Author Topic: Ceramic paint for exhaust?  (Read 2586 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=4im1ksuhr09kut8uo7g7fr1j2d&/topic,19740.0.html
« on: July 27, 2012, 09:40:44 am »
As above.
I want to get my exhaust coated black (like uncle robins). Is there anything you can buy off the shelf to do this or is it a professional job only?
Rich
Re: Ceramic paint for exhaust?
« Reply #1 on: July 27, 2012, 10:25:17 am »
Just set your revo fuelling to 1 and those tips will soon blacken up...   :laugh:
AA
« Reply #2 on: July 27, 2012, 12:26:11 pm »
 Ive used Rustoleum (not ceramic) before with very good results.
 iirc its called hat paint?? and costs about a tenner for 500ml
EDIT  Its actually called Hardhat
« Last Edit: July 28, 2012, 12:54:13 pm by AA »
« Reply #3 on: July 27, 2012, 01:07:24 pm »
A pic of 'Uncle Robin's ceramic coated tips for reference:
These are factory coated as supplied by Milltek. I'm not sure if they are an offered option.
Ceramic coatings are very easy to clean with a non-abrasive cream (I use Megs NXT) and also the tips are cold to the touch even after a long spirited drive of several hundred miles.
I don't know about how successfully a ceramic paint can be applied - In ignorance I would imagine the ceramic coated to be done under heat.
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: July 27, 2012, 01:52:21 pm »
Seach plasma coatings on google.  Ceramic coating isnt usually smooth but an abrasive surface.
Hycote do a very high temp paint that should last well on the tips.
Follow AKS tuning on Facebook
« Reply #5 on: July 27, 2012, 03:22:43 pm »
Would that Hycote be matt or gloss Alex?
« Reply #6 on: July 27, 2012, 04:06:35 pm »
Search plasma coatings on google.  Ceramic coating isnt usually smooth but an abrasive surface.
....Mine is most definitely very smooth (no texture whatsoever) and satin finish - Neither matt nor gloss. I'll be talking to Milltek soon-ish and I'll try to remember to ask for more info.
Previous to this I was testing a black powdercoated finish for them and it grey'd up quite badly in the winter conditions, so we decided to try the ceramic and it is now in it's third year.
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: July 27, 2012, 10:21:17 pm »
I'm sure they do a satin finish.
« Reply #8 on: July 28, 2012, 12:32:44 am »
I'll look into it. I'm getting bored polishing my exhaust and it getting sooted up after 2 miles.
  • -Receive: 427
« Reply #9 on: July 28, 2012, 11:25:54 am »
How's about gold?  :laugh:
Offline Powervalve Nige
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #10 on: July 28, 2012, 09:07:17 pm »
It's done by Camcoat in warrington.
'57' varieties of colour available, we've used satin and gloss both are excellent options.
Nige
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #11 on: July 28, 2012, 09:41:15 pm »
I take it they have to remove the exhaust for this and it's not just sprayed on from a can :laugh:
Would there be any benefit to having a DP coated in it before installation Nige?
« Reply #12 on: July 28, 2012, 09:45:21 pm »
 :grin:
Nope! all you have to do is switch the engine off, a guy lies down underneath and applies a coat. You then switch the engine back on to dry the coat and repeat the process.  :innocent:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #13 on: July 28, 2012, 09:46:29 pm »
Would it not be quicker if you had the engine running all the time so it dries on contact, therefore speeding the process up?  :happy2:
« Reply #14 on: July 28, 2012, 09:49:59 pm »
Again, nope! i suggested this to the guy with the spray can and he just laughed at me and called me a fool.  :rolleye:
