Author Topic: MIL coming on after cambelt change  (Read 805 times)
Bear
« on: July 17, 2012, 04:12:50 pm »
Had the engine light on twice now after cambelt change 5 weeks ago.
Firstly they replaced PCV Valve, now yesterday they say could be Cam shaft adjuster Valve.
Would you believe this could lie at the cambelt change as a problem. car drives fine
and starts fine.
Offline 56OctyVRS
  • -Receive: 72
Re: MIL coming on after cambelt change
« Reply #1 on: July 18, 2012, 09:23:18 am »
Does the engine run okay as they might have got the timing wrong.
Bear
« Reply #2 on: July 19, 2012, 07:25:02 pm »
Engine runs fine. Doesn't go into limp mode when light comes on.
I'm just asking about the cam belt as others on a internet search have
found this problem
Offline PDT
  • -Receive: 142
« Reply #3 on: July 19, 2012, 07:36:48 pm »
and starts fine.
If the light is on then there will be a fault(s) stored. Post up the fault codes and maybe we can help disgnose the problem  :happy2:
