Author Topic: Knocking noise from back of my Gti  (Read 1228 times)
Offline zabba
« on: July 26, 2012, 01:57:18 pm »
I've got an annoying knocking sound from the back of my gti somewhere and looking for some advice on what it might be.  It's an 05 plate with 65k on the clock
Difficult to describe but sounds similar to what you would hear if the tailgate wasn't closed properly.  Tends to occur mostly at speeds under 50ish and more so when lifting off or braking.
It's definitely not the parcel shelf balls as it still occurs when the shelf is out.  Could it be droplinks?  how would I check?
Only had the car a month, and it's spoiling what is otherwise a great car!
Offline gigolo456
Re: Knocking noise from back of my Gti
« Reply #1 on: July 26, 2012, 02:00:46 pm »
x 2, but mine only happens when engine is up to temperature, and has only happened since i changed by exhaust, but whatever it is, IT'S DRIVING ME CRAZY!! As you say, it can only be likened to the boot not being closed properly!!  :sad1:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #2 on: July 26, 2012, 02:01:16 pm »
I'd say droplinks or top mounts...
Diesel Daily Hack.
Offline gigolo456
« Reply #3 on: July 26, 2012, 02:05:21 pm »
are both of those not primarily at the front of the car?? I had my front droplinks changed when my car failed it's MOT back in April, well that and the CV boot....
Offline zabba
« Reply #4 on: July 27, 2012, 08:44:18 am »
Good to know it's not just me with this problem!  I think mine also happens only when up to temperature, as when it was at VW last week for a service I asked them to look at it, and of course it didn't make the noise!  presumably because it hadn't warmed up
Offline gigolo456
« Reply #5 on: July 27, 2012, 09:06:35 am »
Has yours got a stock exhaust or aftermarket? :-o
Offline zabba
« Reply #6 on: July 27, 2012, 03:27:13 pm »
I've got the stock exhaust, but as your problem has only started since you got the exhaust changed, maybe I'll get mine checked to see if it's the source of the noise!
Offline gigolo456
« Reply #7 on: July 27, 2012, 04:28:25 pm »
Will be interesting to hear if you discover wat it is, ive just had a 25 mile journey, and yeah, knocking was bak, seems perhaps to b more apparent when the steering wheel is turned slightly, not sure though, but definitely eminates from boot area or under it! Must be the exhaust once hot, otherwise surely it would b there when cold also!? :-o
