Author Topic: B1 S1 -Too High (Rich) -VCDS Logs embeded - Please help!!!  (Read 4228 times)
Offline Rav2011
« on: July 22, 2012, 07:32:44 pm »
Hi Guys,
I'm currently battling with the following error.
008598 -  P2196 - 004 (B1 S1 Too High(Rich)) - Intermittent
I have a full 100 cell Blueflame exhaust system with a lambda spacer on the post cat sensor. I am stage 2 mapped (AMD Technik).
If I remove the spacer, then I get a DTC about the catalyst system being below efficiency. With the lambda spacer, I intemittently get the
008598 (B1 S1 too rich) error.
I have recently replaced the pre-cat and post-cat sensors and am now lost on this.
Any help would be greatly appreciated.
How do I fix this? Do I try the Draft Design 42 sensor now? The one that I currently have is from PTR Exhausts (Ebay) and has been drilled to 8MM.
« Last Edit: July 24, 2012, 01:05:21 pm by Rav2011 »
Offline Rav2011
Re: B1 S1 -Too High (Rich)
« Reply #1 on: July 24, 2012, 10:10:18 am »
Come on someone must know about this problem or must have encountered the same before at stage 2?
Saintsteve
« Reply #2 on: July 24, 2012, 10:14:05 am »
 Are you getting this with the map uninstalled aswell??
« Last Edit: July 24, 2012, 10:16:11 am by Saintsteve »
Offline Rav2011
« Reply #3 on: July 24, 2012, 10:32:07 am »
Hi SaintSteve,
I did disconnect the MAF sensor yesterday and took the car for a drive, I must admit to you that I did not any notice any difference in the power, it was exactly the same.
If you want the VCDS log (CSV file), whilst driving at 2500 - 3500 RPM (4/5 th gear) I can send this to you as I must admit I am not great in interpretting the readings.
Saintsteve
« Reply #4 on: July 24, 2012, 10:55:46 am »
Can you un-install the remap. Load the original and see if fault appears. If its fine without the map, you need to get in touch with AMD to get them to adjust the remap because that's what it sounds like, if you've done what you say you have already.
Offline Rav2011
« Reply #5 on: July 24, 2012, 11:13:55 am »
I can give it a go but may have to pay out top $$$ to get the map put back on again.
It's all confusing as I have a lambda spacer in place and was told that the map would cancel out the second lambda.
If that was the case then I should not have got the catalyst sytem below efficiency error with the lambd spacer removed, as the second sensor should have been deleted.
With the spacer on (current setup), I get the B1 S1 too rich error.
Saintsteve
« Reply #6 on: July 24, 2012, 11:53:58 am »
If all the sensors are replaced, and if you can remove the spacer, load the stock map , and not a tuners mocked version of it. I'm sure you will hit the nail on the head. i too have same issue with efficiency error which I'm sure is just the remap.Im not overly concerned as it only does it once in a while and not a fault all the time.Mine seems to occur at slow speeds around 25mph
Offline Rav2011
« Reply #7 on: July 24, 2012, 12:26:05 pm »
who did you get your car mapped from?
Saintsteve
« Reply #8 on: July 24, 2012, 12:28:05 pm »
Superchips Bluefin
« Last Edit: July 24, 2012, 12:39:08 pm by Saintsteve »
Offline Rav2011
« Reply #9 on: July 24, 2012, 12:35:18 pm »
I can't say i've heard of them before.
Are you any good at reading through VCDS logs for MAF readings? I am trying to determine if it's worth me replacing the MAF first? I don't really want to remove the remap as I would have to pay another compamny to have it put back on again and it kind of defeats the purpose of going to stage 2.
Let me know if you want me to send the VCDS log for the MAF readings?
Saintsteve
« Reply #10 on: July 24, 2012, 12:37:12 pm »
Post them on here, then others can give input, I only know limited stuff. Others will help if you post logs
Offline Rav2011
« Reply #11 on: July 24, 2012, 12:47:01 pm »
How do you post logs on here? I am not able to attach them.
Saintsteve
« Reply #12 on: July 24, 2012, 12:48:08 pm »
I'm not sure, why not copy paste?
Offline Rav2011
« Reply #13 on: July 24, 2012, 01:04:39 pm »
Okay, here goes (sorry, may be a little difficult to read) .....
Monday   23   July   2012   21:14:09
1K0 907 115 J      2.0l R4/4V TFSI     0030
   Group A:   '003            Group B:    Not Running            Group C:    Not Running
      Engine Speed   Intake Air Mass   Throttle Drive   Ignition
   TIME         Angle Sensor 1   Timing Angle   TIME               TIME
Marker   STAMP    /min    g/s    %    °BTDC   STAMP               STAMP
   0.01   760   2.86   1.6   0.8
   0.12   760   2.86   1.6   0.8
   0.25   760   2.86   1.6   0.8
   0.41   760   2.86   1.6   0.8
   0.54   760   2.86   1.6   0.8
   0.67   760   2.86   1.6   0.8
   0.79   760   2.86   1.6   0.8
   0.97   760   2.83   1.6   1.5
   1.09   760   2.86   1.6   0.8
   1.21   760   2.86   1.6   0
   1.34   760   2.86   1.6   0
   1.51   760   2.83   1.6   0.8
   1.64   760   2.86   1.6   1.5
   1.76   760   2.86   1.6   0.8
   1.89   760   2.89   1.6   0
   2.06   760   2.86   1.6   0
   2.19   760   2.86   1.6   -0.8
   2.31   760   2.86   1.6   0
   2.43   760   2.86   1.6   0.8
   2.6   760   2.83   1.6   0.8
   2.73   760   2.83   3.9   10.5
   2.85   800   4.36   3.1   11.3
   2.98   880   4.78   3.5   24
   3.15   1040   5.28   3.5   24
   3.27   1160   5.14   3.5   26.3
   3.4   1280   5.33   3.9   27.8
   3.53   1320   5.92   4.3   28.5
   3.7   1440   6.28   4.3   30.8
   3.82   1520   6.47   4.7   30.8
   3.95   1600   6.69   5.1   29.3
   4.07   1680   7.58   5.9   26.3
   4.24   1760   8.31   6.3   20.3
   4.37   1840   8.69   6.3   18
   4.5   1920   9.17   6.7   17.3
   4.62   2000   9.11   6.7   16.5
   4.78   2120   9.36   6.7   15.8
   4.92   2200   9.33   7.1   16.5
   5.03   2240   9.61   7.1   17.3
   5.17   2320   9.69   7.1   17.3
   5.33   2400   9.81   7.1   17.3
   5.45   2440   9.94   7.5   17.3
   5.59   2520   10.17   7.5   18
   5.71   2560   10.19   7.5   18
   5.88   2600   10.36   7.5   21.8
   6.01   2640   10.28   7.1   25.5
   6.13   2680   9.89   6.7   29.3
   6.26   2680   9.33   6.7   9
   6.43   2640   9.14   6.7   7.5
   6.55   2600   9.03   6.7   8.3
   6.68   2520   8.89   6.3   9
   6.8   2480   8.72   6.3   6.8
   6.97   2400   8.31   5.9   6.8
   7.1   2400   8.08   5.9   8.3
   7.22   2400   7.86   5.9   17.3
   7.35   2400   8.25   6.7   18.8
   7.51   2440   9.64   7.1   18
   7.64   2480   9.64   7.1   18
   7.77   2520   9.83   7.1   18
   7.89   2560   9.89   7.1   18
   8.06   2640   10.03   7.1   23.3
   8.19   2680   10.08   7.1   27
   8.32   2680   9.69   7.1   30
   8.44   2720   9.61   7.1   32.3
   8.6   2760   9.53   7.1   33
   8.73   2760   9.44   7.1   33.8
   8.86   2800   9.33   7.1   33.8
   8.98   2800   9.42   6.7   33.8
   9.15   2800   9.42   7.1   33.8
   9.28   2840   9.5   7.1   34.5
   9.41   2840   9.47   7.1   33.8
   9.53   2840   9.53   7.1   33
   9.7   2880   9.64   7.1   30.8
   9.83   2880   9.64   7.1   30
   9.95   2920   9.69   7.1   29.3
   10.07   2920   9.78   7.1   29.3
   10.24   2920   9.75   7.1   28.5
   10.37   2960   9.94   7.1   27.8
   10.5   2960   9.86   7.1   27
   10.62   2960   9.83   7.1   26.3
   10.79   2960   9.92   7.1   26.3
   10.92   2960   9.86   7.1   21
   11.04   3000   9.81   7.1   21
   11.17   3000   9.92   7.1   21
   11.34   2960   9.78   7.1   21
   11.47   2960   9.89   7.1   21
   11.59   3000   9.86   7.1   21
   11.71   2960   9.75   7.1   21
   11.88   2960   9.67   7.1   21
   12.01   2960   9.64   7.1   21
   12.14   2960   9.61   7.1   21
   12.27   2960   9.61   7.1   21
   12.44   2960   9.58   6.7   21
   12.56   2960   9.56   6.7   21.8
   12.69   2960   9.47   6.7   21
   12.81   2960   9.44   6.7   21
   12.98   2960   9.33   6.7   21
   13.11   2960   9.25   6.7   21.8
   13.23   2960   9.31   6.7   21.8
   13.36   2960   9.31   6.7   21.8
   13.53   2960   9.36   6.7   21.8
   13.65   2960   9.22   6.7   21
   13.78   2960   9.28   6.7   21.8
   13.9   2960   9.36   6.7   21.8
   14.06   2960   9.28   6.7   21.8
   14.2   2920   9.25   6.7   8.3
   14.32   2920   9.31   6.7   34.5
   14.45   2840   10.22   7.5   2.3
   14.61   2720   10.17   7.1   -4.5
   14.74   2560   9.61   6.7   -4.5
   14.86   2440   9   6.3   -5.3
   14.99   2320   8.17   5.9   -5.3
   15.16   2120   7.69   5.1   -5.3
   15.29   2000   6.81   4.7   -5.3
   15.41   1840   6.11   4.3   -6
   15.53   1760   6.03   3.9   -7.5
   15.7   1600   5.36   3.5   -6.8
   15.83   1480   5.17   3.5   -6.8
   15.96   1360   4.5   2.7   -6.8
   16.08   1240   4.19   2.4   -3.8
Monday   23   July   2012   21:47:22
   0.05   760   3.11   2   -2.3
   0.22   760   3.11   2   -2.3
   0.35   760   3.08   2   -2.3
   0.48   760   3.11   2   -2.3
   0.6   760   3.08   2   -3
   0.77   760   3.08   2   -2.3
   0.9   760   3.06   2   -2.3
   1.03   720   3.08   1.6   -2.3
   1.14   720   3   1.6   -2.3
   1.32   760   2.94   1.6   -2.3
   1.44   760   2.94   1.6   -2.3
   1.57   760   3   1.6   -1.5
   1.69   760   2.97   1.6   -1.5
   1.86   720   3.06   1.6   -0.8
   1.99   720   3.03   2   -0.8
   2.12   720   3.06   1.6   -1.5
   2.24   760   3.14   2   -2.3
   2.41   760   3.19   2   -4.5
   2.54   760   3.11   2   -3.8
   2.66   760   3.11   2   -3.8
   2.79   760   3.11   2   -3
   2.96   760   3.03   1.6   -3
   3.08   760   3   1.6   -3
   3.21   760   3.03   1.6   -3.8
   3.33   760   3.03   1.6   -2.3
   3.5   760   3.03   1.6   -2.3
   3.63   720   3.03   1.6   -1.5
   3.75   760   3.03   1.6   -2.3
   3.88   720   2.97   1.6   -2.3
   4.05   720   2.97   1.6   -1.5
   4.18   720   3   1.6   0.8
   4.3   720   3   1.6   1.5
   4.42   720   3.06   2   2.3
   4.59   720   3.28   2   9
   4.72   760   4.25   5.5   9
   4.84   800   7.5   5.5   12
   4.97   920   7.17   5.5   9
   5.14   1080   5.89   4.3   3.8
   5.26   1120   5.92   4.3   12.8
   5.39   1120   6.19   4.7   19.5
   5.52   1120   6.56   4.7   18.8
   5.68   1080   6.92   5.1   24.8
   5.82   1040   7.39   6.3   24
   5.94   1080   8.89   7.1   24
   6.06   1120   9.75   7.1   15.8
   6.23   1200   8.75   6.3   12.8
   6.36   1200   8.39   6.3   18.8
   6.49   1200   8.58   6.3   20.3
   6.61   1200   8.53   6.3   20.3
   6.78   1160   8.56   6.3   19.5
   6.91   1120   8.25   6.3   24.8
   7.03   1040   8.14   6.3   23.3
   7.15   1000   8.81   7.1   22.5
   7.32   880   10.42   10.6   12.8
   7.45   1080   13.94   13.7   8.3
   7.58   1160   14.97   14.9   8.3
   7.7   1200   16.94   14.9   7.5
   7.87   1440   21.83   20   9.8
   8   1520   24.47   22.4   9
   8.12   1680   27.78   25.1   9.8
   8.25   1800   31.58   27.1   9.8
   8.41   2000   36.53   28.2   9.8
   8.54   2160   41.97   29   7.5
   8.67   2280   47.28   29   9
   8.79   2440   32.58   18   9.8
   8.96   2520   15.47   9.4   29.3
   9.08   2440   6.53   5.1   -6.8
   9.22   2320   5.75   5.5   -5.3
   9.34   2240   6.14   5.5   -5.3
   9.5   2080   6.06   4.7   -1.5
   9.64   2040   6.83   12.9   19.5
   9.76   1680   29.97   20   1.5
   9.88   1760   28.83   35.3   1.5
   10.05   1760   36.03   91.8   -0.8
   10.18   1960   40.97   98.8   3
   10.31   1960   43.47   99.6   3.8
   10.43   2080   48.17   99.6   2.3
   10.6   2200   55.33   99.6   3
   10.73   2280   62.67   99.6   3
   10.85   2360   70.19   99.6   0.8
   10.98   2480   79.03   99.6   -1.5
   11.15   2600   83.06   66.3   0.8
   11.27   2680   47.11   22.7   5.3
   11.4   2720   23.14   13.7   9.8
   11.52   2680   11.64   7.5   -9.8
   11.69   2600   4.11   5.5   -5.3
   11.82   2440   5.42   5.5   -5.3
   11.94   2320   6.44   5.5   -5.3
   12.07   2280   11.36   7.5   21.8
   12.24   1920   37.53   27.1   -3
   12.36   2120   41.42   73.3   -0.8
   12.49   2080   43.81   97.3   -2.3
   12.62   2080   48.44   99.2   0.8
   12.78   2160   52.94   99.6   -3
   12.91   2200   56.92   99.6   -1.5
   13.04   2280   60.83   99.6   -1.5
   13.16   2280   66.47   80.8   -2.3
   13.33   2400   63.28   33.7   -1.5
   13.45   2400   62.81   30.6   -1.5
   13.58   2480   56.08   28.6   -0.8
   13.71   2520   53.5   29   0
   13.87   2600   54.36   29.4   4.5
   14.01   2640   50.86   28.2   5.3
   14.13   2680   49.28   27.8   4.5
   14.25   2720   51.42   32.5   3
   14.43   2800   53.72   32.5   11.3
   14.55   2800   35.94   19.2   12.8
   14.68   2800   15.25   8.6   31.5
   14.79   2720   6.72   5.9   -5.3
   14.96   2560   7.25   5.9   -5.3
   15.09   2440   7.03   5.9   -5.3
   15.22   2360   7.03   5.9   13.5
   15.34   2200   17.47   17.6   20.3
   15.51   2160   37.22   31.8   0
   15.64   2200   45.78   91   -1.5
   15.77   2200   48.14   92.9   -4.5
   15.89   2240   53.03   85.1   -2.3
   16.06   2240   55.33   52.2   0.8
   16.19   2280   58.22   34.9   0
   16.31   2280   29.36   20   1.5
   16.44   2280   25.06   16.5   1.5
   16.6   2320   17.58   9.8   1.5
   16.74   2320   10.78   7.8   8.3
   16.86   2320   8.44   6.3   4.5
   16.98   2320   6.03   5.1   4.5
   17.15   2320   6.31   5.1   -0.8
   17.28   2320   6.75   5.5   -5.3
   17.41   2320   7   5.5   -5.3
   17.53   2280   7.22   5.5   -5.3
   17.7   2320   7.5   5.5   -5.3
   17.83   2280   7.31   5.5   -5.3
   17.95   2280   7.67   5.5   11.3
   18.07   2280   8   5.5   -0.8
   18.24   2200   7.72   5.5   -5.3
   18.37   2200   7.53   5.1   -5.3
   18.5   2160   7.5   5.1   -5.3
   18.62   2120   7.06   5.1   -5.3
   18.79   2040   7   4.7   -5.3
   18.92   2000   6.92   4.7   -5.3
   19.04   1960   6.44   4.7   -5.3
   19.17   1920   6.42   4.3   -5.3
   19.34   1880   6.22   4.3   -6
   19.46   1840   5.86   3.9   -6.8
   19.59   1800   5.94   3.9   -6.8
   19.71   1760   5.72   3.9   -7.5
   19.88   1680   5.53   3.9   -7.5
   20.01   1640   5.47   3.5   -7.5
   20.13   1640   5.31   3.5   -7.5
   20.26   1600   5.28   3.5   -6.8
   20.43   1560   5.11   3.5   -6.8
   20.55   1520   4.94   3.5   -6.8
   20.68   1440   4.75   3.1   -6.8
   20.81   1440   4.44   3.1   -6.8
   20.97   1440   4.42   3.1   -8.3
   21.1   1440   4.31   3.1   -8.3
   21.23   1440   4.42   3.1   -8.3
   21.35   1440   4.44   3.1   -8.3
   21.52   1400   4.33   3.1   -8.3
   21.65   1440   4.47   3.1   -8.3
   21.77   1400   4.44   3.1   -5.3
   21.9   1440   4.42   3.1   6.8
   22.06   1400   4.75   3.5   16.5
   22.2   1440   5.67   5.1   22.5
   22.32   1400   10.03   8.2   19.5
   22.45   1440   11.53   9.4   26.3
   22.61   1440   15.08   11.4   24.8
   22.74   1440   15.67   11.8   22.5
   22.87   1480   15.67   12.5   21
   22.99   1480   16.28   12.5   18.8
   23.16   1480   15.17   10.2   20.3
   23.29   1480   11   7.8   26.3
   23.41   1520   10.97   7.8   27.8
   23.53   1520   10.89   8.2   28.5
   23.7   1520   15.28   11.4   26.3
   23.83   1520   15.67   14.1   21.8
   23.95   1560   19.97   16.9   15
   24.08   1600   27   31.8   6.8
   24.25   1600   31.36   88.6   -1.5
   24.38   1600   33.22   89.8   -3.8
   24.5   1640   35.28   91.8   -1.5
   24.63   1640   35.58   93.3   -1.5
   24.8   1680   37.19   94.1   -1.5
   24.92   1720   38.39   95.7   -1.5
   25.05   1760   39.5   97.3   -1.5
   25.17   1760   40.81   98.8   -2.3
   25.34   1800   42.75   99.6   -3
   25.47   1840   44.47   99.6   -2.3
   25.59   1840   45.28   99.6   -3
   25.71   1880   47.22   99.6   -3.8
   25.89   1920   48.72   99.6   -3.8
   26.02   1960   51.67   99.6   -3.8
   26.14   2000   53.17   99.6   -3.8
   26.26   2000   55.19   99.6   -3.8
   26.43   2040   58.03   99.6   -3.8
   26.56   2080   59.81   99.6   -4.5
   26.69   2120   63.97   99.6   -5.3
   26.81   2160   66   99.6   -6
   26.98   2200   71.75   99.6   -7.5
   27.11   2160   14.94   22.7   -16.5
   27.23   2200   18.28   15.3   -11.3
   27.36   2240   5.47   7.8   0
   27.53   2200   3.53   5.5   15
   27.65   2160   4   4.7   15.8
   27.78   2120   3.86   4.3   8.3
   27.9   2120   4.56   4.7   1.5
   28.07   2040   5.61   4.7   -5.3
   28.2   2000   5.75   4.7   -5.3
   28.32   2000   5.81   4.3   -4.5
   28.45   1960   5.89   4.3   -5.3
   28.62   1880   6.11   4.3   -1.5
   28.74   1880   6.5   4.3   4.5
   28.87   1840   5.94   4.3   -5.3
   28.99   1840   6.19   4.3   -6.8
   29.16   1800   5.89   3.9   -7.5
   29.29   1760   5.75   3.9   -7.5
   29.42   1720   5.69   3.9   -7.5
   29.54   1720   5.67   3.9   -7.5
   29.71   1720   5.44   3.9   -7.5
   29.84   1720   5.64   3.9   12.8
   29.96   1760   16.31   12.5   -0.8
   30.09   1720   18.81   13.3   7.5
   30.25   1720   18.97   13.7   3
   30.39   1760   24   18   4.5
   30.51   1760   28.08   22.7   3.8
   30.63   1800   34   87.8   -1.5
   30.8   1800   36.83   99.6   -3
   30.93   1840   38.89   99.6   0
   31.06   1840   40.42   99.6   0.8
   31.18   1880   41.28   99.6   0.8
   31.35   1920   44.22   99.6   0
   31.48   1920   46.64   99.6   0
   31.6   1960   47.92   99.6   -0.8
   31.73   2000   49.36   99.6   -0.8
   31.89   2040   53.61   99.6   -2.3
   32.02   2040   55.06   81.6   -13.5
   32.15   2080   17.72   14.5   -12.8
   32.27   2040   9.92   7.8   -6
   32.44   2080   4.89   5.1   12.8
   32.57   2040   3.97   4.3   15.8
   32.69   2040   3.44   4.3   9.8
   32.81   2000   4.64   4.3   3
   32.98   1960   5.25   4.3   -5.3
   33.11   1960   5.36   4.3   -5.3
   33.24   1920   5.56   4.3   -5.3
   33.37   1880   5.72   4.3   -6
   33.53   1840   5.94   4.3   -1.5
   33.65   1840   5.83   4.3   2.3
   33.78   1800   6.17   4.3   -6
   33.91   1800   6   3.9   -7.5
   34.08   1760   5.86   3.9   -7.5
   34.21   1720   5.75   3.9   -7.5
   34.33   1680   5.61   3.9   -7.5
   34.45   1680   5.56   3.9   -7.5
   34.62   1640   5.5   3.5   -7.5
   34.75   1640   5.25   3.5   -7.5
   34.88   1640   5.25   3.5   -7.5
   35   1600   5.31   3.5   -6.8
   35.17   1600   5.19   3.5   -6.8
   35.3   1560   5.08   3.5   -6.8
   35.42   1520   5   3.1   -6.8
   35.55   1520   4.92   3.1   -6.8
   35.72   1520   4.83   3.1   -6.8
   35.84   1480   4.53   3.1   -6.8
   35.97   1480   4.64   3.1   -6
   36.09   1480   4.61   3.1   -6.8
   36.26   1440   4.53   3.1   -8.3
   36.39   1440   4.61   3.1   -8.3
   36.52   1440   4.5   3.1   -8.3
   36.64   1440   4.56   3.1   -8.3
   36.81   1400   4.5   3.1   -8.3
   36.94   1400   4.36   3.1   -8.3
   37.06   1400   4.47   3.1   -8.3
   37.18   1360   4.39   2.7   -8.3
   37.35   1360   4.36   2.7   -8.3
   37.48   1360   4.22   2.7   -8.3
   37.6   1360   4.06   2.7   -8.3
   37.73   1320   4.17   2.7   -8.3
   37.9   1320   4.11   2.7   -8.3
   38.02   1320   4.08   2.7   -8.3
   38.15   1320   4.08   2.7   -8.3
   38.28   1320   4.08   2.7   -8.3
   38.44   1280   4.06   2.7   -8.3
   38.57   1280   4.08   2.7   -8.3
   38.69   1280   4.08   2.7   -8.3
   38.82   1280   4.11   2.7   -8.3
   38.99   1280   4.03   2.7   -8.3
   39.12   1280   3.97   2.7   -8.3
   39.25   1240   4.11   2.7   -8.3
   39.37   1240   4.08   2.7   -8.3
   39.54   1240   4.03   2.7   -8.3
   39.67   1240   3.92   2.4   -8.3
   39.79   1240   3.86   2.4   -8.3
   39.91   1240   3.94   2.4   -8.3
   40.08   1240   3.81   2.7   -8.3
   40.21   1240   3.97   2.7   -8.3
   40.34   1240   4.03   2.7   -8.3
   40.46   1200   4   2.7   -8.3
   40.63   1080   3.97   2.4   -8.3
   40.76   1000   3.72   2   5.3
   40.88   920   3.25   2   3.8
   41.01   920   3.39   2   -6
   41.18   880   3   1.6   -5.3
   41.3   840   2.72   1.6   -0.8
   41.43   840   2.81   1.6   -3.8
   41.55   800   2.81   1.6   0.8
   41.72   760   2.72   1.6   -0.8
   41.85   760   2.72   1.2   1.5
   41.97   760   2.75   1.2   0.8
   42.1   920   2.75   1.2   -9
   42.27   1120   2.31   1.6   -8.3
   42.4   1320   3.25   2.7   -8.3
   42.52   1480   4.39   3.5   -8.3
   42.65   1800   5.47   3.9   -8.3
   42.81   2120   6.64   4.7   -6
   42.94   2080   7.33   5.5   -6
   43.07   2000   7.14   5.1   -3.8
   43.19   2080   6.86   5.1   0
   43.36   2080   6.92   5.1   9.8
   43.49   2040   9.19   7.5   16.5
   43.61   2040   10.31   7.8   15.8
   43.73   2040   11.42   8.6   15.8
   43.91   2080   14.42   10.2   15
   44.03   2120   14.86   10.2   14.3
   44.15   2120   14.58   10.2   14.3
   44.28   2160   16.08   11   14.3
   44.45   2160   19.03   13.3   16.5
   44.58   2200   21.17   13.7   18.8
   44.7   2240   24.92   15.3   20.3
   44.83   2280   25.56   15.3   21
   45   2320   26.56   14.5   22.5
   45.13   2360   17.44   9.4   30
   45.25   2360   11.33   7.8   33
   45.37   2400   9.72   6.7   25.5
   45.54   2400   11.19   5.5   24.8
   45.67   2400   7.81   5.9   18
   45.8   2400   7.81   6.3   21
   45.92   2400   8.78   6.3   19.5
   46.09   2400   9.42   7.1   18
   46.21   2400   11   7.8   17.3
   46.34   2400   10.92   7.5   16.5
   46.47   2400   10.89   7.5   16.5
   46.63   2400   10.56   7.5   16.5
   46.77   2440   10.42   7.5   16.5
   46.89   2440   10.5   7.5   16.5
   47.01   2440   10.53   7.5   16.5
   47.18   2440   10.17   6.7   15.8
   47.31   2440   8.14   5.9   9
   47.43   2400   8.14   5.9   0.8
   47.56   2440   7.92   5.9   -2.3
   47.73   2440   8.11   5.9   6.8
   47.85   2440   7.92   6.3   17.3
   47.98   2440   9.03   7.8   17.3
   48.1   2400   10.64   7.5   17.3
   48.27   2400   10.42   7.5   17.3
   48.4   2440   10.56   7.5   17.3
   48.52   2440   10.25   7.5   17.3
   48.65   2440   10.36   7.5   17.3
   48.82   2440   9.61   6.7   17.3
   48.94   2440   8.94   6.7   17.3
   49.07   2440   8.97   6.7   17.3
   49.2   2440   9.17   6.7   17.3
   49.36   2440   8.42   5.9   10.5
   49.49   2440   8.36   5.9   3.8
   49.62   2400   8.19   5.9   -1.5
   49.75   2360   8.11   5.9   -5.3
   49.91   2400   7.92   5.9   -5.3
   50.04   2360   8.17   5.9   -5.3
   50.17   2360   7.94   5.9   -5.3
   50.29   2360   7.64   5.9   -5.3
   50.46   2360   7.89   5.5   17.3
   50.59   2320   8.03   5.5   -5.3
   50.71   2320   7.83   5.5   -5.3
   50.84   2320   7.75   5.5   -3
   51   2280   7.72   5.5   0
   51.13   2280   7.64   5.5   5.3
   51.26   2280   9.58   7.5   15
   51.38   2320   10.89   7.8   6
   51.55   2280   14.14   10.6   15.8
   51.68   2320   21.75   14.9   14.3
   51.8   2360   29.5   19.6   11.3
   51.93   2400   37.83   26.7   10.5
   52.1   2480   49.56   32.5   9.8
   52.22   2560   54   32.5   12
   52.35   2600   55.81   32.5   12.8
   52.47   2680   57.61   31.8   12
   52.64   2800   58.14   31.4   12
   52.77   2880   54.86   29   12
   52.89   2960   55   26.7   15.8
   53.01   2960   37.61   17.3   21.8
   53.19   3080   29.53   15.7   28.5
   53.31   3120   29.33   15.7   30
   53.44   3120   27.42   14.5   33.8
   53.56   3160   24.28   12.9   35.3
   53.73   3160   19.53   12.2   35.3
   53.86   3200   19.39   12.5   35.3
   53.98   3200   20.97   12.5   35.3
   54.11   3240   14.58   7.8   35.3
   54.28   3200   10.36   7.8   36
   54.4   3160   11.08   7.8   -3
   54.53   3040   10.89   7.8   -3.8
   54.66   2920   10.92   7.5   -4.5
   54.82   2800   10.33   7.1   -4.5
   54.95   2720   12   7.1   -4.5
   55.08   2640   9.53   6.7   -4.5
   55.2   2640   9.58   8.6   18.8
   55.37   2200   29.94   18.4   7.5
   55.5   2320   39   28.2   8.3
   55.63   2360   46.11   31.8   5.3
   55.75   2360   49.92   32.9   10.5
   55.92   2440   57.14   31.8   12
   56.04   2440   61.67   32.5   10.5
   56.17   2520   64.83   32.9   9.8
   56.29   2560   68.06   29.8   8.3
   56.46   2600   70.42   29   7.5
   56.59   2640   71.5   26.7   6.8
   56.72   2680   37   21.2   11.3
   56.84   2720   16.53   11.4   19.5
   57.01   2720   9.94   8.2   33.8
   57.14   2720   9.42   7.1   36
   57.26   2720   7.39   6.3   31.5
   57.39   2720   7.47   6.3   19.5
   57.56   2680   8.44   6.3   9
   57.68   2640   8.58   6.3   3.8
   57.81   2600   8.69   6.3   -2.3
   57.93   2560   8.83   6.3   -4.5
   58.1   2520   8.92   6.3   -4.5
   58.23   2480   8.69   6.3   -5.3
   58.36   2440   8.58   5.9   4.5
   58.48   2400   8.56   5.9   -3
   58.65   2320   8.19   5.5   -5.3
   58.77   2280   8.11   5.5   -5.3
   58.89   2240   7.56   5.1   -5.3
   59.02   2200   7.5   5.1   -5.3
   59.2   2200   7.42   5.1   -5.3
   59.32   2120   7.31   4.7   -5.3
   59.44   2080   7.08   4.7   -5.3
   59.57   2080   7   4.7   -5.3
   59.74   2040   6.67   4.7   -5.3
   59.87   1960   6.31   4.3   -5.3
   59.99   1960   6.22   4.3   -5.3
   60.12   1960   6.33   4.3   -5.3
   60.29   1920   6.11   4.3   -5.3
   60.41   1880   6.11   4.3   -6
   60.54   1880   6   4.3   -6
   60.66   1880   6   3.9   -6
   60.83   1880   5.97   3.9   -6
   60.96   1840   5.86   3.9   -1.5
   61.09   1880   7.86   7.1   15.8
   61.21   1840   11.11   8.2   15.8
   61.38   1840   14.28   10.2   14.3
   61.51   1880   14.89   10.2   12.8
   61.63   1880   14.89   10.2   12
   61.75   1880   15.58   11.4   12.8
   61.92   1920   22.31   15.7   15.8
   62.05   1920   25.06   17.3   15
   62.18   1960   27.92   18   16.5
   62.3   1960   28.92   18.8   16.5
   62.47   2000   30.39   18.4   18.8
   62.59   2040   29.78   18   18.8
   62.72   2040   29.53   17.3   19.5
   62.84   2080   29.97   16.9   19.5
   63.01   2120   29.83   16.9   20.3
   63.14   2120   28.94   15.7   21
   63.27   2160   18.61   11   22.5
   63.39   2160   11.61   7.8   31.5
   63.56   2200   9.14   6.7   29.3
   63.69   2200   6.86   5.1   22.5
   63.81   2160   6.11   4.7   20.3
   63.93   2160   6.11   4.7   8.3
   64.11   2160   6.72   5.1   -1.5
   64.24   2200   6.86   5.1   -4.5
   64.36   2160   7.25   5.1   -5.3
   64.48   2160   8.75   5.1   -5.3
   64.65   2160   7.25   5.1   -5.3
   64.78   2160   7.17   5.1   -1.5
   64.9   2160   7.17   5.1   4.5
   65.03   2120   7.11   5.1   -3.8
   65.2   2120   7.22   5.1   -5.3
   65.33   2120   7.31   5.1   -5.3
   65.45   2120   7.08   4.7   -5.3
   65.58   2120   7.06   4.7   -5.3
   65.74   2120   6.89   4.7   -5.3
   65.87   2080   7.06   4.7   -5.3
   66   2080   6.75   4.7   -5.3
   66.12   2080   6.86   4.7   -5.3
   66.29   2080   6.58   4.7   -5.3
   66.42   2080   6.67   4.7   -5.3
   66.54   2040   6.69   4.7   -5.3
   66.67   2040   6.64   4.7   -5.3
   66.83   2040   6.61   4.7   -5.3
   66.96   2000   6.58   4.3   -4.5
   67.09   2000   6.47   4.3   -4.5
   67.21   2000   6.47   4.3   -5.3
   67.38   2000   6.33   4.3   -4.5
   68.06   1920   6.36   4.3   -5.3
   68.18   1920   6.33   4.3   -5.3
   68.31   1920   6.22   4.3   -5.3
   68.48   1920   6.06   4.3   -6
   68.6   1920   5.92   4.3   -3.8
   68.73   1880   5.83   3.9   -1.5
   68.85   1920   5.78   4.3   0.8
   69.02   1880   5.94   4.3   5.3
   69.15   1880   6.47   5.5   15.8
   69.27   1920   9.06   6.7   15.8
   69.4   1840   9.03   6.7   15.8
   122.53   2040   7.61   5.5   16.5
   122.65   2000   8.11   5.9   16.5
   122.78   2000   8.14   5.9   16.5
   122.91   2040   8.67   5.9   16.5
   123.07   2000   8.5   5.9   16.5
   123.2   2040   8.56   5.9   16.5
   123.32   2000   8.44   5.9   16.5
   123.45   2000   8.47   5.9   16.5
   123.62   2000   8.5   5.9   16.5
   123.75   2000   8.56   5.9   16.5
   123.87   2000   8.56   5.9   16.5
   124   2000   7.69   5.5   16.5
   124.17   2000   7.64   5.1   16.5
   124.29   2000   7.25   5.1   16.5
   124.42   2000   7.14   5.1   16.5
   124.54   2000   7.19   5.1   16.5
   124.71   2000   7.08   5.1   16.5
   124.84   2000   7.14   4.7   16.5
   124.96   2000   7.69   6.3   16.5
   125.09   2040   13.5   12.2   15.8
   125.26   2080   34.61   33.3   8.3
   125.39   2080   39.53   95.7   6
   125.51   2080   43.56   98.8   6.8
   125.64   2120   47.83   99.6   10.5
   125.8   2200   53.33   99.6   9.8
   125.93   2240   57.94   99.6   8.3
   126.06   2280   65.33   99.6   6
   126.18   2320   72.97   99.6   2.3
   126.35   2400   82.86   99.6   0.8
   126.48   2480   91.25   99.6   -0.8
   126.6   2520   99.19   99.6   -1.5
   126.73   2600   100.47   99.6   -2.3
   126.9   2680   108.39   99.6   -2.3
   127.03   2760   112.78   99.6   -1.5
   127.15   2840   118.22   99.6   -2.3
   127.28   2920   115.78   99.6   0.8
   127.44   3000   123.83   98.4   2.3
   127.57   3080   122.19   98.8   2.3
   127.7   3160   125.19   98.8   2.3
   127.82   3240   129.47   99.2   3
   127.99   3360   133.36   99.2   3
   128.11   3400   136   39.2   -4.5
   128.24   3480   20.61   19.2   -4.5
   128.37   3480   5.78   4.7   -3
   128.54   3280   2.22   5.9   -3
   128.66   3120   3.19   6.7   -3
   128.79   3040   9.89   7.1   23.3
   128.91   3200   46.83   31.8   11.3
   129.09   2480   63.56   88.2   3
   129.21   2520   76.67   97.6   3.8
   129.34   2680   87.56   99.2   2.3
   129.46   2680   96.92   99.6   0
   129.63   2720   107.03   99.6   0.8
   129.75   2760   109.53   99.6   -1.5
   129.88   2800   113.08   99.6   -1.5
   130.01   2840   118.11   99.6   -0.8
   130.17   2880   121.11   99.6   0
   130.3   2960   120   98.8   0.8
   130.43   2960   117.44   98.4   0.8
   130.55   3040   117.69   98.4   1.5
   130.72   3040   29.64   20   -6.8
   130.85   3080   11.53   12.9   3.8
   130.97   3080   3.89   8.2   30
   131.1   3040   4.89   7.5   36
   131.26   3040   6.33   6.3   28.5
   131.39   3040   7.89   6.7   15
   131.52   3000   8.17   6.7   6
   131.65   3000   9.14   7.1   0.8
   131.81   2960   9.89   7.1   -4.5
   131.94   2920   9.83   7.1   -4.5
   132.07   2920   10.19   7.1   -4.5
   132.19   2920   9.97   7.1   -4.5
   132.36   2880   10.53   7.1   2.3
   132.48   2880   10.67   7.1   -4.5
   132.61   2840   10.42   7.1   -4.5
   132.74   2840   10.64   6.7   -4.5
   132.91   2840   10.19   6.7   9
   133.03   2920   34.14   22.7   3
   133.16   2840   57.03   90.6   10.5
   133.28   2880   66.11   98.4   11.3
   133.45   2920   81.97   99.6   10.5
   133.58   2920   95.89   99.6   6
   133.7   2960   108.19   99.6   5.3
   133.83   2960   113.64   99.6   4.5
   134   3040   117.36   99.6   2.3
   134.13   3080   119.03   99.6   3
   134.25   3120   123.78   99.6   3
   134.37   3120   125.97   66.3   -5.3
   134.54   3120   17.31   16.5   -6
   134.67   3160   9.94   9.4   22.5
   134.79   3160   3.42   7.8   35.3
   134.92   3120   5.08   6.7   36.8
   135.09   3120   7.03   6.7   22.5
   135.22   3080   8.36   7.1   10.5
   135.34   3040   9.42   7.1   3.8
   135.46   3040   9.67   7.1   -2.3
   135.63   3000   10.22   7.1   -3.8
   135.76   2960   10.42   7.1   -4.5
   135.89   2920   10.31   7.1   -4.5
   136.01   2920   10.31   7.1   10.5
   136.18   2880   10.44   7.1   -0.8
   136.31   2840   10.58   7.1   -4.5
   136.43   2840   12.75   7.1   -4.5
   136.55   2800   10.28   6.7   -4.5
   136.72   2760   10.39   6.7   -4.5
   136.85   2720   9.92   6.3   -4.5
   136.98   2720   10.06   6.3   -4.5
   137.1   2680   9.72   6.3   -4.5
   137.27   2640   9.5   6.3   -4.5
   137.4   2600   9.14   5.9   -4.5
   137.52   2600   9.08   5.9   -4.5
   137.65   2560   8.97   5.9   -4.5
   137.82   2560   8.81   5.9   -4.5
   137.94   2560   8.58   5.9   -4.5
   138.07   2560   8.89   5.9   -4.5
   138.2   2520   8.92   5.9   -4.5
   138.36   2520   8.83   5.9   -4.5
   138.49   2520   8.56   5.9   -4.5
   138.62   2520   8.58   5.9   -4.5
   138.74   2480   8.25   5.5   -5.3
   138.91   2480   8.5   5.5   -5.3
   139.04   2480   8.44   5.5   -4.5
   139.17   2480   8.42   5.5   -5.3
   139.29   2440   8.33   5.5   -5.3
   139.45   2440   8.36   5.5   -5.3
   139.58   2440   8.08   5.5   -5.3
   139.71   2400   8.28   5.5   -5.3
   139.83   2400   8.03   5.5   -5.3
   140   2360   7.97   5.5   -5.3
   140.13   2360   8   5.5   -5.3
   140.26   2320   7.75   5.5   -5.3
   140.38   2320   7.5   5.1   -5.3
   140.55   2280   7.78   5.1   -5.3
   140.68   2280   7.58   5.1   -5.3
   140.8   2240   7.53   5.1   -5.3
   140.92   2200   7.44   5.1   -5.3
   141.09   2200   7.25   4.7   -5.3
   141.22   2160   7.28   4.7   -5.3
   141.35   2120   7.03   4.7   -5.3
   141.47   2120   6.81   4.7   -5.3
   141.64   2080   6.83   4.7   -5.3
   141.77   2040   6.64   4.3   -5.3
   141.89   2040   6.47   4.3   -5.3
   142.01   2000   6.64   4.3   -5.3
   142.19   1960   6.36   4.3   -5.3
   142.32   1960   6.08   3.9   -5.3
   142.44   1920   6.11   3.9   -5.3
   142.56   1920   6.03   3.9   -5.3
   142.73   1920   6.03   3.9   -6
   142.86   1920   6.14   3.9   -6
   142.98   1920   6.11   3.9   -6
   143.11   1880   6.03   3.9   -6
   143.28   1880   5.94   3.9   -6
   143.4   1880   5.72   3.9   -6
   143.53   1880   6   3.9   -6
   143.65   1840   6.06   3.9   -6.8
   143.82   1840   6   3.9   -6.8
   143.95   1840   5.89   3.9   -6.8
   144.08   1840   5.92   3.9   -6.8
   144.2   1800   5.72   3.9   -6.8
   144.37   1800   5.97   3.9   -6.8
   144.5   1800   5.75   3.9   -6.8
   144.62   1800   5.81   3.9   -6.8
   144.74   1800   5.72   3.9   -7.5
   144.91   1760   5.72   3.9   -7.5
   145.04   1760   5.64   3.9   -7.5
   145.17   1760   5.58   3.9   -6
   145.29   1760   5.44   3.5   -4.5
   145.46   1760   6.44   5.1   15
   145.58   1720   9.53   7.1   15.8
   145.71   1760   9.75   7.1   8.3
   145.84   1760   9.56   7.1   12.8
   146.01   1760   9.56   6.7   16.5
   146.13   1760   9.61   6.7   15.8
   146.26   1760   9.83   6.7   18
   146.38   1760   8.67   5.5   18.8
   146.55   1760   5.53   3.5   18.8
   146.68   1760   5.53   3.5   10.5
   146.8   1720   5.5   3.5   2.3
   146.93   1720   5.39   3.5   -1.5
   147.1   1720   5.61   3.5   -7.5
   147.22   1720   5.56   3.5   -7.5
   147.35   1680   5.64   3.5   -7.5
   147.47   1720   5.56   3.5   -7.5
   147.65   1680   5.58   3.5   15
   147.77   1680   5.44   3.5   3.8
   147.9   1680   5.39   3.5   -3
   148.02   1680   5.58   3.5   -7.5
   148.19   1680   5.56   3.5   -7.5
   148.32   1680   5.47   3.5   -7.5
   148.45   1680   5.47   3.5   -7.5
   148.56   1640   5.44   3.5   -7.5
   148.73   1640   5.36   3.5   -7.5
   148.86   1640   5.33   3.1   -7.5
   148.99   1640   5.17   3.1   -7.5
   149.11   1600   5.19   3.1   -7.5
   149.28   1600   5.25   3.1   -7.5
   149.41   1520   5.25   3.1   -6.8
   149.54   1400   4.72   2.7   -6.8
   149.66   1280   4.22   2.4   -7.5
   149.83   1120   3.61   2   -8.3
   149.95   1040   3.53   2   20.3
   150.08   1040   3.67   2   -3
   150.21   1000   3.11   1.6   -4.5
   150.38   960   2.83   1.6   0
   150.5   960   2.92   1.6   -0.8
   150.63   920   2.81   1.6   0
   150.75   880   2.72   1.2   0
   150.92   840   2.75   1.2   0.8
   151.05   800   2.69   1.2   -2.3
   151.17   760   2.61   1.2   0.8
   151.29   720   2.64   1.2   3
   151.47   720   2.67   1.2   2.3
   151.59   720   2.67   1.2   2.3
   151.71   720   2.61   1.2   3.8
   151.84   720   2.64   1.2   3
   152.01   720   2.67   1.2   3
   152.14   720   2.69   1.2   1.5
   152.27   720   2.69   1.2   2.3
   152.39   720   2.69   1.2   1.5
   152.56   720   2.69   1.2   2.3
   152.68   720   2.69   1.2   2.3
   152.81   720   2.69   1.2   2.3
   152.94   720   2.72   1.2   2.3
   153.1   720   2.67   1.2   2.3
   153.23   720   2.72   1.2   2.3
   153.36   760   2.75   1.2   1.5
   153.48   760   2.72   1.2   0.8
   153.65   760   2.75   1.2   0
   153.78   760   2.72   1.2   -1.5
   153.9   760   2.75   1.2   -0.8
   154.03   760   2.75   1.2   -1.5
   154.2   760   2.78   1.2   -1.5
   154.32   760   2.72   1.2   -1.5
   154.45   760   2.75   1.2   -2.3
   154.57   760   2.69   1.2   -1.5
   154.74   760   2.67   1.2   -1.5
   154.87   760   2.61   1.2   -0.8
   154.99   760   2.58   1.2   -0.8
   155.12   760   2.58   1.2   0
   155.29   720   2.56   1.2   0
   155.41   720   2.56   1.2   0
   155.54   720   2.58   1.2   0
   155.66   720   2.58   1.2   0
   155.83   720   2.53   1.2   0.8
   155.96   720   2.56   1.2   1.5
   156.08   720   2.56   1.2   1.5
   156.21   720   2.53   1.2   1.5
   156.38   720   2.53   1.2   2.3
   156.51   720   2.56   1.2   2.3
   156.64   720   2.64   1.2   1.5
   156.76   720   2.67   1.2   1.5
   156.93   720   2.67   1.2   0.8
   157.06   760   2.67   1.2   0
   157.18   760   2.61   1.2   0
   157.31   760   2.64   1.2   0
   157.48   760   2.67   1.2   0
   157.6   760   2.69   1.2   0
   157.73   760   2.67   1.2   0.8
   157.85   760   2.64   1.2   13.5
   158.02   800   4.86   3.9   14.3
   158.15   1200   7   6.7   24
   158.27   1520   9.39   8.6   27
   158.4   1320   14.06   10.6   24.8
   158.57   1360   19.53   15.7   18.8
   158.69   1440   19.36   16.1   10.5
   158.82   1440   23.39   20   6
   158.95   1480   25.78   23.9   9
   159.11   1520   27.03   23.9   8.3
   159.23   1520   28.25   23.9   7.5
   159.36   1560   29.83   23.9   7.5
   159.49   1600   30.92   24.7   6.8
   159.66   1640   32.36   25.1   6.8
   159.79   1680   33.22   24.7   6.8
   159.91   1720   34.17   23.5   6
   160.03   1760   33.97   23.1   6.8
   160.2   1800   32.72   21.2   9
   160.33   1840   30.83   19.2   10.5
   160.46   1840   29.22   17.6   11.3
   160.58   1920   29.44   16.9   13.5
   160.75   1920   25.81   14.5   16.5
   160.88   1960   23.69   13.7   18.8
   161   1960   19.03   11.8   22.5
   161.13   2000   19.97   12.2   26.3
   161.3   2000   20.94   12.5   25.5
   161.42   2040   21.11   12.5   25.5
   161.55   2040   21.56   12.9   26.3
   161.67   2080   21.69   12.9   25.5
   161.85   2080   22.08   12.9   26.3
   161.97   2120   22.56   13.3   26.3
   162.1   2120   22.39   13.3   26.3
   162.22   2120   22.78   13.3   26.3
   162.39   2160   22.97   13.3   26.3
   162.52   2160   23   13.3   26.3
   162.64   2200   23.11   13.3   26.3
   162.77   2200   22.75   13.3   26.3
   162.93   2240   22.64   12.9   26.3
   163.06   2240   22.64   12.9   26.3
   163.18   2240   22.81   12.9   27
   163.31   2280   23.08   12.9   27
   163.48   2280   22.92   12.9   27
   163.61   2280   22.78   12.9   27.8
   163.73   2280   22.5   12.9   27.8
   163.85   2320   22.5   12.9   27.8
   164.02   2320   22.06   12.2   27.8
   164.15   2360   21.44   12.5   29.3
   164.28   2360   22   12.5   28.5
   164.41   2360   21.67   12.5   29.3
   164.57   2400   21.94   12.5   29.3
   164.7   2400   22.28   12.5   29.3
   164.82   2400   22   12.5   29.3
   164.95   2400   22.06   12.5   29.3
   165.11   2440   22.25   12.5   29.3
   165.25   2440   21.75   12.5   29.3
   165.37   2440   22.19   12.5   29.3
   165.5   2480   22.22   12.5   29.3
   165.66   2480   22.06   12.2   29.3
   165.79   2480   21.58   12.2   30.8
   165.92   2480   21.11   12.2   30.8
   166.04   2520   20.67   12.2   30.8
   166.21   2520   20   11.8   31.5
   166.34   2520   20   11.8   31.5
   166.46   2520   20.75   11.8   31.5
   166.59   2520   20.14   11.8   31.5
   166.76   2560   18.56   11   32.3
   166.88   2560   18.69   11.4   32.3
   167.01   2560   18.86   11.4   32.3
   167.13   2560   19.17   11.4   32.3
   167.3   2600   19.11   10.6   33
   167.43   2560   10.92   6.7   36
   167.55   2560   8.75   5.5   34.5
   167.68   2560   8.42   5.9   22.5
   167.84   2520   8.47   5.9   6
   167.97   2560   8.19   5.9   1.5
   168.1   2520   8.61   5.9   -3
   168.22   2560   8.56   5.9   -4.5
   168.39   2520   8.69   5.9   -4.5
   168.52   2520   8.72   5.9   -4.5
   168.64   2520   8.72   5.9   -4.5
   168.77   2480   8.69   5.9   6.8
   168.94   2480   8.36   5.9   -3.8
   169.07   2440   8.33   5.9   -5.3
   169.19   2440   8.61   5.9   -5.3
   169.32   2400   8.31   5.5   -5.3
   169.49   2400   8.33   5.5   -5.3
   169.61   2400   8.11   5.5   -5.3
   169.74   2360   8   5.5   -5.3
   169.86   2360   8.03   5.5   -5.3
   170.03   2320   7.94   5.5   -5.3
   170.15   2320   7.75   5.1   -5.3
   170.29   2280   7.81   5.1   -5.3
   170.41   2280   7.56   5.1   -5.3
   170.58   2200   7.5   5.1   -5.3
   170.7   2200   7.56   5.1   -5.3
   170.83   2160   7   4.7   -5.3
   170.96   2120   7.08   4.7   -5.3
   171.12   2080   6.81   4.3   -5.3
   171.25   2040   6.64   4.3   -5.3
   171.38   2040   6.58   4.3   -5.3
   171.5   2040   6.36   5.5   10.5
   171.68   2000   11.58   9   15.8
   171.8   2040   16.17   11   6
   171.93   2040   19.5   12.5   14.3
   172.05   2040   19.28   12.2   15.8
   172.22   2040   19.69   12.2   21
   172.34   2040   19.17   12.2   23.3
   172.47   2080   18.19   11.8   27
   172.6   2080   18.56   11.8   28.5
   172.76   2080   19   11.8   28.5
   172.89   2080   19.17   11.8   28.5
   173.02   2120   19.22   12.5   28.5
   173.14   2120   21.75   13.3   27.8
   173.31   2160   25.11   14.9   25.5
   173.44   2160   27.03   15.7   24
   173.56   2160   28   16.1   23.3
   173.69   2200   28.44   16.1   22.5
   173.86   2200   28.94   15.7   22.5
   173.98   2240   28.64   15.7   23.3
   174.11   2240   28.89   15.3   23.3
   174.23   2280   27.11   14.5   23.3
   174.4   2280   33.36   17.6   22.5
   174.53   2320   33.75   17.6   21
   174.65   2360   34.5   17.6   20.3
   174.78   2360   34.56   18   20.3
   174.95   2400   35.25   18.4   19.5
   175.08   2440   37.72   19.2   18.8
   175.19   2440   38.14   19.6   18
   175.32   2480   39.44   20   18
   175.49   2520   40.39   20   17.3
   175.62   2560   40.28   18.4   18
   175.74   2520   23   12.9   25.5
   175.87   2560   15.53   9.4   32.3
   176.04   2560   10.19   7.1   26.3
   176.17   2560   6.94   5.5   32.3
   176.29   2560   7.25   5.9   28.5
   176.42   2560   8.75   7.5   27
   176.58   2560   14.33   10.2   24.8
   176.71   2560   16.33   10.2   22.5
   176.84   2560   16.42   10.2   22.5
   176.96   2560   16.58   10.2   21.8
   177.13   2560   15.83   10.2   22.5
   177.26   2560   17.89   11.8   22.5
   177.38   2560   19.78   12.2   23.3
   177.51   2600   20.31   12.2   26.3
   177.68   2600   24.78   14.1   28.5
   177.8   2640   36.69   22.4   24
   177.93   2640   49.64   31   18
   178.05   2680   62.75   89.4   14.3
   178.22   2720   79.28   99.2   10.5
   178.35   2760   87.5   99.6   8.3
   178.47   2840   100.39   99.6   3
   178.6   2880   110   99.6   5.3
   178.77   2960   116.11   99.6   3
   178.89   3040   122.83   99.6   0.8
   179.02   3080   124.08   99.6   3
   179.14   3160   131.36   99.6   0
   179.31   3280   134.72   81.6   -2.3
   179.44   3280   34.5   21.6   -6.8
   179.57   3320   15.92   14.5   2.3
   179.69   3280   8.44   10.2   24
   179.86   3320   6.06   7.8   33.8
   179.99   3280   6.83   7.1   28.5
   180.12   3280   8.33   7.1   17.3
   180.24   3240   9.31   7.1   9.8
   180.41   3160   10.17   7.5   0
   180.54   3200   10.19   7.5   -3.8
   180.66   3120   10.75   7.5   -3.8
   180.79   3120   11   7.5   -3.8
   180.95   3080   10.92   7.5   -3.8
   181.08   3040   10.86   7.5   -3.8
   181.21   3040   11   7.5   -3.8
   181.33   3000   10.83   7.5   -3.8
   181.5   2960   10.86   7.1   -4.5
   181.63   2920   10.72   7.1   -4.5
   181.75   2880   10.64   7.1   -4.5
   181.88   2880   10.36   6.7   -4.5
   182.05   2840   10.22   6.7   -4.5
   182.17   2800   10   6.7   -4.5
   182.3   2760   9.92   6.7   -4.5
   182.42   2760   9.53   6.3   -4.5
   182.59   2680   9.53   6.3   -4.5
   182.72   2640   9.31   6.3   -4.5
   182.84   2600   8.97   5.9   -4.5
   182.97   2560   8.94   5.9   -4.5
   183.13   2480   8.5   5.9   -4.5
   183.26   2440   8.31   5.5   -5.3
   183.39   2360   8.25   5.5   -5.3
   183.51   2320   7.69   5.1   -5.3
   183.68   2240   7.64   5.1   -5.3
   183.81   2160   6.92   4.7   -5.3
   183.94   2120   7.03   4.7   -5.3
   184.06   2000   6.86   4.3   -5.3
   184.22   1800   6.17   3.9   -6.8
   184.35   1680   5.83   3.5   -7.5
   184.48   1560   5.33   3.5   -6.8
   184.61   1440   4.67   2.7   -6.8
   184.77   1280   3.86   2.4   -7.5
   184.9   1160   3.42   2.4   -8.3
   185.03   1040   3.25   1.6   19.5
   185.15   1000   3.47   2   13.5
   185.32   1000   3.47   1.6   -9
   185.45   960   2.86   1.6   -4.5
   185.57   920   2.78   1.2   -1.5
   185.7   920   2.78   1.2   -0.8
   185.87   880   2.81   1.2   -2.3
   185.99   840   2.75   1.2   -3
   186.12   800   2.75   1.2   -2.3
   186.24   800   2.75   1.2   -1.5
   186.41   760   2.64   1.2   0
   186.54   760   2.61   1.2   1.5
   186.67   760   2.58   1.2   0.8
   186.79   720   2.58   1.2   2.3
   186.96   720   2.56   1.2   4.5
   187.09   720   2.58   1.2   3
   187.21   720   2.58   1.2   3.8
   187.33   720   2.64   1.2   3.8
   187.5   720   2.89   1.2   1.5
   187.63   720   2.72   1.2   0.8
   187.76   720   2.75   1.2   0.8
   187.88   720   2.69   1.2   1.5
   188.05   720   2.69   1.2   2.3
   188.18   720   2.64   1.2   2.3
   188.3   720   2.69   1.2   2.3
   188.43   720   2.67   1.2   2.3
   188.59   760   2.75   1.2   1.5
   188.73   760   2.72   1.2   1.5
   188.84   760   2.78   1.2   1.5
   188.97   760   2.75   1.2   1.5
   189.14   760   2.78   1.2   0.8
   189.27   760   2.75   1.2   0
   189.39   760   2.75   1.2   -1.5
   189.51   760   2.72   1.2   -0.8
   189.69   760   2.92   2   -0.8
   189.81   760   3.31   1.6   -2.3
   189.94   760   3.08   1.6   -6
   190.07   760   3.03   1.6   -8.3
   190.24   760   3.03   1.6   -7.5
   190.36   760   3   1.6   -6
   190.49   760   2.94   1.6   -6.8
   190.61   760   2.92   1.6   -6
   190.78   760   2.89   1.2   -5.3
   190.91   760   2.83   1.2   10.5
   191.03   800   2.81   3.9   10.5
   191.15   800   6.22   4.7   12
   191.32   960   6.75   4.7   0
   191.45   1040   5.72   3.5   -1.5
   191.58   1080   5.22   3.5   4.5
   191.7   1080   5.14   3.5   9.8
   191.87   1080   5.36   3.5   21.8
   192   1080   5.53   4.7   24.8
   192.12   1080   7.11   6.3   24.8
   192.24   1080   10   7.5   24
   192.41   1240   10.06   7.5   24.8
   192.54   1280   10.39   7.8   25.5
   192.67   1280   10.83   8.2   25.5
   192.79   1280   13.14   10.2   22.5
   192.96   1280   14.03   11   19.5
   193.08   1240   14.36   11.4   16.5
   193.21   1160   14.33   11.8   14.3
   193.34   1080   13.97   11.4   11.3
   193.51   960   12.86   11.8   7.5
   193.64   1200   16.06   14.5   9.8
   193.76   1320   18.69   16.1   11.3
   193.88   1360   20.19   16.5   9.8
   194.06   1560   25.72   18.4   10.5
   194.18   1600   17.81   15.3   3.8
   194.31   1760   16.58   9.8   8.3
   194.43   1760   11.81   7.8   24
   194.6   1800   8.86   6.3   33
   194.72   1840   8.72   5.9   33
   194.85   1880   6.67   3.5   33
   194.98   1840   5.22   3.9   30.8
   195.15   1840   5.39   3.9   12
   195.28   1840   5.5   3.9   21
   195.4   1840   5.78   3.9   17.3
   195.52   1840   5.83   3.9   11.3
   195.69   1800   5.92   3.9   6.8
   195.82   1800   5.97   3.9   3.8
   195.94   1800   5.86   3.9   5.3
   196.07   1800   5.97   3.9   2.3
   196.24   1760   5.75   3.9   0.8
   196.37   1720   5.83   3.9   -0.8
   196.49   1720   5.83   3.9   -0.8
   196.61   1760   5.64   3.5   1.5
   196.78   1720   5.5   3.5   4.5
   196.91   1720   5.56   3.5   5.3
   197.04   1720   5.53   3.5   11.3
   197.17   1720   5.5   3.9   15
   197.34   1680   6.69   4.7   15
   197.46   1680   6.75   4.7   15
   197.59   1720   9.11   6.7   15
   197.71   1760   9.72   7.1   15.8
   197.88   1640   7.06   4.7   15
   198.01   1680   6.67   4.3   -2.3
   198.13   1680   6.17   3.9   -4.5
   198.26   1680   5.17   3.5   10.5
   198.42   1640   5.33   3.5   0.8
   198.55   1640   5.22   3.5   -2.3
   198.68   1640   5.17   3.5   -6.8
   198.8   1640   5.08   3.1   -7.5
   198.97   1600   5.17   3.1   -6
   199.1   1640   4.89   3.1   -7.5
   199.22   1640   4.92   3.1   -7.5
   199.34   1560   5.14   3.1   -6.8
   199.51   1600   4.92   3.1   -6.8
   199.64   1600   4.67   3.1   -5.3
   199.77   1520   4.97   3.1   -4.5
   199.89   1480   4.72   3.1   -4.5
   200.06   1520   4.42   2.7   -2.3
   200.19   1520   4.53   2.7   0
   200.31   1520   4.61   3.1   3.8
   200.44   1480   4.64   3.1   7.5
   200.61   1520   4.81   3.1   12.8
   200.74   1520   4.81   3.1   13.5
   200.86   1520   4.89   3.1   14.3
   200.98   1480   4.89   3.1   14.3
   201.15   1520   5.36   3.9   14.3
   201.28   1520   5.72   3.9   14.3
   201.4   1520   6.67   4.7   14.3
   201.53   1520   6.78   4.7   14.3
   201.7   1560   8.86   7.1   4.5
   201.83   1560   10.06   7.5   3.8
   201.95   1600   10.69   7.8   3
   202.07   1640   13.56   10.2   15
   202.24   1720   16.94   12.5   25.5
   202.37   1760   17.86   12.9   24.8
   202.5   1880   18.67   12.9   16.5
   202.62   1920   20.75   13.7   25.5
   202.79   2000   21.31   13.7   27
   202.92   2040   21.36   13.7   27
   203.04   2160   22.25   13.7   27.8
   203.17   2200   22.61   13.7   27.8
   203.34   2280   19.28   11.8   30.8
   203.47   2360   19.83   11.8   30.8
   203.59   2400   19.67   11.8   30.8
   203.71   2480   18.42   10.6   31.5
   203.89   2520   15.42   9   33
   204.01   2560   12.64   7.8   35.3
   204.14   2600   11.69   7.8   36
   204.26   2600   10.97   6.3   36.8
   204.43   2600   8.03   5.5   25.5
   204.55   2560   7.75   5.5   6.8
   204.68   2520   7.69   5.5   3
   204.81   2560   8.31   5.9   0
   204.98   2520   8.28   5.9   -4.5
   205.11   2480   8.47   5.9   -4.5
   205.23   2480   8.44   5.9   -4.5
   205.36   2480   8.25   5.9   12
   205.52   2440   8.28   5.5   -0.8
   205.65   2400   8.19   5.5   -5.3
   205.78   2360   8.06   5.5   -5.3
   205.9   2280   8   5.5   -5.3
   206.07   2080   7.33   5.1   -5.3
   206.2   1960   6.72   4.3   -5.3
   206.32   1840   6.25   3.9   -6.8
   206.45   1720   5.86   3.9   -7.5
   206.61   1560   5.5   3.5   -6.8
   206.74   1440   4.81   2.7   -6.8
   206.87   1320   4.22   2.4   -7.5
   206.99   1200   3.89   2   -8.3
   207.16   1040   3.64   2   14.3
   207.29   1000   3.33   1.6   -1.5
   207.41   1000   3.31   1.6   -5.3
   207.53   960   3.22   1.6   -3
   207.7   920   2.61   1.2   -1.5
   207.83   880   2.64   1.2   -0.8
   207.95   840   2.69   1.2   -0.8
   208.08   840   2.69   1.2   -1.5
   208.25   800   2.69   1.2   -1.5
   208.37   760   2.78   1.2   -2.3
   208.5   720   2.72   1.2   4.5
   208.63   720   2.72   1.2   3
   208.79   760   2.75   1.2   1.5
   208.93   760   2.78   1.2   1.5
   209.05   760   2.75   1.2   0.8
   209.18   760   2.72   1.2   0.8
   209.34   760   2.72   1.2   0
   209.47   760   2.75   1.2   1.5
   209.59   760   2.72   1.2   0.8
   209.72   760   2.75   1.2   1.5
   209.88   760   2.72   1.2   2.3
   210.02   760   2.75   1.2   1.5
   210.14   720   2.75   1.2   2.3
   210.27   720   2.78   1.2   2.3
   210.44   760   2.75   1.2   0.8
   210.57   760   2.75   1.2   1.5
   210.69   760   2.72   1.2   0.8
   210.81   760   2.75   1.2   1.5
   210.98   760   2.75   1.2   0.8
   211.11   760   2.81   1.2   0
   211.23   760   2.75   1.2   -0.8
   211.36   760   2.81   1.2   -1.5
   211.53   760   2.78   1.2   -1.5
   211.65   760   2.83   1.2   -1.5
   211.78   760   2.81   1.2   -2.3
   211.9   760   2.78   1.2   -1.5
   212.07   760   2.69   1.2   -1.5
   212.2   760   2.67   1.2   -0.8
   212.33   760   2.61   1.2   -0.8
   212.45   760   2.61   1.2   0
   212.62   760   2.58   1.2   0.8
   212.74   760   2.64   1.2   0
   212.87   760   2.64   1.2   0
Saintsteve
Re: B1 S1 -Too High (Rich) -VCDS Logs embeded - Please help!!!
« Reply #14 on: July 24, 2012, 07:37:41 pm »
I'm not sure.. That's almost impossible to make out, but looking and guesstimating, your timing seems extremely retarded, if I'm reading it correctly. Something's a miss...
Lots of low minus figures which isn't good. You need to try and organised or find someone that knows how to post in column format.
