Author Topic: Heat Soak Symptoms  (Read 1731 times)
Offline johnhol78
Heat Soak Symptoms
« on: July 26, 2012, 05:54:12 pm »
Can anyone tell me the symptoms of heat soak??
If the air filer hose had snapped the brackets near the front grill and was pointing down towards engine - in 30 degree heat and traffic - would this cause heat soak?
Low rev seems ok bit slow but over 3000rpm it's not pulling at all or revving that much. No data logs as having issues logging - just wanted to know the heat soak symptoms
Offline john87
  • -Receive: 53
Re: Heat Soak Symptoms
« Reply #1 on: August 01, 2012, 12:10:07 pm »
The main symptoms of heak soak are loss of power and reduced throttle response, but this is caused by the lack of power. Warmer air = less oxygen per given volume = less 'bang' when fuel is ignited  :happy2:
