Author Topic: oil cooler  (Read 2945 times)
Offline james
oil cooler
« on: August 06, 2012, 10:08:50 pm »
where is the best place to get one? make wise also?
on a long hard drive my oil is getting up to 115oc.
will remove ac rad at the same time  :party:
Offline Scrubadub
  • Soon to be "bagged"
Re: oil cooler
« Reply #1 on: August 07, 2012, 02:39:17 pm »
Thats considered a fine operating temperature.
I once fitted an oil cooler without a thermostat and it kept oil temps to about 80deg, and caused my oil to go like mayonnaise.
The oil needed to get to a higher temperature to evaporate the moisture.
I dred to think the long term damage it would of caused  :stupid:
Fun bags
Offline PDT
  • -Receive: 142
Re: oil cooler
« Reply #2 on: August 07, 2012, 06:39:24 pm »
100-120 degrees is acceptable. I had issues with oil temp on my 135i, switching to 10-50 oil has helped.
Offline vRSAlex
  • -Receive: 253
Re: oil cooler
« Reply #3 on: August 07, 2012, 06:43:25 pm »
I can do you one.  Mocal cooler and nice braided lines with an inline thermostat.
Follow AKS tuning on Facebook
Re: oil cooler
« Reply #4 on: August 07, 2012, 09:09:48 pm »
I would say change it every 5k and don't worry about it.  :smiley:
Offline vRSAlex
  • -Receive: 253
Re: oil cooler
« Reply #5 on: August 07, 2012, 09:19:11 pm »
If the temps get too high then the oil gets too thin and cant lubricate.
James, what oil do you use?
Offline james
Re: oil cooler
« Reply #6 on: August 07, 2012, 10:54:17 pm »
Castrol 530 fst
you think I should change to a different oil?
Offline vRSAlex
  • -Receive: 253
Re: oil cooler
« Reply #7 on: August 07, 2012, 11:10:27 pm »
Castrol 530 fst
Yes.  Go to a 5w40 competition oil.  You should notice the temp drop slightly too.
I would recommend the Millers cfs 5w40 nt.  Running this in my car and loads of others on here are too.  Highest temps I saw at a brunters track day was 110.  On the road I'm usually around 90.
Offline james
Re: oil cooler
« Reply #8 on: August 08, 2012, 07:09:12 pm »
sounds good to me, i will get some on order  :happy2:
