Author Topic: Urgent help required with fuse layout pls  (Read 770 times)
Offline nadlad
  • GT Sport 08 140PS
« on: July 24, 2012, 03:20:02 am »
Just about got my car spot on until I took drivers door card off and once back on now the wing mirrors don't seem to work!
The switch lights up and it's definitely connected but there's no movement when I twist the knob.
I did disconnect and connect with ignition on so am thinking maybe I have blown the fuse however I am unable to find which fuse it is for the Wing mirrors in the fuse box pls can someone help cheers
Nad
Offline Statller-Stevo
Re: Urgent help required with fuse layout pls
« Reply #1 on: July 24, 2012, 07:34:28 am »
I don't think you'll have blown a fuse, the door mirror works through the window motor ( its called a door controller ) pop the door card back off and check you've not accidentally unplugged the mirror or caught a wire on something
Hope this helps you out
