Author Topic: RNS510 Maps / Postcode search  (Read 6700 times)
Neil
« on: July 29, 2012, 09:19:01 am »
I have a version `b` RNS510 unit with V7 maps, now there seems to be conflicting stories regarding firmware to enable V8 maps.
I`ve no idea of what firmware I have as holding down the setup button doesn`t show it. I have searched for info. and read that I can just install V8 maps and all will be fine and also read that a firmware update would also be required. The car is `06 with the original canbus and I have no battery drain issues.
My main issue is that I want the latest maps so I gain the full postcode search as the postcode search I have is next to useless, infact it is usless as I`m back to using a 6 year old Garmin which is so much better. The RNS510 is fine when you need to go to ie. 12 Front St, York, YO2 3.. but most of my searches are for farms and places in the countryside and the darn RNS is taking miles away from where I should be so I really need full postcode search.
So can someone confirm would installing the latest V8 maps give me full postcode search whatever firmware I have or is a certain firmware required?
Thanks.
vw55raz
Re: RNS510 Maps / Postcode search
« Reply #1 on: July 29, 2012, 09:40:01 am »
V8 maps would give you 7 digit postcode search. But you would need a certain minimum fw version as well.
Try the modified 2760 which will prevent battery drain.
Sorted :)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #2 on: July 29, 2012, 09:46:40 am »
For 7 digit search you need:
268x or higher firmware AND V7 or higher maps  :happy2:
Offline bakili
Re: Re: RNS510 Maps / Postcode search
« Reply #3 on: July 29, 2012, 09:51:50 am »
I have B version running 4020 firmware with V8 maps. I had it for 2 weeks now, no issues so far.
Sent from my HTC One
Neil
« Reply #4 on: July 29, 2012, 10:11:29 am »
Thanks for the quick replys boys  :happy2:
You`ve just verified what I though, I`ll need a newer firmware.
I was just hoping to get away with the easy solution of loading V8 maps, firmware might be a bit beyond my capabilities.
Off to search . . .   :smiley:
Neil
« Reply #5 on: July 29, 2012, 10:15:14 am »
I`m just about to read through your sticky at the top of the page  :happy2:
vw55raz
« Reply #6 on: July 29, 2012, 10:25:18 am »
Just remember If your currently on a fw lower than 1xxx and you update the maps and then update the fw then it will delete the maps partition.
I'll do the fw first. And then the maps
Offline po_138
« Reply #7 on: July 30, 2012, 01:10:50 pm »
Dam
Just done upgrade v7 maps, still only 4 digit postcode. Fw showing 0900.
Which fw do you recomend?
vw55raz
« Reply #8 on: July 30, 2012, 01:13:19 pm »
Dam
http://vwnavi.com/volkswagen-factory-fit-navigation-systems/rns-510-mfd3-navi-system/firmware/13672-unofficial-272x-software-swl-recovery-cd.html
modified 2760 for a/b/c units
Offline po_138
« Reply #9 on: July 30, 2012, 01:29:05 pm »
Can't download from that site.
Any other ways?
Offline po_138
« Reply #10 on: July 30, 2012, 01:32:02 pm »
sorry done
vw55raz
« Reply #11 on: July 30, 2012, 01:33:02 pm »
Any other ways?
Which version unit do you have? Also what year car?
If you have a 2008 you may have a newer canbus and you can update to any firmware.
If you have an older canbus you would need modified fw. It's on that page I posted. How come you can't download from there?
Offline po_138
« Reply #12 on: July 31, 2012, 11:10:08 am »
How do u get RNS info again?
vw55raz
« Reply #13 on: July 31, 2012, 11:14:24 am »
There should be a sticker on top of the unit stating the part number.
If you don't have access to it then you could activate the secret menu using vcds and hold setup button for 10 seconds and that will give you all the info you need.
Offline po_138
« Reply #14 on: July 31, 2012, 11:21:30 am »
Car is 2008 gt tdi with highline. I think version B.
This scan I got from Omeydz on Sunday
VCDS Version: Release 10.6.5
Data version: 20110930
Sunday,29,July,2012,23:16:39:36219
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 FC HW: 03G 906 018 FC
Component: R4 2.0l PPD1.2 1879
Revision: --H52--- Serial number: VWX7Z0H63NG8SE
Coding: 0000078
Shop #: WSC 01279 785 00200
VCID: 6BD040C6331E
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 T HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1810
Revision: 04843012 Serial number: 00000805211083
Coding: 0000020
VCID: 234068E69B4E
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 163B600D092800FC681106E7901D0082B100
Shop #: WSC 01316 785 00200
VCID: 75E466BE655A
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 77F86CB67F56
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008464822
Coding: E78B8F2700041500471400001400000000197F075C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 336098A62BAE
Part No: 1K2 955 119 E
Component: Wischer 300608 021 0501
Coding: 00038805
Shop #: WSC 00000
Part No: 1K0 955 559 AH
Component: RLS 140708 054 0402
Coding: 00209069
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC1SF5V%
Coding: 0013112
Shop #: WSC 01357 011 00200
VCID: 3D74BE9E1DEA
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0001604
Shop #: WSC 12345 123 12345
VCID: 7AFE75824C44
Part No: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Shop #: WSC 00000
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 974 B HW: 1K0 920 974 B
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H63NG8SE
Coding: 0007403
Shop #: WSC 00513 210 90439
VCID: 2D548EDECD8A
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 060708F1000564
Coding: ED807F064002020003
VCID: 3564A6BE25DA
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2416
VCID: 2D548EDECD8A
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 B HW: 1T0 035 680 B
Component: RNS-MID H03 0900
Revision: AB001001 Serial number: VWZ6Z7H9200095
Coding: 060004000400001200
ASAM Dataset: ------------------------- ------
VCID: 2D548EDECD8A
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 194
Mileage: 120704 km
Time Indication: 0
Date: 2000.00.00
Time: 20:23:19
Address 42: Door Elect, Driver Labels: None
Part No SW: 1K0 959 701 AK HW: 1K0 959 701 AK
Component: Tuer-SG 006 1204
Coding: 0000692
VCID: 77F86CB67F56
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A5E85C2FC64
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 999002005103487F2D02840570085FC690FC00
VCID: 83008866BB8E
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: None
Part No SW: 1K0 959 702 AK HW: 1K0 959 702 AK
Coding: 0000692
VCID: 78FA6F8A7248
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2D548EDECD8A
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 194
Mileage: 120704 km
Time Indication: 0
Date: 2000.00.00
Time: 20:23:19
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 01279 785 1012552
VCID: 387AAF8A32C8
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
VCID: 397CAA8E09C2
End ---------------------------------------------------------------------
Sunday,29,July,2012,23:17:14:36219
Control Module Part Number: 02E 300 050 T
Component and/or Version: GSG DSG AG6 431 1810
Software Coding: 0000020
Work Shop Code: WSC 01279
VCID: 234068E69B4E
Advanced Identification
Identification: TFK-030
Revision: 04843012
Date: 21.05.08
Manufacturer number: 1083
Test stand number: 8503
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00200 785 01324
Flash Date: --.--.--
Software
000X
Misc.
Hardware number: 02E 927 770 AJ
Lot Number: E10
Type Lock: 0002
VCDS Info:
