Author Topic: MKV K03 advice  (Read 6670 times)
Offline drsilviuro
Re: MKV K03 advice
« Reply #15 on: August 13, 2012, 07:36:29 am »
This is my stage 2 with 649 settings.
Offline Just_quietly
Re: MKV K03 advice
« Reply #16 on: August 13, 2012, 11:26:44 am »
This was the best setting after many logs. Timing pull almost zero and everything matches with requested.
I run 98 ron pump gas. No wmi.
How much boost is B9? B7 for my car is around 23psi. If you run your car at fuel 9, is that a lean fuel setting for you or rich? I'm confused, are all cars different they way they respond to settings?
Sorry for all the questions. I'm really intrigued with your settings and results.
Offline edd666999
  • -Receive: 89
Re: MKV K03 advice
« Reply #17 on: August 13, 2012, 12:11:49 pm »
from all the 2+ revo cars i have seen his settings are very high. but he says he has logged his car so must be ok.
Re: MKV K03 advice
« Reply #18 on: August 13, 2012, 01:02:51 pm »
I ran a 13.9 and 103mph (60" was 2.2sec manual) last week in full street trim and full tank of gas not knowing I was going to run. (I have very persuasive friends). I'm going try slicks and much less fuel next time. We'll see what happens.
Re: MKV K03 advice
« Reply #19 on: August 13, 2012, 02:25:14 pm »
I wonder why both previous RR graphs seem devoid of any torque spike ...
Offline drsilviuro
Re: MKV K03 advice
« Reply #20 on: August 13, 2012, 04:57:43 pm »
This is one of my logs with 959
Re: MKV K03 advice
« Reply #21 on: August 15, 2012, 04:54:36 am »
Excuse my ignorance but how can you tell with these values whether you are pulling timing?
Where's knock correction?
Re: MKV K03 advice
« Reply #22 on: August 15, 2012, 10:26:43 am »
He hasn't shown any block 020 logging so there is no way to say what his CFs are from those logs.
Offline drsilviuro
Re: MKV K03 advice
« Reply #23 on: August 15, 2012, 03:11:14 pm »
On the same 959 setting.
Re: MKV K03 advice
« Reply #24 on: August 16, 2012, 11:42:30 pm »
Thanks. That's what I was talking about. Great logs. Your car is a mystery. Glad it's working out for you. I must have a boost leak because my actual to specified boost is a lower. 15-20hp low who knows. Bloody cars!
