Author Topic: Coding cruise control  (Read 2481 times)
Offline Yetisimon
« on: July 25, 2012, 04:48:20 pm »
Hi
My cars in having a service and cruise control fit by a vw dealer but I've just had a call saying there having trouble coding the cruise control just wounding if any body has come across his before ?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Coding cruise control
« Reply #1 on: July 25, 2012, 05:03:25 pm »
Incompetent franchised dealers, sadly yes  :jumping:
The only reason I can see they would be having a problem is if the steering controller is not suitable or if they've done something wrong.
What car is it?
Stu...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: July 25, 2012, 05:18:18 pm »
I see from your posts that it is a GTi Ed30 2007
Either the dealer has done something wrong or I bet your controller has 638 0070 HW SW
Maybe you should have used someone on here instead of using the dealers.
Cluster and Key coding
Location Great Yarmouth
Offline jedi-knight83
  • -Receive: 41
« Reply #3 on: July 25, 2012, 06:21:08 pm »
the ed30 2007 i did the other day was different to when i did my earlier caddy / golf.
Wouldnt let me into 'coding' section so had to do it via long coding.
all worked fine though.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: July 25, 2012, 06:24:50 pm »
if the coding is long, then the activation is in there otherwise it is in the coding II
Offline Yetisimon
« Reply #5 on: July 25, 2012, 09:22:10 pm »
The only reason I put it into a vw dealer is I couldn't find anyone in Kent area that could do it in time. But at the end of the day vw quoted one hour to do it so I'm only paying one hour !
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #6 on: July 25, 2012, 09:48:08 pm »
Wow. only?? 1 hour in my VW Dealer - 120 quid - thats cheap. I dont' know hows in Kent maybe cheaper. And 1 hour just for codding is a rip off.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: July 25, 2012, 09:54:09 pm »
A standard MK5 install can be done in circa 15mins.  An hour is giving themselves plenty of time.
Stu...
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #8 on: July 25, 2012, 10:20:24 pm »
True
For a tea time  :grin: :grin:
Offline Yetisimon
« Reply #9 on: July 25, 2012, 10:20:59 pm »
Hour to fit and code and they did say it would only take about 45 mins. There's problems with it now so it's down to them to sort it out !
