Author Topic: 101 flaming fault codes  (Read 2108 times)
Offline johnhol78
« on: July 31, 2012, 05:39:12 pm »
Some help needed if possible. The CCM on is worrying me  :confused:
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 40845C846A05
1 Fault Found:
01309 - Power Steering Control Module (J500)
            008 - Implausible Signal
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000002016266
   Coding: ED8C8F27000418000A1600001400000000197F075C
   Shop #: WSC 00200 210 90001
   VCID: 2B5E1B28F383
   Part No: 1K2 955 119 C
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00200
   Part No: 1K0 955 559 R
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 00200
2 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 212
                    Mileage: 129911 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.70 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01330 - Central Control Module for Central Convenience (J393)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 224
                    Mileage: 130625 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.70 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0001403
   Shop #: WSC 01019 210 75693
   VCID: EED8523C8011
1 Fault Found:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K0820400AB
   Coding: E9807F065002020003
   Shop #: WSC 06314 000 00000
   VCID: 346C00542EBD
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 212
                    Mileage: 131290 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:25:59
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2370
   Coding: 0000692
   VCID: 36683A5C38C1
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
   VCID: 336E03482BB3
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
This could be expensive  :confused:
vw55raz
Re: 101 flaming fault codes
« Reply #1 on: July 31, 2012, 05:42:02 pm »
have you tried clearing all faults and rescanning?
looks like most errors are in fact pointing to the cccm
Offline johnhol78
« Reply #2 on: July 31, 2012, 05:49:02 pm »
Yeah, cleared the codes and this was left.
CCCM, is that a easy part to replace or should I be going to the dealer?
vw55raz
« Reply #3 on: July 31, 2012, 06:40:22 pm »
you could get a 2nd hand one and fit yourself.
heres a guide how to change it on this post somewhere
http://forums.vwvortex.com/showthread.php?3604801-DIY-hi-line-cluster&s=0779cba71b261abc7957376722d9ad5e
