Author Topic: Air Con Removal Guide anywhere?  (Read 3431 times)
h4rdy
« on: July 24, 2012, 12:06:13 pm »
Ok so my Air Con has never worked so to gain some flow to the THS IC, lose 10kg and apparently gain slightly from no pump to drive I am going to take the plunge.
Has anybody seen a guide anywhere?
I searched and noted that JonnyC has/had done it and TfsiMike has but want to do it myself.
Please no arguments as to why from newbies the reasons are above. I noted one of the other topics went this way.
I have a picture from Jonnyc's thread so know what needs to come off.
Thanks to all who reply :love:
h4rdy
Re: Air Con Removal Guide anywhere?
« Reply #1 on: July 24, 2012, 12:10:54 pm »
Looks like this little lot.
And does anybody know what the shorter belt number is now?
h4rdy
« Reply #2 on: July 24, 2012, 12:11:42 pm »
If there isn't one ill do one. :love:
Offline Statller-Stevo
« Reply #3 on: July 24, 2012, 05:35:58 pm »
Hi we removed Johns Herdys A/C & Mikes plenty of others too
The belt you need you can get from Euro-C-Parts
Their no : 202660555
Remember to seal the a/c expansion block up in the bulkhead so moisture cant get in
Hope this helps Jnr :happy2:
« Last Edit: July 24, 2012, 05:38:07 pm by Statller-Stevo »
h4rdy
« Reply #4 on: July 24, 2012, 07:11:41 pm »
Thanks very much I'll order now so when I am ready.
J
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: July 25, 2012, 09:25:53 am »
This may sound stupied but i take it you still get heat in winter if this is removed?.
h4rdy
« Reply #6 on: July 25, 2012, 09:40:11 am »
Apparently so, yes.
I am not sure if there is any coding to do but it doesn't work anyway so what's the difference.
Bloody Tourans has just packed up as well. Told I need a new pressure sensor but expect a pump as well.
That lasted 8 years so marginally better than 2-3. I couldn't tell you if it had it fixed before I owned the Golf though.
Offline gazon69
« Reply #7 on: July 25, 2012, 11:49:06 am »
Statller took mine off when i went stage 2+ well over a year ago now. Heater still works as it should. Hate aircon anyways and lets face it were not exactly in a country where we get blistering temps 6 months out of the year be lucky to get 6 days, windows down suffice. Good luck matey :happy2:
