Author Topic: RNS510 Maps / Postcode search  (Read 6698 times)
vw55raz
Re: RNS510 Maps / Postcode search
« Reply #15 on: July 31, 2012, 11:48:15 am »
You have a newEr canbus gateway so you should be fine. No battery drain. I would install fw 3800. I personally don't like the 4xxx firmware as you can't change your route on the navigation whilst driving. You would have to pull over to input a new destination.
Offline po_138
« Reply #16 on: July 31, 2012, 12:00:25 pm »
Will I lose the V7 maps?
Or I have to reinstall?
Offline po_138
« Reply #17 on: July 31, 2012, 12:06:46 pm »
Sorry where can I find 3800fw. 3810fw is on that site
vw55raz
« Reply #18 on: July 31, 2012, 12:32:24 pm »
you will have to reinstall the maps and music on the hard drive.
ill try finding a download link for you
vw55raz
« Reply #19 on: July 31, 2012, 12:35:42 pm »
Offline po_138
« Reply #20 on: July 31, 2012, 01:15:19 pm »
Can I save my music on to sd?
vw55raz
« Reply #21 on: July 31, 2012, 02:28:07 pm »
im not sure.you can give it a try.
 i normally just copy from my laptop to sd card and then onto the hard drive. never tried copying from hard drive to sd card
Offline po_138
« Reply #22 on: July 31, 2012, 02:48:18 pm »
Previous owner left Now69 on there :drool:
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #23 on: July 31, 2012, 03:06:29 pm »
3810 is fine
http://depositfiles.com/files/gbtlf3s2i
Be carefull with this link guys. To download it u need to send a text to some number which cost u £1.50. After that u will receive few texts a week telling u ur subscribtion is prolonged and for each receiving text u will be charge £1.50 again
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
vw55raz
« Reply #24 on: July 31, 2012, 03:20:17 pm »
I downloaded it fine. Just clicked on regular download :)
  • -Receive: 291
« Reply #25 on: July 31, 2012, 03:21:18 pm »
There's a big window which comes up. Close the window by clicking on the x in the top right.
Offline po_138
« Reply #26 on: July 31, 2012, 04:11:14 pm »
That was the easy bit. Its trying to burn it on to disk
