35
« Reply #4 on: July 16, 2012, 02:55:37 pm »
Could poss be this. Needs to be checked ASAP
Offline Black9
  • -Given: 35
« Reply #5 on: July 16, 2012, 02:56:10 pm »
U mean to remove and re-fit a new one. I was thinking a set of pliers
Offline Black9
  • -Given: 35
« Reply #6 on: July 16, 2012, 02:57:46 pm »
No idea where the other half of the cap is, must have fell off when i was driving. Think I'll need a set of pliers to remove it or just break it carefully :fighting:
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #7 on: July 16, 2012, 03:02:41 pm »
It's quite easy to do this when removing the engine cover. Has it been in the garage recently?
Offline Black9
  • -Given: 35
« Reply #8 on: July 16, 2012, 03:04:43 pm »
Was in having 4 new tyres and upper mounts. May have been pulled off when mech tried to remove eng cover to check eng mounts :fighting: bit of a waste considering he told me mounts were fine and quite clearly aren't  :signLOL:
