Author Topic: Are Mk6 Calipers a straight fit on Mk5's?  (Read 2305 times)
Offline ashley
« on: July 20, 2012, 10:56:19 pm »
Hi all,
The Mrs with be the main driver of my Ed30 from Sept. Decided the RS4 brakes are overkill!
Was looking to replace with standard mk5 jobbies but obviously mk6 gti brakes will newer and covered lower miles. Have an option on some locally at a sensible price.
So are the fronts and rears a straight swap?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=4hd4g3bp0mvkefp3k3parph4c7&/topic,19740.0.html
Re: Are Mk6 Calipers a straight fit on Mk5's?
« Reply #1 on: July 20, 2012, 10:57:23 pm »
Yep... same 312mm setup.
Offline ashley
« Reply #2 on: July 20, 2012, 10:59:13 pm »
cheers, realise they are both 312mm on the fronts, just wanted to confirm the mounting points are the same , discs the same offset etc.
Any ideas on the rears?
« Reply #3 on: July 20, 2012, 11:07:02 pm »
Yep all the same... so long as they have come off a mk6 GTI they will fit a MK5 GTI... its the same car essentially.
Offline ashley
« Reply #4 on: July 20, 2012, 11:08:44 pm »
Great thought so, although knowing my luck there was a minor update that would cause probs.
« Reply #5 on: July 20, 2012, 11:12:17 pm »
Nopey...  :laugh:
