Author Topic: B1 S1 -Too High (Rich) -VCDS Logs embeded - Please help!!!  (Read 4227 times)
Offline Rav2011
Re: B1 S1 -Too High (Rich) -VCDS Logs embeded - Please help!!!
« Reply #15 on: July 24, 2012, 09:15:55 pm »
Hi SaintSteve,
I've just sent you the VCDS log via email.
Don't forget I may not necessarily have been able to drive the car continuously in 4th or 5th gear (due to other drivers on the road!!).
I beleive that I should only be interested in air mass readings for 2500 RPM + only????
Please let me know what you think?
Offline Rav2011
« Reply #16 on: July 28, 2012, 12:29:30 pm »
Okay, replaced the MAF and the car does seem to be running smother but I still cannot get rid of this too rich error!!! :rolleye:
I am thinking of running some injector cleaner through the fuel system, just in case the injectors are clogged and causing a too rich condition.
I certainly have never run this procedure since i've had the car (2 years).
« Last Edit: July 28, 2012, 12:36:39 pm by Rav2011 »
Saintsteve
« Reply #17 on: July 29, 2012, 07:20:44 am »
What sparks have you got? Oem?
Offline Rav2011
« Reply #18 on: July 29, 2012, 11:32:24 am »
Denso Irridiums
Saintsteve
« Reply #19 on: July 29, 2012, 06:31:30 pm »
Offline Rav2011
« Reply #20 on: July 29, 2012, 07:23:31 pm »
Is there a performance decrease with OEM spark plugs?
Saintsteve
« Reply #21 on: July 29, 2012, 09:29:36 pm »
No..none fella
Offline Rav2011
« Reply #22 on: July 29, 2012, 09:58:19 pm »
Thanks fella
