Author Topic: Car feels sluggish after mot..,  (Read 2611 times)
Offline DarkSideJohn
« on: July 24, 2012, 06:21:06 pm »
Hey folks
Had my mot at the weekend just gone , passed with flying colours , except they noted I would need new front tires as they were rather worn , after inspecting myself I discovered this to be true , so I've got fresh rubber up front
Car feels kinda sluggish , doesn't seem to have that urgency it did before it went in.
In addition I don't feel as confident in the brakes , feels like I have to push the pedal a lot to get a response , vw did note that my rear brakes were worn to 70% could this be it ?
As well as noting they can find no history of a break fluid change
Any ideas folks ?
John
'04 GT TDI 140 | Remapped | Cold Air Intake | WALK | TBE
Offline keano
  • -Given: 79
Re: Car feels sluggish after mot..,
« Reply #1 on: July 24, 2012, 07:14:54 pm »
Do mot testers even lift the bonnet? It is more of a useless inspection than anything else.  It wouldn't have affected your car mate.  :happy2:
Offline gigolo456
« Reply #2 on: July 24, 2012, 07:15:01 pm »
Wats the temperature like up yr way today!?
« Reply #3 on: July 24, 2012, 07:20:37 pm »
Probably more of it being in my head to be honest
Could new front rubber , worn rear brakes and unknown brake fluid change affect performance ? or general feel
Its pretty much around the 25-27 degrees point today , not a welcome change , i prefer the cold myself
Offline gigolo456
« Reply #4 on: July 24, 2012, 08:07:41 pm »
Exactly, and so does a turbo-charged car! :-D
Offline Frenzy
  • -Receive: 29
« Reply #5 on: July 24, 2012, 08:42:44 pm »
Check psi in the front tyres as they are new. You'd hope whoever fit them would inflate them to correct psi but if you check at best it'll rule out a potential problem.
« Reply #6 on: July 24, 2012, 10:06:38 pm »
Its more the braking I feel more worried about
feels like I have to press the pedal rather hard to get a response , is this gonna be heat related or should it be a genuine concern ?
Offline Ree
« Reply #7 on: July 24, 2012, 11:36:37 pm »
May be air trapped in, try pumping the brake pedal with car off until its stiff ! The pedal that is !
The switch on and take a little drive !
« Reply #8 on: July 24, 2012, 11:41:21 pm »
Thanks for your suggestion Ree , I'll give that a try in the morning before my short 7 mile commute , hopefully it's nothing to worry about !
« Reply #9 on: July 25, 2012, 08:53:32 am »
Thank you for your suggestion Ree certainly seemed to work , pumped the brakes first thing , there was like a release of air then the pedal firmed up
Drive to work was a lot more confident , felt more like it use too !
Gonna get the rear brakes replaced at weekend and a brake fluid change as a mater of course
Plus being cooler this morning everything felt soooo much better , dunno what I was fretting about lol
« Reply #10 on: July 25, 2012, 09:05:41 am »
Hey folks
....Always put 'fresh rubber' (new tyres) on the back and move your used rubber to the front.
^ Sticky Vicky is SWMBO!
