Author Topic: Camshaft replacement - cost?  (Read 17887 times)
Offline johnhol78
« on: August 06, 2012, 12:48:58 pm »
What sort f price could i be looking at to have the camshaft replaced?
Still get fuelling issues after replacing a perfectly good follower, Thrust sensor and have a horrible feeling it could be the cam.
J
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: Camshaft replacement - cost?
« Reply #1 on: August 06, 2012, 05:34:11 pm »
Sorry I can't help you with the exact cost but IIRC it's around £1000-1500ish.
If your follower was ok when you removed it, the cam should be fine.
Could be the pump?
Graeme
Offline johnhol78
« Reply #2 on: August 06, 2012, 06:12:45 pm »
Could be the pump?
Graeme
To be honest mate I'm completely lost......Could be HPFP, LPFP, Camshaft, Fuel Filter.......could be £100 or as you say £1500ish.
Just want a car that drives without issues.......love my GTI but relationship is becoming strained.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: August 06, 2012, 06:21:28 pm »
for £1500 i'd buy an S3 engine for it, and sell all the working bits of your old engine to make up the cost.
PLANS: Stage 2+
Offline johnhol78
« Reply #4 on: August 06, 2012, 06:25:03 pm »
That's what I thought....wouldn't pay that to fix an engine when i can get a better one for the same price.
Offline TopsGTI
« Reply #5 on: August 06, 2012, 09:35:46 pm »
Had some fuelling issues recently which was traced to fuel pump cam follower, the camshaft lobe was badly scored unfortunately which required replacement too. I paid £640 ish for camshaft, cam follower, new DV and oil change at Volkcraft in Exeter.
Offline johnhol78
« Reply #6 on: August 06, 2012, 10:16:05 pm »
Cam follower been changed twice in 20k an both times been in pretty good condition, felt the cam surface and felt smooth as a babies......so unlikely that though bracing myself. Booked into the stealers tomorrow as can;t get hold of any decent local tuners/specialists.
Thinking a sensor as the car was perfect again when i popped out to a mates house......once it's warm it seems to go to limp mode so thinking LPFP or even possible the knackered air intake bracket and hose that keeps coming away - would lack of air or very hot air cause limp mode behaviour???
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #7 on: August 06, 2012, 10:59:52 pm »
2.0TFSI cams will be under 500 notes. Then just the labour to swap em over.
Offline heavyd
  • -Receive: 29
« Reply #8 on: August 07, 2012, 01:14:53 am »
I had intermittant fuelling issues before and it was a faulty in tank pump. someone else had issueson here recently, and his was down to a blocked fuel filter
Offline johnhol78
« Reply #9 on: August 07, 2012, 08:39:24 am »
Did you have the issue where it won't rev over 3k and the fault code says:
004195 - Fuel Pressure Regulation: Control Range Not Reached
               P1063 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 68
                    Mileage: 130010 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:27:06
             Freeze Frame:
                    RPM: 758 /min
                    Load: 17.6 %
                    Speed: 11.0 km/h
                    Temperature: 88.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
Readiness: 0000 0000
If so then I might get a fuel filter and LPFP first
Offline heavyd
  • -Receive: 29
« Reply #10 on: August 07, 2012, 09:58:11 am »
cant remember the fault code, sorry.
The fuel filter is a cheap job to do anyway, will only take you 10mins, worthwhile doing anyway.
Heres a log of mine when the in tank pump went iffy
Offline johnhol78
« Reply #11 on: August 07, 2012, 11:17:36 am »
Looks very similar to mine. Not sure what to do....get an LPFP and fit myself or take it to a garage as it might be HPFP....
Offline heavyd
  • -Receive: 29
« Reply #12 on: August 07, 2012, 12:39:47 pm »
with it being an intermittant fault, you need to just keep driving about continuously datalogging the lpfp and hpfp.
I paid for a hpfp for no reason whatsoever. bear in mind theyre both ~£160 mark.
The garage wont know whether its the lpfp or the hpfp either, without seeing the logs when it goes iffy.
Like I said, another member had the same issues and it was down to the fuel filter.
I'm just trying to advise you from my mistakes.
Offline heavyd
  • -Receive: 29
« Reply #13 on: August 07, 2012, 12:41:41 pm »
If you look at my logs, its clear to see the lpfp is struggling, thats what you need to be looking for. it should be running at no less than around 4 bar.
I only found the fauilt by having my laptop plugged in, and driviing around for ages until it reoccured :happy2:
Offline johnhol78
« Reply #14 on: August 07, 2012, 01:10:35 pm »
Is that block 231?
