Author Topic: Changed all my bulbs for SuperWhite LEDs  (Read 110349 times)
Offline nadlad
  • GT Sport 08 140PS
Re: Changed all my bulbs for SuperWhite LEDs
« Reply #135 on: August 25, 2012, 08:39:11 pm »
My foot well LEDs are not working it's not the bulbs though must be the housing going try a diff connector in there
Saintsteve
« Reply #136 on: August 25, 2012, 09:08:46 pm »
Have you double checked you haven't got the LEDs in the wrong way around... ?
Offline Russ_leeds
« Reply #137 on: August 25, 2012, 09:33:55 pm »
X2 some only work a certain way!
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
« Reply #138 on: August 25, 2012, 09:49:08 pm »
You did use the canbus LEDs in the footwell didn't you?
As others have said, LEDs only work one way round  :wink:
Offline nadlad
  • GT Sport 08 140PS
« Reply #139 on: August 26, 2012, 12:35:03 am »
i bought hem off Matt here
I had canbus leds in them and they were working i am now using them for the sidelights so  left them disconnected for a couple of days till the same leds arrived in the post!
Problem now is but there not comign on i then tested the same leds in the map light and they worked so that rules the leds being faulty
the footwell lighting are on them clip style connectors  so i might try them in another location to actually see if the light housing is fecked such as the boot light then that will rule the housing out alternatively i have the door exit lights which use the same style connector so i may try them in the footwell just to check the wiring is ok
 unless theres a fuse for the footlights otherwise am not sure whats up with them it cant be a coincidence that both sides have stopped working all i did was take the leds out of there and use them for the sidelights
any help ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #140 on: August 26, 2012, 12:48:23 am »
try the light in a different plug
The diode could be loose
The footwell lights are switched on by the CECM
Cluster and Key coding
Location Great Yarmouth
Offline richtung
  • -Receive: 56
« Reply #141 on: August 26, 2012, 05:35:36 pm »
managed to finally get round to installing the interior LED bulbs.
The only problem i found was that the glove box light would work with 5SMD 501 W5W LED's (the same ones as the map lights). Tried flipping them over, tried a known working LED bulb, nothing.
However, tried the bulb for the foot well (8SMD CANBUS W5W LED) and it works... anybody else have this issue?
Rich
Offline nadlad
  • GT Sport 08 140PS
« Reply #142 on: August 26, 2012, 06:18:20 pm »
Mine did the same but I tapped/ banged the bulb holder from outside once in situe and it works now ave got issues with footwell lights even with halogens it ain't lighting up
Offline richtung
  • -Receive: 56
« Reply #143 on: August 26, 2012, 08:25:27 pm »
forgot to mention, one of the red LED lights (the ones near next to the map reading lights hadnt worked since i bought the car. Taking the light unit apart and re-assembling somehow has got it working again! Bonus!
Offline nadlad
  • GT Sport 08 140PS
« Reply #144 on: August 26, 2012, 09:07:37 pm »
Someone help me with the bastwRdddd footwell light what is going on everything else is fineeeeeeeee
Offline dalevr6
« Reply #145 on: August 29, 2012, 08:05:57 pm »
Received yesterday and fitted today, just waiting for complete darkness!
Offline jedi-knight83
  • -Receive: 41
« Reply #146 on: September 08, 2012, 11:48:39 pm »
did anyone confirm the puddle lights were indeed 8SMD W5W LEDs?
« Reply #147 on: September 09, 2012, 12:46:21 am »
I can't help matey, I don't have the puddle lights  :sad1:
(well not those ones in the mirrors)  :wink:
Offline Grande_GTi
  • -Given: 41
« Reply #148 on: September 10, 2012, 12:03:19 pm »
Fitted mine and my brothers the other days
Props to matt for putting the kit together
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
  • -Receive: 41
« Reply #149 on: September 11, 2012, 11:39:16 am »
by the way... my 55 plate gti has 3 lights up front.
the headlining (with all lights etc) I picked up for my friend from a 07 golf only has 2 lights up front.
Strange.
