Author Topic: Head unit does not turn on with ignition  (Read 1901 times)
Offline adam_may
« on: August 03, 2012, 09:23:22 am »
I have fitted a aftermarket head unit but it does not turn on and off with the ignition. Any ideas what i could do to solve this? Thanks Adam
Offline skard
  • -Receive: 245
Re: Head unit does not turn on with ignition
« Reply #1 on: August 03, 2012, 10:39:58 am »
The mk5 doesn't have a switched live in the radio loom.
You'll have to take a switched feed from elsewhere, or even better buy a CAN interface box.
Offline adam_may
« Reply #2 on: August 04, 2012, 10:09:52 am »
Right so what colour wire would i connect the switched live to? Yellow or red? Would i disconnect it from the loom so that the switched live goes straight to the headunit?
Offline fliprio
« Reply #3 on: August 04, 2012, 09:12:50 pm »
I did this on mine yesterday, the yellow wire which is the memory 12v goes to the 12v wire in the car stereo harness that attached to the back of the old stereo, the red wire goes stright to as switched 12v source, I fed mine into the fuse box.  I made myself a fuse tap by grinding a small amount of plastic off the end of a 10A fuse and solering the red wire to it, followed by wrapping it in electrical tape, this fuse can then go into the fusebox in a spare location which has a switched 12v, which you can find with a multimeter
my head unit now switches on and off with the ignition, unfortunantly I am having problems getting the radio to work on mine.
Offline adam_may
« Reply #4 on: August 06, 2012, 10:52:51 am »
Right cheers for that helps alot. i havent got the ariel adaptor yet so not tried my radio
Offline Gazza747
« Reply #5 on: August 06, 2012, 02:38:41 pm »
I have posted some details on the thread bu fliprio that may help with the radio adaptor.
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline bm_99
« Reply #6 on: August 06, 2012, 05:45:44 pm »
cheers for this people, handy to know before i change my stereo
