Author Topic: Do coilovers compress less the shocks and springs ?  (Read 1688 times)
Offline Ree
« on: August 04, 2012, 02:15:31 am »
Hey Peeps !
Currently running lowtec springs on standard shocks, this sometimes scrapes on the square humps when I have passengers or stuff in the boot.
Wanted to know if coilsovers handle payloads better i.e less compression under same weight compared to springs and shocks
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Do coilovers compress less the shocks and springs ?
« Reply #1 on: August 04, 2012, 03:40:53 am »
The amount of compression is no question if coilover or not, just a question what spring rates
(how stiff) and damping rates you run and what the weight of your car is.
Soft springs + soft stock dampers + heavy R32 + passengers = too much compression on bumps.
You will at least want stiffer Bilstein B6/B8 shocks or even better stiffer springs + Bilsteins.  :happy2:
« Last Edit: August 04, 2012, 03:42:28 am by the bruce »
"You get what you pay for."
Offline SI-R32
  • -Receive: 126
Re: Re: Do coilovers compress less the shocks and springs ?
« Reply #2 on: August 04, 2012, 08:23:21 am »
Ree if your putting passengers in the boot mate your doing something wrong ;D
Offline Ree
« Reply #3 on: August 04, 2012, 10:32:12 am »
Thanks for that !
I was actually thinking of getting bilstein coilovers, may have to just leave the drop at 20mm all round, have just a slight drop.
Offline Ree
« Reply #4 on: August 04, 2012, 10:32:59 am »
Where else is the mother in law gonna sit !
Offline Yawn
« Reply #5 on: August 04, 2012, 11:10:14 am »
 :signLOL:
