Author Topic: Help car vibrating  (Read 2064 times)
Offline benjii
Help car vibrating
« on: July 26, 2012, 09:14:37 pm »
Just went out in my car and pulled on to the dual carriageway and all of a sudden the car made a horrible noise and there vibration in everything pedals, seats, steering wheel. The clutch engages and still has a biting point, the gearbox still goes in gear easy, there still boost and car drive fine but a horrible noise and really bad vibration
Offline edd666999
  • -Receive: 89
Re: Help car vibrating
« Reply #1 on: July 26, 2012, 09:16:18 pm »
cambelt done recently?
Offline Apollo
  • Middlesbrough
« Reply #2 on: July 26, 2012, 09:16:43 pm »
What sort of noise and where from.....possible engine mount gone?
Offline benjii
« Reply #3 on: July 26, 2012, 09:23:28 pm »
Cambelt was done in november, all I can explain about the noise is somthing hitting rubber the noise gets louder the faster I go same as the vibration and if it helps with the handbrake up just lifting the clutch to biting point the car vibrates alot
Offline gigolo456
« Reply #4 on: July 26, 2012, 09:48:31 pm »
When was the last time u had yr wheels balanced? If out, that can cause the steering wheel to vibrate, and pedals too if I remember correctly!?
Offline edd666999
  • -Receive: 89
« Reply #5 on: July 26, 2012, 09:49:02 pm »
personally wouldn't drive it if the noise gets worse the faster you go...
Offline benjii
« Reply #6 on: July 26, 2012, 10:12:46 pm »
It's not balanced wheels as its much more Vibration no definitely not driving it, it's locked up in my mates garage for him to solve  :signLOL: he reckons maybe just a pipe banging or an exhaust mount hopefully nothing more
Offline benjii
« Reply #7 on: July 27, 2012, 06:32:22 pm »
Well he test drove it broke down and oil light on now said he thinks the car gonna be in for a good week great no car for me
Offline Baz300
« Reply #8 on: July 27, 2012, 07:09:02 pm »
Dual mass flywheel? Does the noise get louder with revs or speed?
I had one go on a focus diesel
Saintsteve
« Reply #9 on: July 27, 2012, 07:11:37 pm »
Broken engine mount?
Offline benjii
« Reply #10 on: July 27, 2012, 07:47:13 pm »
Not sure at the moment as at 6 they were just taking the bumper off etc to see we're the noise is coming from but there finished now . head mechanic reckons its an oil pump as the car showing up an oil light but his still not 100% sure. Thanks for the help guys I'll keep you updated lucking aa warranty comes in handy
Offline benjii
« Reply #11 on: July 27, 2012, 07:52:00 pm »
It could well be yes it gets louder just with speed as when lifting off throttle the noise gets quiter the slower I go only thing what's confusing me its showing up on dash as an oil problem Hopefully my friend sticking it on diagnostics computer to see what the code is
Offline benjii
« Reply #12 on: July 28, 2012, 09:54:11 pm »
Bump
Been looking at faulty oil pump would the symptoms be the same how much damage will a broken one cause and how much to replace
« Reply #13 on: July 28, 2012, 11:05:28 pm »
Bump
If the oil pump is fubared then lack of lubrication can be deadly to the engine and turbo...
Offline benjii
« Reply #14 on: August 01, 2012, 05:02:42 pm »
Well little update the engine is in pieces and has got burn marks to the cylinder head so looks like engine rebuild does anyone no rough cost for an engine rebuild
