Author Topic: ABS ESP Warning lights--- a lot has been said but....  (Read 850 times)
Offline danielvelezcaicedo
  • CLEAN O'L VAGSTARD
« on: August 01, 2012, 07:50:07 pm »
Hello everybody,
I have what it seems to be a very common problem but with a lot of different apparent causes: ESP, ABS in yellow, and Hand brake in red warning lights accompanied by warning beeps. The break pads are almost new, brake fluid perfect.
When I look for it on the web, abs speed sensors and faulty ground cables appear as possible suspects. Can anyone tell me if this is where I should be looking for? is there another possible cause?
The car is a 09 GTI DSG.
Thanks.
Offline edd666999
  • -Receive: 89
Re: ABS ESP Warning lights--- a lot has been said but....
« Reply #1 on: August 01, 2012, 08:16:10 pm »
Get your car scanned via vcds. Will help you locate the issue
« Reply #2 on: August 01, 2012, 11:17:21 pm »
The car was scanned and the mecanic (VW dealer) told me it appeared that a connection was interrupted generating the message, but there was no specific part for this interruption, he told me wait and see if the next time it happens a newer, more specific code appears. In Short: No answer... hope somebody with the same problem can guide me...
« Reply #3 on: August 02, 2012, 08:12:43 am »
Do you have an after market stereo head unit by any chance?
« Reply #4 on: August 02, 2012, 07:13:52 pm »
Hello,
No, it is the sock (basic) one...
