Author Topic: Downpipe with stock catback  (Read 3714 times)
Offline crafto
« on: July 26, 2012, 11:27:47 am »
Hi folks,
Looking for some advice, has anyone fitted a downpipe but kept the oem catback system? I have read that the main restrictions are in the downpipe and that the stock catback should still be OK for stage 2. Also is an uprgaed axuhaust system a must for stage 2 as I have also read that a cat back upgrade will not give a huge gain and a urbo back is the prefered option? Would a pre-cat delete may be wowrthwhile?
I have an edition 30 and am looking to upgrade to satge 2, also how acceptable will the nise levels be when at mortorway cruising speeds? Excuse my lack of knowledge but any info would be appreciated.
Cheers.
Offline dan930
  • -Receive: 56
Re: Downpipe with stock catback
« Reply #1 on: July 26, 2012, 11:53:05 am »
Hi folks,
Cheers.
I had a milltek highflow sportscat connected to oem backbox..u get a little bit more noise & with a remap there are big gains..hope this helps mate
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline chungster
« Reply #2 on: July 26, 2012, 06:01:01 pm »
High flow DP with stock cat back is ok.
Stage 2 does need DP to take advantage of the code. Otherwise stage 1 can cater for all other mods excl DP / HPFP mods
Offline ashw831
« Reply #3 on: July 30, 2012, 09:07:41 pm »
Sorry to hijack!!
What are the gains you ae likely to get from a decat to a standard exhaust system, also with some sort of induction upgrade on a normal GTI?
Offline Mark_eire
  • Dublin, Ireland
« Reply #4 on: July 31, 2012, 07:57:47 pm »
I've got a 3'' blueflame DP and decat on my vRS mated to standard cat back and on a stage II custom map have got 260bhp
2010 Audi A6 Avant S-Line
2007 VW Golf GTI
Offline GLIDN
« Reply #5 on: August 01, 2012, 04:15:22 am »
been running ATP 3" CATLESS downpipe, Soon to be replaced by APR Downpipe. Still keeping factory CAT-Back. Made less then 10kw's on Dyno mk5. But a nice jump on MK6 however.
Sounds great little bit noiser. Over all great sound. And looks Standard. Win Win I would say.
Offline ashw831
« Reply #6 on: August 02, 2012, 07:50:19 pm »
Hmm.. So the noise doesn't really change too much? How do we get pops and bangs on these? Mine caccles and pops now on standard, is that normal?
Are the performance gains with having a performance catback worth the extra expense?
Offline GLIDN
« Reply #7 on: August 07, 2012, 06:19:35 am »
You will get a nice sound on the go pedal as well as high revs when you are slowing down with gears. But driving like miss daisy, you would not know the car is any different to a stock car.
Maybe a slight increase in idle.
Offline ashw831
« Reply #8 on: August 08, 2012, 09:11:18 pm »
Awesome, may invest soon.. Wheels and tyres first! :-(
