Author Topic: Revo Select + for Porsche switch, will it work VAG?  (Read 1651 times)
Offline jammy78
« on: July 22, 2012, 03:17:14 pm »
Hi,
Does anyone know if a Revo Select plus switch for Porsche will work with VAG models, if I put the correct settings on it?
MK2 Leon CUPRA  Revo Stage1 / Sideskirts / Spoiler / Eibach Sportline / RNS 510 / Armrest / Gloss Black Alloys
Offline vRSAlex
  • -Receive: 253
Re: Revo Select + for Porsche switch, will it work VAG?
« Reply #1 on: July 22, 2012, 03:56:58 pm »
Hi,
Should work, but what Porsche do you have?
Follow AKS tuning on Facebook
Offline jammy78
« Reply #2 on: July 22, 2012, 04:20:46 pm »
Hi,
Unfortunately I don't own a Porsche! I just got hold of a Select + switch which has been used with a Porsche! The software disc says
"Select plus Porsche"
Ver: 1.8
If I d/l the VAG software from the revo website, will this be ok?
« Last Edit: July 22, 2012, 04:23:31 pm by jammy78 »
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: July 22, 2012, 04:39:10 pm »
Hi,
Ver: 1.8
Yeah it must just be different software.  Give it a go.
Offline jammy78
« Reply #4 on: July 22, 2012, 05:04:51 pm »
Yep, the switches must be the same?
I d/l the VAG software & connected the switch to the car to "Acquire" the current ECU settings & it came back with:
Boost = 6
Timing = 4
Fuel = 9
So it looks like it works.  I'm not going to mess with the settings just yet, as I'm only Stage 1 at the moment.
I got another question tho.....
With options 1 (Stock), 2 (Performance), 3 & 4 (anti theft) I'm gathering these will be set for the original Porsche.... now can I change these settings or will this need to be done by a Revo installer?
Also is  0 - 0 - 0 = Stock?
Many thanks!
« Reply #5 on: July 22, 2012, 05:23:23 pm »
Boost = 6
Timing = 4
Fuel = 9
If you are using V-Power petrol you should be able to up your timing to 5 or 6. The exact value depends on your CFs when logging with vcds.
