Author Topic: Best place to run amp power cable  (Read 6863 times)
Offline adam_may
« on: August 06, 2012, 01:38:24 pm »
Wheres the best place to run the power cable for the amp from the battery i to the car? I cant see any grommits or anything that i could put it through! MK5 golf. Cheers Adam
Offline silent dubber
    • Readers Ride
Re: Best place to run amp power cable
« Reply #1 on: August 09, 2012, 12:16:58 pm »
Mate this is pretty simples.
Right remove the bottom end of the Glove box's ( work carefully as theres wires and the b/box is also connected to a bracket under the centre console and if you over force it it will snap
Ok Underneath the right in the n/s mid corner is a wiring loom, there's enough gap to pass a amp power wire through it is quite fidily so just be patient
Get a wire made coat hanger and wrap the wire road it and make sure you cover it in insulation tape as you dont to cause any damage underneath, the amp wire will come out by the firewall/scuttle, behind the fuse box.
Thats job done
Silent Dubber
Instagram:- harveyrooprai
build thread - http://www.mk5golfgti.co.uk/forum/index.php/topic,51322.0.html
Offline bm_99
« Reply #2 on: August 12, 2012, 01:07:36 pm »
Thats job done
Is that big enough for a 0 gaue cable mate>
Offline dub singh
  • Snakebite Chasers...
« Reply #3 on: August 13, 2012, 12:31:08 am »
It is indeed...  Ive got 2 runs of 0 gauge going through.. jus make sure you lubricate it well.. bit of fairy liquid oughta do the job..
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Offline fraggle17
« Reply #4 on: January 10, 2013, 03:51:31 pm »
i've tried to do this today, but i only have a T25 torq wrench for my MTB and it appears that the bolts are smaller than this :confused: will it be safe to say wire the power from the rear 12V socket in the boot or will this result in fuse blowing/overheating of the wire or boot socket?
Offline Scrubadub
  • Soon to be "bagged"
« Reply #5 on: January 10, 2013, 03:55:22 pm »
There rear cigarette lighter is 10amp max
Fun bags
Offline fraggle17
« Reply #6 on: January 10, 2013, 04:07:17 pm »
ok, so it wont work? i have had this sub for years and don't know what spec it is to be honest! what sort of ampage will it need?
Offline Scrubadub
« Reply #7 on: January 11, 2013, 07:16:20 am »
Depending on what power the amp is but if its a decent size 1 to need o gauge wire I'm sure it will draw more than 10amps
Fun bags
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #8 on: May 29, 2021, 10:57:16 pm »
bump for blingsta
Offline blingsta
« Reply #9 on: May 29, 2021, 11:28:51 pm »
Perfect 👍.. cheers fella
