Author Topic: Update RNS-510 Help please!  (Read 2778 times)
Offline Mark_eire
  • Dublin, Ireland
« on: July 16, 2012, 11:51:24 pm »
I've got a 2006 Skoda Octavia vRS with an RNS510/Columbus unit fitted.
I'm planning to upgrade the climate control to the newer FL unit which displays on the RNS screen,
AFAIK, this requires an update of the fw to 2xxx my unit is a version A with fw1004 and v7.2 maps
I don't want to upgrade the CAN gateway so can anybody give me a definitive answer as to which fw I can run without battery drain issues?
I've seen modified fw272x on vwnavi which claims to work but I'm not certain how to download or burn these discs, my computer skills only go as far as forum browsing!
I know there is a tutorial here, but I'm not confident enough in my skills to download and burn the disc correctly!!
If someone can help me by burning the fw I need and posting to me, I'd be prepared to pay whatever to cover the costs and a few pints on top!
Thanks in advance!
Mark
« Last Edit: July 17, 2012, 12:01:35 am by Mark_eire »
2010 Audi A6 Avant S-Line
2007 VW Golf GTI
vw55raz
Re: Update RNS-510 Help please!
« Reply #1 on: July 17, 2012, 12:09:48 am »
Where are you based mate?
I do v8 maps and fw to stop battery drain.
Offline Mark_eire
  • Dublin, Ireland
« Reply #2 on: July 17, 2012, 12:12:18 am »
I'm in Dublin, Ireland! Might try downloading the file and burning it myself but fear I'll brick the unit...
2007 VW Golf GTI
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #3 on: July 17, 2012, 06:10:22 am »
Hi
If you want to upgrade ur climatronic unit than u need upgrade your canbus anyway.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Mark_eire
  • Dublin, Ireland
« Reply #4 on: July 17, 2012, 09:37:30 am »
Hi
Wasn't aware of that! Thanks for your help,
I'll try get a newer can gateway so!!
2007 VW Golf GTI
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #5 on: July 17, 2012, 09:48:34 am »
mark_eire PM send
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: July 17, 2012, 09:00:32 pm »
Hi
you don't need a newer gateway if you want to have climatronic on the screen.
The MK6 panel will work even with an old gateway, the only thing is VAG-Com won't communicate with it.
I fitted a Mk6 panel in VWrascal's car and he has an H gateway
If you want to upgrade the firmware then you may need a gateway depending on what you opt for.
I offer New 7N0 gateways, if you require one
Cluster and Key coding
Location Great Yarmouth
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #7 on: July 17, 2012, 09:18:19 pm »
So how you want to read/clear the fault codes on HVAC if VCDS won't communicate with it?
And also on that post the Canbus is on the needed part list
http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed.&highlight=Climatronic
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: July 17, 2012, 09:25:36 pm »
you can't clear the faults.
VW dealer system VAS can't communicate with a MK6 Climate panel when fitted in a Mk5 regardless of gateway version.
VCDS also requires a different label file too
a lot of threads say you need new 3c8 cecm too, why spend on what you don't need
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #9 on: July 17, 2012, 09:34:37 pm »
Well I have 3C0 CECM in my and it works with MK6 climatronic panel.
Maybe VAS cant but at least VCDS can.
