Author Topic: Air Con & Fuel.....  (Read 5162 times)
Ifti
Air Con & Fuel.....
« on: May 30, 2009, 09:05:38 pm »
A [stingy] mate of mine told me that he didnt use air con very much since it used fuel?
Is this correct? If so, how much fuel can having your air con switched on possibly use??
Offline v2brett
Re: Air Con & Fuel.....
« Reply #1 on: May 30, 2009, 09:11:00 pm »
it will use a bit more, not sure on the exact figure but i can remember JC on topgear saying a civic will do 6mpg less if the aircons on  :confused: :confused:      but i think the bigger the engine the less fuel it will use as its not struggling as much.   IMO its worth the fuel :driver:
Still Here!
« Reply #2 on: May 30, 2009, 09:39:27 pm »
I recon it's about 2mpg difference on my car...
Offline vwrascal
« Reply #3 on: May 30, 2009, 10:56:18 pm »
deffo worth the extra vpower wasteage today, I was cooler than zac efron holidaying in the antarctic  :chicken:
Ifti
« Reply #4 on: May 31, 2009, 11:09:30 am »
I really didnt think it used that much. I have had the air con on recently, and have been getting around 2-3mpg lower then usual, on a normal run. I actually thought somet was wrong initially, but forgot about having the air con switched on! lol
Offline JonnyG
  • Golf R
« Reply #5 on: May 31, 2009, 11:16:52 am »
There was a post a while ago with someone complaining about low mpg
They were advised to try not using AC, heated seats etc
I think there mpg went up by about +3mpg as a result   :happy2:
Golf R, 5dr, DSG, March 2010, Rising Blue, 19" Talladegas, Cruise
Ifti
« Reply #6 on: May 31, 2009, 01:13:23 pm »
I thought heated seats and AC etc used battery power.
Why do they consume fuel as well?
Offline BeezerDiesel
  • -Given: 33
« Reply #7 on: May 31, 2009, 01:19:24 pm »
The aircon is a mechanical unit driven by a belt, this it makes drag on the engine. The aircon blower is electric as are the heated seats and rear window/mirrors etc. If these draw a charge constantly they will be draining the battery which in turn will need extra juice from the alternator. The alternator like the aircon compressor is also driven by the engine.
Combined, that's a wee bit of fuel usage that's not going to the wheels.
Unscientific answer I know but you get the drift.
Andy
7R
Ifti
« Reply #8 on: May 31, 2009, 01:25:53 pm »
Yup I get it now, cheers  :wink:
Offline winrya
« Reply #9 on: May 31, 2009, 05:07:15 pm »
But you also have to consider that the fuel consumption increases by 10% with the windows open  :happy2:
Offline bennylenny88
  • needs moar lowwww
« Reply #10 on: May 31, 2009, 05:50:22 pm »
my mpg goes down straight away  :rolleye:
Offline neg
  • gone old skool
« Reply #11 on: May 31, 2009, 06:00:04 pm »
I read somewhere its like carrying another passenger - not the end of the world on days like today but when its not needed I always put mine on ECON.
Ifti
« Reply #12 on: May 31, 2009, 06:04:38 pm »
I always put the air con on rather then drive with the windows down at a higher speed - the wind noise does my head in!
However, like the above, I usually have it on ECON and only use air con when its a really hot day, or when I have the kids in the car.
Offline Steve82
« Reply #13 on: May 31, 2009, 06:12:11 pm »
Same as myself, use it on Econ most of the time unless its a very hot day!
Offline Jules86
  • -Receive: 46
    • Forumwars
« Reply #14 on: May 31, 2009, 06:16:17 pm »
Aircon is better for fuel consumption than leaving the windows open  :happy2:
If anyone watches mythbusters they tested it thoroughly and aircon won  :wink:
