Author Topic: Fitting a RCD510 and Security Code  (Read 12750 times)
Offline GLIDN
Re: Fitting a RCD510 and Security Code
« Reply #15 on: February 17, 2014, 01:14:17 am »
I'm looking to sell the RCD510 that came with my MK6 as standard.  Is there an easier way to get the code rather than contacting the dealer?
if you cant get the code from the seller, let me know. I can point you in the direction to someone who can get them.
I'm afraid not. Unless you sell the radio with no code, but provide the buyer with your Vin and radio's serial number (on the unit).
Offline paul_mck
« Reply #16 on: February 19, 2014, 08:26:17 pm »
slightly related question. I bought an RCD510 to replace my RCD300 and I have the code ok, but if I remove it later and put the 300 back in will it ask for that code again? as I don't have it, just the one for the 510.
cheers.
Offline paul_mck
« Reply #17 on: February 19, 2014, 08:46:29 pm »
wow I have no patience. yes it works fine. put 510 in, entered code. removed 510 fitted 300. worked fine, didn't ask for code.
