Author Topic: Enging squeeling ( timing belt tensioner??)  (Read 1116 times)
Offline Jbrist
« on: August 05, 2012, 12:59:30 pm »
as above my enine is squealing and what ive read is that it is the timing belt tensioner???
heres the video
I will be replacing it but just wanted to know if i should go for the genuine kit or the ecs kit heres the linkhttp://www.psituning.com/product.php/19169/ecs_ultimate_timing_belt_kit___2_0t_bpy
please let me know what you all think is best.
Thanks Josh
Offline dan930
  • -Receive: 56
Re: Enging squeeling ( timing belt tensioner??)
« Reply #1 on: August 05, 2012, 01:33:16 pm »
Mine was squealing like a pig..but had the cambelt,water pump & tensioners done a few days ago and not heard any noise since
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
« Reply #2 on: August 05, 2012, 02:09:46 pm »
Mine would squeal quietly on start / cold start. New cambelt / WP and it went away :)
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
« Reply #3 on: August 05, 2012, 02:16:14 pm »
Definitely the tensioner ,  its a well known issue when the belt needs replacing. Replace the cambelt , tensioner and waterpump with oem parts  :happy2:
Offline Black9
  • -Given: 35
« Reply #4 on: August 05, 2012, 03:44:12 pm »
Mines does This sometimes when pulling away from a standstill. Only sometimes tho. Same problem u think
Offline Jbrist
« Reply #5 on: August 05, 2012, 03:48:05 pm »
Thanks for the replys hopefully I'll get it done in the week.
Why oem and not ecs?
Offline Matto
  • -Receive: 116
« Reply #6 on: August 05, 2012, 10:58:44 pm »
One thing I will say just for reference, but doesn't seem the case with yours is I have had a problem on my old mk4 where the tensioner was flapping like crazy. You would only here a chirp from the belt when on full look or as the engine loaded up.
I changed the tensioner and it went away for a day or so then came back. Finally found out that it was the alternator pulley. It has a slipper clutch mechanism built into it which had seized.
