Author Topic: Fitted new a.p brakes (not without drama)  (Read 8060 times)
Offline alackofspeed
  • -Receive: 24
Re: Fitted new a.p brakes (not without drama)
« Reply #30 on: August 01, 2012, 06:05:24 pm »
The fact these brakes fit under 17" stock wheels make them them an appealing upgrade.
What are the dust / weather seals like on these?
Offline gazon69
« Reply #31 on: August 01, 2012, 06:26:29 pm »
Right, done a few miles with the brakes now and all i can say is wow. The more i seem to be using them the better they are getting. Pedal feel is exceptional very oem like but once pressed hard, more than capable of stopping you at good speeds. Low dust levels up to now, probably better than the pads that were on before. With the hardware that is on my car now i fancy doing a track day just to put them through their paces properly. I will do another update probably in about another week. :happy2:
Offline drsilviuro
« Reply #32 on: August 02, 2012, 12:35:02 am »
Will these fit under 17" with no spacer?
....If this is the same size kit which AP fiited on mine, then yes. AP used my car to test the fit:
Mighty fine brakes - Very even and progressive feel, powerful without any snatching, and even better balanced when S3/R32 OEM brakes are fitted to the rear (Mk5 GTI).
Can you please tell me what are the codes for calipers and discs?
Offline drsilviuro
« Reply #33 on: August 02, 2012, 12:36:40 am »
+1
« Reply #34 on: August 02, 2012, 07:40:24 am »
....Over 80,000 miles since 2006 on mine without issue.
« Reply #35 on: August 02, 2012, 07:51:49 am »
....My AP kit # is CP5200-1056 but the newer version which gazon has fitted will probably be a different #.
Offline gazon69
« Reply #36 on: August 02, 2012, 08:30:56 am »
have you ever had yours rebuilt robin or serviced. If not i suppose thats an added bonus
Offline drsilviuro
« Reply #37 on: August 02, 2012, 08:58:11 am »
RedRobin is this your kit? http://www.apracing.com/product_details/road_car_upgrades/formula_big_brake_kits/vw/golf_mk5_gti_and_tdi-front_4_piston_kit_cp5200-1056.aspx
Here at specification states that only 18" & 19" fit.
@gazon Do you know if it's the same part number of the caliper?
« Last Edit: August 02, 2012, 09:11:07 am by drsilviuro »
Offline gazon69
« Reply #38 on: August 02, 2012, 10:47:15 am »
Not sure of the part no as this wasn't advertised in the sale thread and as said, they have been sat in my garden shed for the last 6months, sorry i cant help with any more info, the best person to ask would be daveb, he sent them to me, they purchased from brian "gobbleplease" hth
« Last Edit: August 02, 2012, 10:49:19 am by gazon69 »
« Reply #39 on: August 02, 2012, 05:48:07 pm »
....That is my kit and the reason I have it is because AP invited me to let them have my car specifically to test if this kit would fit OEM Monza 17's because they wanted that market. Would you believe that VW wouldn't supply them a Monza!
It does fit! - I ran the AP kit under my Monza 17's while my Monza 18's were being refurb'd and powdercoated. It is a tight clearance though.
« Reply #40 on: August 02, 2012, 05:50:34 pm »
....Neither rebuilt nor serviced so far - Only new discs and pads (originally supplied with DS2500's and now AP's own pads).
Offline drsilviuro
« Reply #41 on: August 02, 2012, 06:05:46 pm »
Now I need to source one up!  :happy2:
« Reply #42 on: August 02, 2012, 06:16:51 pm »
One thing which should be double-checked before buying is whether gazon's AP kit is the same as mine or rather whether it has any changes in dimensions anywhere.
I suggest finding out gazon's AP kit # and seeing if it's different to mine (posted earlier) and then contact AP to see if any dimensional changes. If forum Brake Guru DaveB is around, he might know.
Offline drsilviuro
« Reply #43 on: August 02, 2012, 06:41:37 pm »
I've sent a couple of PM's to Dave, but didn't answer.
I thing gazon got his brakes from here http://www.mk5golfgti.co.uk/forum/index.php/topic,41286.0.html
« Reply #44 on: August 02, 2012, 07:15:35 pm »
Dave (the Brake Guru) is often away flying and also has his hands full when at home with twin babies. But I'm sure he'll answer your PM when he can.
It'll probably help him to help you if you PM him a link to this thread. Dave is always a very helpful chap  :happy2:
